I was in a daze for about ten minutes the last time I went to the groecery store and saw liquid milk on the shelf that does not require refridgeration.
How in the world?
Even more shocking, it is organic milk.
I just called the company and they verified it. But they said after you put the product in the fridge, you must keep it there or it will go bad.
I has something do with the way it is packaged and the lining in the packaging.
Here is an explaniation from their web site:
How are your Single Serve Milks packaged?
Single serve milks are packaged in aseptic tetrapaks and unopened will keep at room temperature up to seven months or until the date code. The milk is pasteurized using UHT or ultra-high temperature process which is similar to UP or ultra-pasteurization, in which the milk is heated to >280° F for 2-3 seconds, but packaged in a sterile environment thus extending its shelf life. The package itself is durable, lightweight, convenient for transport, and uses low energy and few materials. It is recyclable at any local program that accepts aseptic packages.
How are you Single Serve Milks pasteurized?
The milk is pasteurized using UHT or ultra-high temperature which is the same as ultra-pasteurization (or UP) in which the milk is heated to >280° F for 2-3 seconds. This pasteurization process coupled with the aseptic packaging extends the shelf life of the milk and allows it to be stored at room temperature. You can find the "UHT" symbol on the back panel in the upper right corner underneath the straw.
Things that make you go "hmmmmmmm."
XO Jessica
How in the world?
XO Jessica
