Euler's Equation and the Reality of Nature.
  • Euler's Equation and the Reality of Nature.
    a)
    Euler's Equation as a mathematical reality.
    Euler's identity is "the gold standard for mathematical beauty'.
    Euler's identity is "the most famous formula in all mathematics".
    ‘ . . . this equation is the mathematical analogue of Leonardo
    da Vinci’s Mona Lisa painting or Michelangelo’s statue of David’
    ‘It is God’s equation’, ‘our jewel ‘, ‘ It is a mathematical icon’.
    . . . . etc.
    b)
    Euler's Equation as a physical reality.
    "it is absolutely paradoxical; we cannot understand it,
    and we don't know what it means, . . . . .’
    ‘ Euler's Equation reaches down into the very depths of existence’
    ‘ Is Euler's Equation about fundamental matters?’
    ‘It would be nice to understand Euler's Identity as a physical process
    using physics.‘
    ‘ Is it possible to unite Euler's Identity with physics, quantum physics ?’
    My aim is to understand the reality of nature.
    Can Euler's equation explain me something about reality?
    To give the answer to this. question I need to bind
    Euler's equation with an object – particle.
    Can it be math- point particle or string- particle or triangle-particle?
    No, Euler's formula has quantity (pi) which says me that
    the particle must be only a circle .
    Now I want to understand the behavior of circle - particle and
    therefore I need to use spatial relativity and quantum theories.
    These two theories say me that the reason of circle – particle’s
    movement is its own inner impulse (h) or (h*=h/2pi).
    a)
    Using its own inner impulse (h) circle - particle moves
    ( as a wheel) in a straight line with constant speed c = 1.
    We call such particle - ‘photon’.
    From Earth – gravity point of view this speed is maximally.
    From Vacuum point of view this speed is minimally.
    In this movement quantum of light behave as a corpuscular (no charge).
    b)
    Using its own inner impulse / intrinsic angular momentum
    ( h* = h / 2pi ) circle - particle rotates around its axis.
    In such movement particle has charge, produce electric waves
    ( waves property of particle) and its speed ( frequency) is : c>1.
    We call such particle - ‘ electron’ and its energy is: E=h*f.
    In this way I can understand the reality of nature.
    Best wishes.
    Israel Sadovnik Socratus.
    P.S.
    ' They would play a greater and greater role in mathematics –
    and then, with the advent of quantum mechanics in the twentieth
    century, in physics and engineering and any field that deals with
    cyclical phenomena such as waves that can be represented by
    complex numbers. For a complex number allows you to represent
    two processes such as phase and wavelenght simultaneously –
    and a complex exponential allows you to map a straight line
    onto a circle in a complex plane.'
    / Book: The great equations. Chapter four.
    The gold standard for mathematical beauty.
    Euler’s equation. Page 104. /
    Euler's e-iPi+1=0 is an amazing equation, not in-and-of itself,
    but because it sharply points to our utter ignorance of the
    simplest mathematical and scientific fundamentals.
    The equation means that in flat Euclidean space, e and Pi happen
    to have their particular values to satisfy any equation that relates
    their mathematical constructs. In curved space, e and Pi vary.
    / Rasulkhozha S. Sharafiddinov . /
    Physics obeys mathematical laws.
    Mathematics must coincide with physical reality
    These coincidences build on each other in elegant way
    and this beauty, when math aligns with physical reality,
    we see in our world.
    But when we try to pass to quantum physics we lost our logic.
    In 1985 Richard P. Feynman wrote:
    ‘ The idea of book - the interaction between light
    ( electromagnetic fields ) and matter is strange. ‘
    ‘ The theory of quantum electrodynamics
    describes Nature as absurd from the point of view
    of common sense. And it agrees fully with experiment.
    So I hope you accept Nature as She is — absurd. ‘
    / book:
    QED: The Strange Theory of Light and Matter page 10. /
      My questions are:
      Can ‘dirac’s virtual particles’ have geometrical form of circle?
      Can we use Euler equation to this circle- particle ?
      Which physical laws can we use to this circle- particle ?
      How can be tied Euler equation, physical laws and
      circle- particle into one theory ?
      I say that there is circle-particle that can change /
      transformed into sphere-particle and vice versa
      and Euler’s equation cosx + isinx in = e^ix can explain
      this transformation / fluctuation of quantum particle
      I try to understand more details.
      I have circle- particle with two infinite numbers: (pi) and (e).
      I say that this circle-particle that can change into sphere-particle
      and vice versa. Then I need third number for these changes.
      The third number, in my opinion, is infinite a=1/137
      ( the fine structure constant = the limited volume coefficient)
      This coefficient (a=1/137) is the border between two
      conditions of quantum particle. This coefficient (a=1/137) is
      responsible for these changes. This coefficient (a=1/137) unite
      geometry with the physics ( e^2=ah*c)
      If physicists use string-particle (particle that has length but
      hasn’t thickness -volume) to understand reality
      (and have some basic problems to solve this task) then why don’t
      use circle-particle for this aim.
      It is a pity that I am not physicist or mathematician.
      If I were mathematician or physicist I wouldn’t lost the chance
      to test this hypothesis.
      Best wishes.
        By the way,
        according to Charle’s law and the consequence of the
        third law of thermodynamics as the thermodynamic temperature
        of a system approaches absolute zero the volume of particles
        approaches zero too. It means the particles must have flat forms.
        They must have geometrical form of a circle: pi= c /d =3,14 . .
        ( All another geometrical forms : triangle, rectangle . . .etc
        have angles and to create angles is needed a force,
        without force all geometrical forms must turn into circle.)
