The Milky Way's halo is curved spacetime
  • The Milky Way's halo is curved spacetime
    A 'new dark force' is more speculative than understanding space itself has mass.
    'Galactic Pile-Up May Point to Mysterious New Dark Force in the Universe'
    Galactic Pile-Up May Point to Mysterious New Dark Force in the Universe | Wired Science | Wired.com
    "The reason this is strange is that dark matter is thought to barely interact with itself. The dark matter should just coast through itself and move at the same speed as the hardly interacting galaxies. Instead, it looks like the dark matter is crashing into something — perhaps itself – and slowing down faster than the galaxies are. But this would require the dark matter to be able to interact with itself in a completely new an unexpected way, a “dark force” that affects only dark matter."
    It's not a new force. It's the aether displaced by the galaxies interacting analogous to the bow waves of two boats which pass by each other.
    'Ether and the Theory of Relativity by Albert Einstein'
    Einstein: "Ether and Relativity"
    "the state of the [ether] is at every place determined by connections with the matter and the state of the ether in neighbouring places"
    The state of the aether at every place determined by connections with the matter and the state of the aether in neighboring places is the state of displacement of the aether.
    Aether has mass. Aether physically occupies three dimensional space. Aether is physically displaced by matter. There is no such thing as non-baryonic dark matter anchored to matter. Matter moves through and displaces the aether.
    'Hubble Finds Ghostly Ring of Dark Matter'
    NASA - Hubble Finds Ghostly Ring of Dark Matter
    "Astronomers using NASA's Hubble Space Telescope got a first-hand view of how dark matter behaves during a titanic collision between two galaxy clusters. The wreck created a ripple of dark mater, which is somewhat similar to a ripple formed in a pond when a rock hits the water."
    The 'pond' consists of aether. The analogy are two boats which pass by each other very closely. Their bow waves slosh back and forth and create a ripple in the water.
    The Milky Way's halo is what is referred to as the curvature of spacetime.
    The Milky Way's halo is the state of displacement of the aether.
    The geometrical representation of gravity as curved spacetime physically exists in nature as the state of displacement of the aether.
    Displaced aether pushing back and exerting inward pressure toward matter is gravity.
    'NASA's Voyager Hits New Region at Solar System Edge'
    NASA - NASA's Voyager Hits New Region at Solar System Edge
    "Voyager is showing that what is outside is pushing back. ... Like cars piling up at a clogged freeway off-ramp, the increased intensity of the magnetic field shows that inward pressure from interstellar space is compacting it."
    It is not the particles of matter which exist in quantities less than in any vacuum artifically created on Earth which are pushing back and exerting inward pressure toward the solar system.
    It is the aether, which the particles of matter exist in, which is the interstellar medium. It is the aether which is displaced by the matter the solar system consists of which is pushing back and exerting inward pressure toward the solar system.
    'Offset between dark matter and ordinary matter: evidence from a sample of 38 lensing clusters of galaxies'
    http://arxiv.org/PS_cache/arxiv/pdf/...004.1475v1.pdf
    "Our data strongly support the idea that the gravitational potential in clusters is mainly due to a non-baryonic fluid, and any exotic field in gravitational theory must resemble that of CDM fields very closely."
    The offset is due to the galaxy clusters moving through the aether. The analogy is a submarine moving through the water. You are under water. Two miles away from you are many lights. Moving between you and the lights one mile away is a submarine. The submarine displaces the water. The state of displacement of the water causes the center of the lensing of the light propagating through the water to be offset from the center of the submarine itself. The offset between the center of the lensing of the light propagating through the water displaced by the submarine and the center of the submarine itself is going to remain the same as the submarine moves through the water. The submarine continually displaces different regions of the water. The state of the water connected to and neighboring the submarine remains the same as the submarine moves through the water even though it is not the same water the submarine continually displaces. This is what is occurring physically in nature as the galaxy clusters move through and displace the aether.
    'Interpretation of quantum mechanics by the double solution theory - Louis de BROGLIE'
    http://aflb.ensmp.fr/AFLB-classiques/aflb124p001.pdf
    “When in 1923-1924 I had my first ideas about Wave Mechanics I was looking for a truly concrete physical image, valid for all particles, of the wave and particle coexistence discovered by Albert Einstein in his "Theory of light quanta". I had no doubt whatsoever about the physical reality of waves and particles.”
    “any particle, even isolated, has to be imagined as in continuous “energetic contact” with a hidden medium”
    The hidden medium of de Broglie wave mechanics is the aether. The “energetic contact” is the state of displacement of the aether.
    "For me, the particle, precisely located in space at every instant, forms on the v wave a small region of high energy concentration, which may be likened in a first approximation, to a moving singularity."
    A particle is a moving singularity which has an associated aether displacement wave.
    In a double slit experiment the particle travels a well defined path which takes it through one slit. The associated wave in the aether passes through both. As the aether wave exits the slits it creates wave interference. As the particle exits a single slit the direction it travels is altered by the wave interference. This is the wave piloting the particle of pilot-wave theory. Detecting the particle strongly exiting a single slit destroys the coherence between the particle and its associated wave in the aether.
    What ripples when galaxy clusters collide is what waves in a double slit experiment; the aether.
    Einstein's gravitational wave is de Broglie's pilot-wave. Both are waves in the aether.
