Precession of equanox
  • Precession of equanox
    Greetings all, Hi..
    Its been a wile before i posted last.
    This is the reason, i am continuing to validate all the evidence before me. I hope to present all that was learned to you guys here for sincere conclusion.
    Let me just say i must be an expert by now, i really want you guys to post your questions and input.
    some of you may have read my ice age model. i have expanded and made verifiable conclusions.
    I will say most definitely external torque precession is the case.
    torque is being applied on earths axis.
    i will add more i just need a starting point..
    If the bird that we see quacks like a duck and swims like a duck, and so on all the way down the line, then it‘s a duck.
    If it crows like a rooster and can‘t swim, then it‘s not a duck. It
    doesn‘t make any difference how many people insist on calling it a duck, —it still isn‘t a duck.
    The physicists‘ atom is an imaginary atom constructed of
    imaginary particles.
    Irwin Schroedinger tells us, “If the question is asked, do the electrons actually exist on these orbits
    within the atom, the answer has to be a decisive no. “The atom of modern physics can only be symbolized by
    a partial differential equation in an abstract multi- dimensional space.”
    Ice age 3 d -model described. Yes Doctor? The precession is continuity torquing. It continues to follow the slipping top analogy.
    Its simply spinning. Its simply stunning, its simply continues to rotate I will exaggerate your observations. Its simply up to you to observe.
    As it rotates earthquakes become time variable according to rotational speed. The axis it i pointing, it following the spinning top.. its simply slipping. its simply a stunning effect. There is a pressure of fluid within the core. Its simply splitting, its Humphrey Dummpie. Its described ,and self verifying. Its simply continues.
    Its bursting, of a water balloon. Its simply to soon., Its simply predictable. Its following its secondary oscillation. Beating like a drum. The wave is in front. Its simply like a pointy boat or arrow. Its simply caused by this star. There is, simply no way around. The time frame was predictable. Its simply solar rotation. Its simply lunar precession. @3 days of solar rotation, and according to speed it will split like a cord. Ripping the seams. Its
    It was simply well known. Its simply a des-cry. An utter dis-( By grace). I am simply sorry. It simply was well known to be true. lighting up like a tree on Christ mass day. Its spilling on two sides. The start of the predictable out come is time variable. It also follow along the net force inducing. Its also bouncing and skipping along. simply bending space. What is relativity?
    Its simply, Cause and effect.. Angel
    As the earth spheroid preforms like an egg.
      cause and effect
      The scientific principles of mass, or charge the direction of that force. gravity. I hope you will enjoy these lectures.. I did..
      Lec 4 MIT 8 02 Electricity and Magnetism, Spring 2002 - YouTube
      Lec 13 8 01 Physics I Classical Mechanics, Fall 1999 - YouTube
      lEC 6 mit 8 02 eLECTRICITY AND mAGNETISM, sPRING 2002 - YouTube
      I had reviewed this information over the last few days, and i was very interested. Walter lewin had described the direction of increasing potential, and also the gravitational force placed on that charge.
      Go over the material a few times. this is the formula for calculating the gravitational flux or electric field. In this lecture something became apparent to me
      Astronomy of binary systems of stars or planets, .how to relate the real work to reality? How do we separate what is fantastic in its Glory?
      If i have charge sun, and charge little sun, and i let the little partner star go; It will try to find equilibrium. it will move to the lower potential.
      I ask how can this be? I suppose that the velocity of little sun does not remain constant and is speeding up. We get to a point were little sun needs to exert a strong force on big sun, a increasing potential. So i had said the sun is also increasing in potential energy, but the force is clearly pushing little sun away.
      If it be that the sun is at its farthest point from earth as we have known it, it is in fact one million miles farther than it used to be... How can a force little sun exert a pressure strong enough to move the sun 1 million miles out of its way so it may then change direction, and we get a gravitational force in the opposite direction that is decreasing.
      this is to help me understand the formula better, and to also include that both potential energy on little sun, and sun are increasing. I really have to push...
      binary sun - YouTube
      802. lec 6 solve for the electric potential, or the total net charge of the local flux field. the cold ISCM.
      we know now, or may estimate the flux, or electric potential. how?
      There are 2 clear give away, Temple one, and Hartley 2 comets.
      Why is this important you may ask? because we can now solve for the given charge of the field, and for the pressure density on these two object that must, by certain well known principle, have the greatest charge density of the equal potential of the addition of the given charges that surround them.
      solve for all the charges that have a high potential of large radius.
      It is now a clear indicator that the coma of the smaller objects reflect these net charges around them.
      therefore we conclude it is the coma of these smaller objects reflect the total energy of the surrounding charges in the ISCM of space.
      The total energy of the charges are therefore of greater mass, and the smaller radius of the smaller given objects reflect this increase of net charge of the surrounding charges of equal potential. making up the local electric field configuration of the given charges.
      the sun also will reflect these charges in the same given way. Objects of large radius and high potential charge, we may get the total net charge of the equal potential region of the ISCM. Electric field.. we must add, and include all of the charges together,
      the smaller radius objects are ionizing space, that much is clear...
      Dipole Automatic. charge Space configuration. - YouTube
