I’m getting 120 volts on my outlet and my outlet tester says things are wired correctly . Could the problem be at the neutral on the transformer pole? I read online that could be a problem on the power companies end
Lights get brighter then burn out when I run my table saw
After I spent 40hrs checking all the wiring I did some internet research. A person with similar problem would turn on a microwave and it would burn the light bulbs out. The problem turned out to be on the power companies end I told them they possibly had a bad neutral at the pole at the transformer. Next day I noticed they cut some limbs touching the line... I went inside and power is workin perfectly fine helllll yeah thank god
Originally posted by johnnyfalcon View PostAfter I spent 40hrs checking all the wiring I did some internet research. A person with similar problem would turn on a microwave and it would burn the light bulbs out. The problem turned out to be on the power companies end I told them they possibly had a bad neutral at the pole at the transformer. Next day I noticed they cut some limbs touching the line... I went inside and power is workin perfectly fine helllll yeah thank god
