radient energy for an integrated circuit. NEW!
  • radient energy for an integrated circuit. NEW!
    Here's the real information about oscillatory circuits.5 years research showed me most of the accepted free energy devices today are based on a phenomenon Tesla discovered when DC was overlaid with AC current.Imagine an I-pad without having to charge! The phenomenon as Tesla described does away with the clumbsiness of stators , brushes and rotors and achieves very fast high frequency pulses. He described it in his conversion patent.
    Tesla Patent 462,418 - Method of and Apparatus for Electrical Conversion and Distribution.
    Any electronics genius out there please look!
    As I understand it he broke the natural inhibiting factors between DC and AC with his system.
    Moray used vacuum tubes to light a bank of lights. Tesla used similar to run a car without petrol ( The Pierce Arrow car)The vacuum tube became the improved valve , became the transistor , became the microchip , became the integrated circuit.The on/off energy signals (digital - computor calculator) and analogue signals back / forth ( TV). On/ off could be said to be the DC signals and back and forth the AC signals.
    Where is the genius that can adapt Teslas overlay of the 2 types of signals to get the fast oscillatory wave and hence the improved and recycled energy on an integrated circuit.Simply put you need a generator , conversion electronics and a battery.To pulse the extra energy back around the circuit.
    Somebody Nov 2009 discovered how to utilize this fast natural oscillatory wave from Teslas simple system using electronics.Watkykjy. He is recharging the battery for his child's ride on car every day from this system. He is retreiving the findings of Bob Boyce who is dying of cancer.
    YouTube - Battery charging with the hex controller (4 of 4)
    Over Unity Physicists and Applications - a history lesson Free energy devices explained using high frequency Tesla phenomenon.
    YouTube - Steven Mark TPU Replica - OU Ring light from freestanding toroidal transformer and electronics in the middle.
    Don't miss this post.Where is the genius who has studied the past and can realize this potential?
    Cheers. Roz.
    Help!!!
    Dear roz1
    Can u please let me know some source of info on Bob's Controller circuit, the ones he revealed to the public Unfortunately getting a membership to his group not possible at the moment for me? I want to know more about the concept of overlying AC and DC for making very sharp impulses those have fast rise and fall time I need some references other than Tesla patent.
    Many Many thanks in advance
      I really like that concept as reported by Sterling Allen at Peswiki (unfortunately, this is still our only source for info on this circuit so far, at least that i am aware of.. other than a few mentions in the Hydroxy Yahoo group, which are not telling us anything more really).
      He is using 8 FETs interleaved, to get the most possible fast rise times and short Duty Cycle pulses on one signal that has good wattage ouput... Besides the 8 FET's each generating a pulse, apparently he is also cleverly using Phase to get 8 more.. All summed to one F output; in this case apparently going to a "battery charger" according to the guy in South Africa; but originally designed to power one of Mr. Boyce's hydroxy cells that was claimed to provide the highest gas output of all his designs.
      It would appear to be, by far, the best example of a high F, relatively high wattage pulse train generator that we have seen yet, i believe.
      And controlled by PIC (programmed and controlled via PC): This is something we as a genre will eventually have to master, i think... However once we do, many things should be possible that were not before, and general circuit reliability and ease of minor design changes should improve as well... Making it easier for others to replicate precisely when used in an Open Source design (...as this IS NOT).
      As long as fast, unipolar pulses continue to be considered one of the best "roads" to achieving FE, this general circuit design should prove useful for many different techs and approaches.
        Thanks!
        Thanks jibbguy for introducing me on this but I thinking on concept. What is the concept behind overlying AC on DC? Why doing so cause in sharp pulses
        Tesla mentioned that he could generate such sharp pulses but I did not find out how?! Any document or reference on such phenomena exist?
        Many thanks again
          In Bob Boyce interview, he mention that then when mixing the AC with the DC, the resulted signal must still have on polarity offset. between 5V to 12V for instance.
          The AC part is benefically consist of multiple frequency. Bob Boyce use three octave at once.
            I can answer this im the genuis with string theory
            First off ac and dc are the same thing
            just experianced different the ground the rock
            is your frame of your car there is no negative
            energy its a illusion
            look the frequency of magenta is 144,000
            the black key between e and f not on the piano
            and also black and white color
            so understanding theres no negative energy takes setting aside your
            regular understanding of electricity and listening
            magenta is red blue
            so its always powers of red blue
            so you have ice blue red flame blue torce
            blue red blue red blue
            negative energy is a illusion of a broken loop
            when the loops complete there is no negative
            only positive because green is your third primary color and can oly exit in water by bending light remove water all green goes away
            chlorophyl to brown which is your true color.
            Feel free to email me im shure i lost 95%
            of you ch@record7.com
