The driver shot jfk with a handgun, likely a 38 service revolver fired from 6-8 feet in front of the President. The violent thrashing backward was caused by the close range shot. That is McClelland's drawing of the exit wound.
John F. Kennedy Assassination Homepage :: Warren Commission :: Hearings :: Volume VI :: Page 38
This testimony and evidence leaves no doubt about Greer's close range shot with a high velocity handgun. This silly interviewer quickly changes the subject after cerebellum falling out is brought to light.
Dr. Mcclelland. I think even then you could make the statement that this wound could have resulted from this type bullet fired through this particular mass of soft tissue, losing that much velocity before it exited from the body. Where you would expect to see this really great hole that is left behind would be, for instance, from a very high velocity missile fired at close range with a heavy caliber bullet, such as a .45 pistol fired at close range, which would make a small entrance hole, relatively, and particularly if it entered some portion of the anatomy such as the head, where there was a sudden change in density from the brain to the skull cavity, as it entered. As it left the body, it would still have a great deal of force behind it and would blow up a large segment of tissue as it exited.
But I don't think the bullet of this nature fired from that distance and going through this large area of homogenous soft tissue would necessarily make the usual kind of exit wound like I just described, with a close range high velocity heavy caliber bullet. This is why it would be difficult to say with certainty as has been implied in some newspaper articles that quoted me, that you could tell for sure that this was an entrance or an exit wound. I think this was blown up a good deal.
"Handgun used"
2. Dr. Charles Wilbur: Dr. Charles Wilber concluded after reviewing the notes made by surgeons at Parkland Hospital, that they suggested that the head wound was made by a hand gun fired at close range.
Amazon.com: Customer Discussions: U.S. Secret Service involvement in the JFK assassination
6. A.J. Millican: “It sounded like a .45 automatic, or a high-powered rifle.” <19WCH486>
7. S.M. Holland: “It would be like you’re firing a .38 pistol right beside a shotgun, or a .45 right beside a shotgun.”
Testimony Of Dr. Robert Nelson Mcclelland
THE EXIT WOUND EXTENDED TO THE BOTTOM OF THE OCCIPITAL BONE. The force of the bullet pushed up the top of the head, but the bullet exited the right rear, as has been factual for many decades. That is McCLELLAND'S drawing of the rear blow-out. https://www.google.com/search?q=dr+m...w=1536&bih=748
Mr. SPECTER - Before proceeding to describe what you did in connection with the tracheostomy, will you more fully describe your observation with respect to the head wound?
Dr. McCLELLAND - As I took the position at the head of the table that I have already described, to help out with the tracheotomy, I was in such a position that I could very closely examine the head wound, and I noted that the right posterior portion of the skull had been extremely blasted. It had been shattered, apparently, by the force of the shot so that the parietal bone was protruded up through the scalp and seemed to be fractured almost along its right posterior half, as well as some of the occipital bone being fractured in its lateral haft, and this sprung open the bones that I mentioned in such a way that you could actually look down into the skull cavity itself and see that probably a third or so, at least, of the brain tissue, posterior cerebral tissue and some of the cerebellar tissue had been blasted out. There was a large amount of bleeding which was occurring mainly from the large venous channels in the skull which had been blasted open.
https://www.youtube.com/watch?v=6Q1lYifmUXA
The driver, Bill Greer shooting jfk is not an opinion, theory, conspiracy theory, or a possibility. It is an obvious fact that was finally acknowledged by myself, and ignored by literally hundreds of conspiracy kooks for the last 50 years.
"Handgun used"
5. Parkland Dr. McClelland's testimony as reproduced in Hearings volume 6, p.38: "Dr. McClelland judged that the wound in the President's skull could be expected '…from a very high velocity missile…with a heavy calibre bullet, such as a .45 pistol fired at close range…' This would particularly apply to the skull '…where there was a sudden change in density from the brain to the skull cavity, as it entered. As it left the body, it would still have a great deal of force behind it and would blow up a large segment of tissue as it exited.'"
"Handgun used"
"Handgun used"
