Ice Age Model years of work went into this. I hope you find it of interest.
2012: External Net Force Torque, Precession - YouTube
This model in its physical form, and character was made with great care to include all know probability in its most simple of form.
The establishment of the most probable of all the inputs i include for this simple model.
A warning this is a very unconventional theory, it only came to light recently, and is related to my special study's.
This will include research I have done in order to make global climate change theory possible to every reader.
I have determined a need to account for the recent flurry of questions about ice ages, and Global warming.
The information I will include will have as many Facts as possible for this very simple Ice age theory.
Background information, define ice age.
A change in climate were the northern pole, southern pole, or both begin to experience a build up of ice sheet, or snow cap for an unidentified period of time.
This can relate to mini Ice age definition as well. The best I can do is relate this to observation.
'The "wiki"- definition An ice age or, more precisely, glacial age, is a generic geological period of long-term reduction in the temperature of the Earth's surface and atmosphere, resulting in the presence or expansion of continental ice sheets, polar ice sheets, and alpine glaciers.'
The wiki definition is also speculative. It considered an ice age as a long term scenario. I simply excluded that premise.
The basics . Q: When we describe a system effected by change, how do you determine, and go about explaining these changes in a scientific manner?
Include, and determine the state of changes occurring in the system leading to a functional physical working model.
My question was used to determine these factors.
The methodology, I had used the axiom assuming all is true. I picked it apart piece by piece, what is left are these observations, and determinable effects.
I had tested for a high degree of accuracy.
All statements used for explaining changes by categorizing the fundamental laws of nature.
Change was determined by cause, and effect including only what is not assumed, but instead what is widely known.
Factor that are less widely known are also included, and gives answers to questions current models lack.
by use of axiom assuming all statements are true, and then by testing it for truth.
by using well known principles, explaining a cause for a given effect.
by keeping it very simple, including self evident or well known principles.
by explaining other less known causes for a given effect.
Try to see this for what I show. I have a carpenters level. It has a bubble of air in the center. The level is used to show what side is up, and what side is down. The air bubble in the center shows equilibrium.
How can I use this in my model that this is so in the case of our planet? How will this predict when a possible ice age will occur?
let earths axis be the level plane, and if I stretched my level from north to south pole the bubble is in perfect equilibrium.. This be the implication, the earth has an up and down.
Obviously Earth is not in perfect equilibrium, when it comes to cold air finding its place among the cold air in our planet system.
We may then state the planet is not in perfect balance, and the bubble resides over the southern pole, rather then the equator. Do you agree?
How will that bubble then in fact shift from equilibrium? Not as hard as you may make it, but by a change in earth axial position. This would cause the bubble to shift.. do you agree?
We have a northern hemisphere, and a southern. If the coldest hemisphere be the southern, than because of Antarctica having a lower temperature then the north pole. This remains true.
Now I wish to cause all the cold air in the south to flow to the north. How can that be? A simple explanation.
A move in axis will prove a shift in bubble, and therefore equilibrium is now in the process of shift, and change. The observable factor, and start of the age. Prediction is important.
I have determined the Northern side now in a process of cold air shift. That shift will eventually find its equilibrium with the coldest air once again above the northern pole.
There are many circumstances that can be related to an ice age, long term, or short term.
One of these circumstances has to do with the earths temperature in relation to the evaporation rate of the oceans world wide.
More evaporation, more water vapor in the atmosphere, and not in the oceans. Predictions that self verify are important.
How can cloud cover effect the globe in relation to temperature rains, snow, oceanic currents, and airflow circulation in the system?
In the same manner volcanic gasses may block out the sun. In the same manner if a deep impact was to occur here on earth, by causing the solar rays to be reflected.
This could lead to a progressive ice age, as time passes world temperatures will fall at a faster rate, more so after the blocking of solar radiation.
Other factors included are also determined, and agree with current knowledge.
Such as gasses from volcanoes. this may block out the suns energy over time. I include the most understood factors, well known today by modern science.
Dust from either volcanoes, meteorite impacts, and the deforestation of the planet. To much air born material in the system.
Perhaps even a dust bowl world wide. leading to a colder climate due to less solar warmth reaching the earths surface.
Solar fluctuations, may lead to a cooling, or warming of earths surface. Both can lead to an ice age. I can agree with that.
Location of equilibrium, or a change in Earth Axial position can lead to a warming, and cooling in one hemisphere over the other.
Non equilibrium. The teeter totter perspective. Similar is the function of a see-saw.
Factors included seem to answer all of the possible circumstances related to ice age periods.
Premiss.
By a change in Axial position, or equilibrium of Earth system in relationship to said galactic plain. I can reflect this change in several ways.
1. By a change in location, and, or position of a body in relation to said plain. A body such as the Earth may experience diverse effects. Including magnetic anomaly, including a change in air flow direction, or temperature within the given system. assuming it has an atmosphere.
2. A change in Earth axis position, to whatever degree may have diverse effects on the inner system, or atmosphere of said body.
This In relation to its present equilibrium, and its magnetic alignments to the stars.. The rotation of the given body, or its angular momentum can make predictable statements. Self verified today.
3. Ice age By volcanic emissions alone, or in conjunction with a change in equilibrium of a system. In relation to its orbit, axial position, and speed of rotation. May also lead to an ice age. Extremely non intuitive.
4 A large meteor impact may lead to an ice age, by the blocking of solar rays reaching the Earths surface.
All statements are true statements.. Yes or no? I have determined this is accurate.
How many of these effects mentioned have taken place today, and when did the first ideas develop?
1. For the axial shift, and bubble, yes there was 2 separate events in the last 2 years. the axis has shifted a total of 7 inches.
2. more then 30 volcanoes have erupted, and continue to erupt in the last 18 months.
fact. If you want to see the numbers of how much dust and ash have been sent hurling into the atmosphere. (quantity of gaseous material).
3. Water vapor level of our atmosphere is quickly increasing. Storms with high wind speed reflect these relations in the given way. A change in angular momentum, and velocity of rotation.
I will also post the numbers. water vapor, or steam is the number one volcanic gas expelled by volcanoes. Include estimated gaseous material over time.
4. There has not been a deep impact on earth by meteorite in a long time. This observation of cause for an ice age today is therefore is excluded from any cause as of today. No deep impact.
I only need to show you with pictures how the air in the system, has made a change in direction in the last 18 months. I show air flow from the southern hemisphere is moving to the northern.
The proper term is arctic, tropical, continental flow. Crossing boundary lines.
5. Solar fluctuation, again this is present in this model. Solar energy is a given, and may decrease, or increase over time.. We now are in the 24 solar cycle, and it has produced heating fluctuation on Earth also.
The sun has also produced many solar flare extremes during this event. 24th solar cycle started in 2010. All info can be found on the net about the problems of solar cycle 24. I can provide much more data. Make your own determinations on these conditions. Solar energy, angular momentum, volcanic eruptions, meteor impact, increase in gaseous materials , and dust in the system, axial shift, Etc..
Oceans reflect the immediate changes, and therefore determined a leveling off period is also is progressive.
All these effects are ongoing, and observable.
The self verified Factor: solar anomalous, volcanic eruption on a large scale, tilt in axial position, Earth magnetic field anomalous, a change in direction of air circulation, and oceanic tides moving to the north.
The model is simple, and works very well for prediction. Excluding all global warming BS mainstream claims.
According to this model are we closing in on an ice age?
Has all causing factors been reflected upon enough to make a determination? If we stick to known causes only. It definitely closely agrees.
Ice age cause, simple verifying model.
See the movies I have made. Immediate determinations based on observation of the globe over time. The first movie was just after the Great chili quake. After the axis has shifted 3 inches.
Pleas pause this movie at 31 seconds, do you see what I do? Intuitive of scientific validating factors. The intimidate change is a constant in determining a cause. There is a massive drip, or a drip of cold air moving toward the equator. Looks like a change in equilibrium in the Earth system. This is the bubble I have reflected. Some may say this is a wobble, some may say indeterminable. Further scientific observation does not agree with the given notion..
Premiss.
