Originally posted by Mad Scientist
Proof 9/11 was planned is in.
Active Thermitic Material Discovered in Dust from the 9/11 World Trade Center Catastr
There was thermite loaded throughout the complex and it is more than just
Jones saying this... I posted this in the past, here it is again - regardless
of what this online journals is - there are credible chemists in the paper.
Get the pdf:
http://www.bentham.org/open/tocpj/ar...002/7TOCPJ.pdf
Here is the abstract of the paper published in the peer reviewed journal:
Open Chemical Physics Journal:
Bentham Science Publishers
The download link to the left gives you the pdf for free and there are NINE (9) authors of the article and not just Jones from Utah.
Active Thermitic Material Discovered in Dust from the 9/11 World Trade Center Catastrophe
Niels H. Harrit*,1, Jeffrey Farrer2, Steven E. Jones*,3, Kevin R. Ryan4, Frank M. Legge5, Daniel Farnsworth2, Gregg Roberts6, James R. Gourley7 and Bradley R. Larsen3
1 Department of Chemistry, University of Copenhagen, Denmark
2 Department of Physics and Astronomy, Brigham Young University, Provo, UT 84602, USA
3 S&J Scientific Co., Provo, UT, 84606, USA
4 9/11 Working Group of Bloomington, Bloomington, IN 47401, USA
5 Logical Systems Consulting, Perth, Western Australia
6 Architects & Engineers for 9/11 Truth, Berkeley, CA 94704, USA
7 International Center for 9/11 Studies, Dallas, TX 75231, USA
Abstract: We have discovered distinctive red/gray chips in all the samples we have studied of the dust produced by the
destruction of the World Trade Center. Examination of four of these samples, collected from separate sites, is reported in
this paper. These red/gray chips show marked similarities in all four samples. One sample was collected by a Manhattan
resident about ten minutes after the collapse of the second WTC Tower, two the next day, and a fourth about a week later.
The properties of these chips were analyzed using optical microscopy, scanning electron microscopy (SEM), X-ray energy
dispersive spectroscopy (XEDS), and differential scanning calorimetry (DSC). The red material contains grains approximately
100 nm across which are largely iron oxide, while aluminum is contained in tiny plate-like structures. Separation
of components using methyl ethyl ketone demonstrated that elemental aluminum is present. The iron oxide and aluminum
are intimately mixed in the red material. When ignited in a DSC device the chips exhibit large but narrow exotherms occurring
at approximately 430 °C, far below the normal ignition temperature for conventional thermite. Numerous iron-rich
spheres are clearly observed in the residue following the ignition of these peculiar red/gray chips. The red portion of these
chips is found to be an unreacted thermitic material and highly energetic.
Keywords: Scanning electron microscopy, X-ray energy dispersive spectroscopy, Differential scanning calorimetry, DSC
analysis, World Trade Center, WTC dust, 9/11, Iron-rich microspheres, Thermite, Super-thermite, Energetic nanocomposites,
Nano-thermite.Last edited by Aaron; 02-11-2011, 09:25 AM.Sincerely,
RPX & MWO http://vril.io
Originally posted by aljhoa View PostStraight from the horse's mouth
YouTube - U.S. Government lies about molten steel found at Ground Zero after 9/11
Al
Jet A-1 Jet A
Autoignition temperature 210 °C (410 °F)
Freezing point < −47 °C (−52.6 °F) < −40 °C (−40 °F)
Open air burning temperatures 287.5 °C (549.5 °F)
Density at 15 °C (59 °F) 0.775 kg/L to 0.840 kg/L
Specific energy > 42.80 MJ/kg
Jet fuel - Wikipedia, the free encyclopedia
Thermal properties
The properties of steel vary widely, depending on its alloying elements.
The austenizing temperature, the temperature where a steel transforms to an austenite crystal structure, for steel starts at 900°C for pure iron, then, as more carbon is added, the temperature falls to a minimum 724°C for eutectic steel (steel with only .83% by weight of carbon in it). As 2.1% carbon (by mass) is approached, the austenizing temperature climbs back up, to 1130°C. Similarly, the melting point of steel changes based on the alloy.
The lowest temperature at which a plain carbon steel can begin to melt, its solidus, is 1130 °C. Steel never turns into a liquid below this temperature. Pure Iron ('Steel' with 0% Carbon) starts to melt at 1492 °C (2720 °F), and is completely liquid upon reaching 1539 °C (2802 °F). Steel with 2.1% Carbon by weight begins melting at 1130 °C (2066 °F), and is completely molten upon reaching 1315 °C (2400 °F). 'Steel' with more than 2.1% Carbon is no longer Steel, but is known as Cast iron.[2]
Structural steel - Wikipedia, the free encyclopedia
YouTube - Huge Plane Crash Fireball!
What was fireball duration?
Is structural steel fireproofed?
What melted structural steel?
Al
Now after knowing that, is it posssible to walk in a building within minutes or hours and have it come down perfectly? no. You need months of careful planning. Like where you need to cut the beams, where the explosives need to be put.
EDIT: here is the link to youtube YouTube - WTC 7 - Pull It By Larry Silverstein
so imagine this is one of your post, holding the building
iimagine putting a stick of explosive where the 2 diagonal lines are. When exploded at the same time it will result in pusing the beam, then collapsing on each other.
Some ppl took pictures of the WTC cleanup, and found LOTS of metal peices and molten metal orund the edge of the beam, but for some reaon this beam was still stck in the ground, whice leads me to beleive it was cut, inserted with explosive, and detonated.
The speed the towers fell, defies the laws of gravity.
i could go on and on and on and on. but like many ppl out there. some really need to see the TRUTH.
Edit: here is a video of a building that burnt for nearly 20 hrs..... and look at it, did it melt? YouTube - The Windsor Tower in Madrid SpainLast edited by duke; 02-13-2011, 02:08 PM.
The 9/11 Commission Rejects own Report as Based on Government Lies
Sep-11-2009 23:46 The 9/11 Commission Rejects own Report as Based on Government Lies
Gordon Duff Salem-News.com
How long have we watered the Tree of Deceit with the blood of patriots?
John Farmer’s book: “The Ground Truth: The Story Behind America’s Defense on 9/11″
(CINCINNATI, Ohio) - In John Farmer’s book: “The Ground Truth: The Story Behind America’s Defense on 9/11″, the author builds the inescapably convincing case that the official version... is almost entirely untrue...
The 9/11 Commission now tells us that the official version of 9/11 was based on false testimony and documents and is almost entirely untrue. The details of this massive cover-up are carefully outlined in a book by John Farmer, who was the Senior Counsel for the 9/11 Commission.
Farmer, Dean of Rutger Universities' School of Law and former Attorney General of New Jersey, was responsible for drafting the original flawed 9/11 report.
Does Farmer have cooperation and agreement from other members of the Commission? Yes. Did they say Bush ordered 9/11? No.
Do they say that the 9/11 Commission was lied to by the FBI, CIA, Whitehouse and NORAD? Yes. Is there full documentary proof of this? Yes.
Farmer states...“at some level of the government, at some point in time…there was an agreement not to tell the truth about what happened... I was shocked at how different the truth was from the way it was described …. The [Norad air defense] tapes told a radically different story from what had been told to us and the public for two years. This is not spin.”
The 9/11 Commission head, Thomas Kean, was the Republican governor of New Jersey. He had the following to say... “We to this day don’t know why NORAD [the North American Aerospace Command] told us what they told us, it was just so far from the truth. . . " When Bush's own handpicked commission failed to go along with the cover up and requested a criminal investigation, why was nothing done?
9/11 Commission member and former US Senator, Bob Kerrey, says, "No one is more qualified to write the definitive book about the tragedy of 9/11 than John Farmer. Fortunately, he has done so. Even more fortunately the language is clear, alive and instructive for anyone who wants to make certain this never happens again."
With the only "official" 9/11 report now totally false, where do we go from here? Who is hurt by these lies? The families of the victims of 9/11 have fought, for years, to get to the truth. For years, our government has hidden behind lies and secrecy to deny them closure.
Whole article here:
The 9/11 Commission Rejects own Report as Based on Government Lies - Salem-News.Com
I knew about this but thinking about it. The entire deal here could be
misinformation planned long in advance.
One that proves the official story is bunk by the very officials that
proclaimed it as true in the beginning. Then at a later time to proclaim
it was based on a lie but not revealing what actually happened. A
damage control one that lets people believe that their report of the truth
is what really happened so that many people will not buy into anything
deeper like Bush's possible involvement, etc...
Basically a fake expose that reveals enough of a lie to show there was
a lie and this is the truth to prevent a deeper truth from ever being
questioned.Sincerely,
Göring spoke about war and extreme nationalism to Captain Gilbert, as recorded in Gilbert's Nuremberg Diary:
Naturally, the common people don't want war; neither in Russia nor in England nor in America, nor for that matter in Germany. That is understood. But, after all, it is the leaders of the country who determine the policy and it is always a simple matter to drag the people along, whether it is a democracy or a fascist dictatorship or a Parliament or a Communist dictatorship. ...voice or no voice, the people can always be brought to the bidding of the leaders. That is easy. All you have to do is to tell them they are being attacked, and denounce the pacifists for lack of patriotism and exposing the country to danger. It works the same way in any country.[44]
Hermann Göring - Wikipedia, the free encyclopedia
http://i187.photobucket.com/albums/x...flag091201.jpg
AlAttached Files
follow the money
puppets like rumsfled,bush,chiany are not the ones to blame its the ones that made money from this 9/11 night mare. the fed reserve and who runs it should be looked at and arms contracters , these guys just the few have almost all the wealth of the world are the ones to look at.these guys have the most to gain.follow the money and you have the night mare in your hands.then you can charge them and have them put in prison.
cheers
Here is a set of experiments that demonstrate that thermite can indeed cut through vertical steel beams, as Prof. Jones and other scientists have said.
I like experimental proofs like this.
(The experimenter demonstrates courage to work with this stuff... Jon Cole)
YouTube - Proof that Thermite can cut a vertical column
48 Millionaires on the 4 Flights of 9/11 and STILL counting!
Was there a New Identity Program, which was being sold to rich people who were part of the syndicate, who then played the role of 9/11 Passengers?
By Phil Jayhan
http://letsrollforums.com/48-million...ts-t20579.html
Very few people ever discuss the gold which was missing from the sub-basements of the WTC.
And the trillions of missing cash with the paper evidence in the very room which was destroyed in the pentagon.
Cut through the illusion and connect the dots.....home run.
{Name of the program which allows remote piloting of these planes}
