News with Discovery
  • News with Discovery
    Articles with the most amazing discoveries are posted here!
    Energetic Forum Administrator
    http://www.energeticforum.com
    Mysterious 'Neural Noise' Actually Primes Brain for Peak Performance
    November 13, 2006 -
    Researchers at the University of Rochester may have answered one of neuroscience's most vexing questions-how can it be that our neurons, which are responsible for our crystal-clear thoughts, seem to fire in utterly random ways?
    In the November issue of Nature Neuroscience, the Rochester study shows that the brain's cortex uses seemingly chaotic, or "noisy," signals to represent the ambiguities of the real world-and that this noise dramatically enhances the brain's processing, enabling us to make decisions in an uncertain world.
    "You'd think this is crazy because engineers are always fighting to reduce the noise in their circuits, and yet here's the best computing machine in the universe-and it looks utterly random," says Alex Pouget, associate professor of brain and cognitive sciences at the University of Rochester.
    Pouget's work for the first time connects two of the brain's biggest mysteries; why it's so noisy, and how it can perform such complex calculations. As counter-intuitive as it sounds, the noise seems integral to making those calculations possible.
    In the last decade, Pouget and his colleagues in the University of Rochester's Department of Brain and Cognitive Sciences have blazed a new path to understanding our gray matter. The traditional approach has assumed the brain uses the same method computation in general had used up until the mid-80s: You see an image and you relate that image to one stored in your head. But the reality of the cranial world seems to be a confusing array of possibilities and probabilities, all of which are somehow, mysteriously, properly calculated.
    The science of drawing answers from such a variety of probabilities is called Bayesian computing, after minister Thomas Bayes who founded the unusual branch of math 150 years ago. Pouget says that when we seem to be struck by an idea from out of the blue, our brain has actually just resolved many probabilities its been fervently calculating.
    "We've known for several years that at the behavioral level, we're 'Bayes optimal,' meaning we are excellent at taking various bits of probability information, weighing their relative worth, and coming to a good conclusion quickly," says Pouget. "But we've always been at a loss to explain how our brains are able to conduct such complex Bayesian computations so easily."
    Two years ago, while talking with a physics friend, some probabilities in Pouget's own head suddenly resolved.
    "One day I had a drink with some machine-learning researchers, and we suddenly said, 'Oh, it's not noise,' because noise implies something's wrong," says Pouget. "We started to realize then that what looked like noise may actually be the brain's way of running at optimal performance."
    Bayesian computing can be done most efficiently when data is formatted in what's called "Poisson distribution."
    And the neural noise, Pouget noticed, looked suspiciously like this optimal distribution.
    This idea set Pouget and his team into investigating whether our neurons' noise really fits this Poisson distribution, and in his current Nature Neuroscience paper he found that it fit extremely well.
    "The cortex appears wired at its foundation to run Bayesian computations as efficiently as can be possible," says Pouget. His paper says the uncertainty of the real world is represented by this noise, and the noise itself is in a format that reduces the resources needed to compute it. Anyone familiar with log tables and slide rules knows that while multiplying large numbers is difficult, adding them with log tables is relatively undemanding.
    The brain is apparently designed in a similar manner-"coding" the possibilities it encounters into a format that makes it tremendously easier to compute an answer.
    Pouget now prefers to call the noise "variability." Our neurons are responding to the light, sounds, and other sensory information from the world around us. But if we want to do something, such as jump over a stream, we need to extract data that is not inherently part of that information. We need to process all the variables we see, including how wide the stream appears, what the consequences of falling in might be, and how far we know we can jump. Each neuron responds to a particular variable and the brain will decide on a conclusion about the whole set of variables using Bayesian inference.
    As you reach your decision, you'd have a lot of trouble articulating most of the variables your brain just processed for you. Similarly, intuition may be less a burst of insight than a rough consensus among your neurons.
    Pouget and his team are now expanding their findings across the entire cortex, because every part of our highly developed cortex displays a similar underlying Bayes-optimal structure.
    "If the structure is the same, that means there must be something fundamentally similar among vision, movement, reasoning, loving-anything that takes place in the human cortex," says Pouget. "The way you learn language must be essentially the same as the way a doctor reasons out a diagnosis, and right now our lab is pushing hard to find out exactly how that noise makes all these different aspects of being human possible."
    Pouget's work still has its skeptics, but this, his fourth paper in Nature Neuroscience on the topic, is starting to win converts.
    "If you ask me, this is the coming revolution," says Pouget. "It hit machine learning and cognitive science, and I think it's just hitting neuroscience. In 10 or 20 years, I think the way everybody thinks about the brain is going to be in these terms."
    Not all of Pouget's neurons are in agreement, however.
    "…but I've been wrong before," he shrugs.
    Original Article Here
    RPX & MWO http://vril.io
      'The Matrix' is a step closer to reality; Neuroscientists break code on sight
      In the sci-fi movie "The Matrix," a cable running from a computer into Neo's brain writes in visual perceptions, and Neo's brain can manipulate the computer-created world. In reality, scientists cannot interact directly with the brain because they do not understand enough about how it codes and decodes information.
      Image: Neurons in a purely visual brain region called the inferotemporal (IT) cortex respond selectively to different images. As pictures were randomly presented to the monkey during specific intervals (top), neurons at different sites in IT produce distinct patterns of activity to each picture (bottom). For example, neurons at site 1 favor the toy and the yam, while neurons at site 3 prefer the monkey face and the cat. Image courtesy / Poggio/DiCarlo labs
      Now, neuroscientists in the McGovern Institute at MIT have been able to decipher a part of the code involved in recognizing visual objects. Practically speaking, computer algorithms used in artificial vision systems might benefit from mimicking these newly uncovered codes.
      The study, a collaboration between James DiCarlo's and Tomaso Poggio's labs, appears in the Nov. 4 issue of Science.
      "We want to know how the brain works to create intelligence," said Poggio, the Eugene McDermott Professor in Brain Sciences and Human Behavior. "Our ability to recognize objects in the visual world is among the most complex problems the brain must solve. Computationally, it is much harder than reasoning." Yet we take it for granted because it appears to happen automatically and almost unconsciously.
      "This work enhances our understanding of how the brain encodes visual information in a useful format for brain regions involved in action, planning and memory," said DiCarlo, an assistant professor of neuroscience.
      In a fraction of a second, visual input about an object runs from the retina through increasingly higher levels of the visual stream, continuously reformatting the information until it reaches the highest purely visual level, the inferotemporal (IT) cortex. The IT cortex identifies and categorizes the object and sends that information to other brain regions.
      To explore how the IT cortex formats that output, the researchers trained monkeys to recognize different objects grouped into categories, such as faces, toys and vehicles. The images appeared in different sizes and positions in the visual field. Recording the activity of hundreds of IT neurons produced a large database of IT neural patterns generated in response to each object under many different conditions.
      Then, the researchers used a computer algorithm, called a classifier, to decipher the code. The classifier was used to associate each object -- say, a monkey's face -- with a particular pattern of neural signals, effectively decoding neural activity. Remarkably, the classifier found that just a split second's worth of the neural signal contained specific enough information to identity and categorize the object, even at positions and sizes the classifier had not previously "seen."
      It was quite surprising that so few IT neurons (several hundred out of millions) for such a short period of time contained so much precise information. "If we could record a larger population of neurons simultaneously, we might find even more robust codes hidden in the neural patterns and extract even fuller information," Poggio said.
      Source: MIT
      Original article is here
        Advancements in Technology and Knowledge
        How fast is technology and our human knowledgebase growing???
        YouTube - Karl Fisch's Did You Know? Remix
        A great video to put it in perspective.
          Absolutely mind boggling. Loved the music too
          Thanks for posting Aaron!
          Love and joy,
          Pamela
          Namaste,
          Pamela
          Discover the Single Greatest Health Science Breakthrough of the Century
            Thanks Aaron <thumbs up>
            Mind boggled
            Alan
            Save over $1,000 on PATHS
            Live your dreams through choosing PATHS
              Wow!!!
              Thank You So Much, Aaron!
              I Loved looking to this....It gave me Goose Bumps!!!
              With Much Love and Gratitude,
              Pamela
              www.pathstopowerfulpotential.com: Program Authoring The Human Subconscious
              My PATHS Website
              My Art Website
              My Paintings As Prints
              My Facebook
