Hi All,
I usually hangout in alternative energy section and I wanted to post this there but thought it really should be under health.
If anyone who is familiar with Royal Raymond Rife there seems to have been a breakthrough in the past few weeks.
For years people have thought that the Beamray machine built by Hoyland/Rife worked on a fixed carrier and an audio frequency but now new research has uncovered that what was once thought to be a lower variable frequency turns out not to be lower but Higher!
www.rife.org You need to click on the PDF file on this page: "A History of Rife’s Instruments and Frequencies"
and Look under the "1936-39 Beam Ray Corporation instrument" It is the best article on rife technology on th web.
1936 to 1939 Beam Rays heterodyned frequencies
Actinomycosis (Streptothrix) 4,680,000 and 4,488,000 = 192,000
Anthrax
4,680,000 & 4,540,800 = 139,200
B. Coli (Rod form)
4,680,000 & 4,263,000 = 417,000
B. Coli (Filterable virus)
4,680,000 & 3,910,000 = 770,000
Bacillus X or BX (Cancer carcinoma & sarcoma)
4,680,000 & 3,076,000 = 1,604,000
Gonorrhea
4,680,000 & 4,44,7000 = 233,000
Spinal Meningitis
4,680,000 & 4,253,000 = 427,000
Staphylococcus Pyogenes Aureus
4,680,000 & 4,202,000 = 478,000
Staphylococcus Pyogenes Albus 4,680,000 & 4,130,930 = 549,070
Streptococcus Pyogenes
4,680,000 & 3,960,000 = 720,000
Syphilis
4,680,000 & 3,891,000 = 789,000
Tetanus
4,680,000 & 4,446,000 = 234,000
Tuberculosis (Rod) 4,680,000 & 4,311,000 = 369,000
Typhoid Fever (Rod form) 4,680,000 & 3,920,000 = 760,000
Typhoid Fever (Filter passing) 4,680,000 & 3,235,000 = 1,445,000
As You can see from above Hoyland was using two MHz Radio Frequencies and mixing them in the Rife tubes. Mixing the two frequencies will give you a plus and minus in the mixed wave. The minus frequencies are the frequencies that most people are familiar with and try to use. I'm not so sure of the plus frequencies but it seems Hoyland was a tricky fellow and hide the possibility of the second high frequencies (ie. MHz).
Of course if one did this experiment they would be introuble with the FCC but this looks like the final piece of the puzzle!!
Just had to share this with some
one
Anthrax
B. Coli (Rod form)
Gonorrhea
Spinal Meningitis
Syphilis
Tetanus
