New Rock HX4G/MX8G
  • New Rock HX4G/MX8G
    New Rock HX4G/MX8G
    Developed for low-port-count applications, such as fax-terminal connectivity, small
    businesses, SOHO, and residential IP-telephony applications, the HX4G/MX8G gateways are
    integrated VoIP-FoIP devices that provide reliable and cost-efficient access methods for
    deploying converged communication solutions for network operators and enterprises. The
    HX4G/MX8G are designed as a compact unit with 2, 4, or 8 FXS/FXO ports, 1 WAN port and 1
    PC port (both are 10/100/1000Mbps Ethernet ports), which allows users to apply it as an
    All-in-One system capable of providing versatile solutions by connecting analog phone,
    fax and POS machine, IP telephony and PSTN.
    New Rock Comprehensive Feature Set with Intelligent Engine
    As intelligent gateways running on embedded Linux operating system, the HX4G/MX8G are
    compatible with many highlighted features such as call forward, call transfer, 3-way
    conference, caller ID, DND, color ringback, forking, automatic routing, digitmap, PSTN
    failover, and much more to provide a complete and highly reliable VoIP solution
    applicable to nearly every application scenarios.
    New Rock High Reliability
    The hardware design of the HX4G/MX8G, from architecture to component selection, is made
    to optimize reliability.
    In addition, with high availability featuring primary-standby, active-standby, and load
    balancing, as well as PSTN failover to handle the failure of the SIP proxy servers,
    power supply, and network, users are provided with carrier-class availability with
    minimized potential downtime.
