MMS - Miracle Mineral Solution - Another cure for AIDS, Cancer, Viruses, Malaria
  • #61
    Recently at a Project Camelot show in Belgium, there was a German guy who spoke there about MMS... Havn't seen that one posted there yet (i watched the live cam at the time, but didn't catch his name or site).
    My own "Clinical Trials" with MMS are going quite well. I changed to using capsules because one day i was violently sick for about 12 hours and since then the taste is too much to contemplate What i vomited that day was scary: Some of it was a black mass of who-knows-what, lol. It freaked me out. I cut back after that and went to the "more often / fewer drops" approach that Jim describes on his site as the "new and improved method"... Also using the "take a 2-day break after 2 weeks" advice to replenish vitamins and minerals, and intestinal "good" flora.
    When using the capsules, make sure they remain dry (put cotton balls in the container or they could soon stick together and be worthless quickly if you live in a humid climate), and pop them into your mouth & swallow them as soon as you make them up (they soften and break quickly). They are not sold in most pharmacies, and may have to be ordered... Many chain drug stores won't carry them at all, the best bet is to go to an small "old school" pharmacy that are often located in medical arts office buildings, where they still compound medicines. I got 500 type 0's for $16 .
    So far i have lost several warts or smooth-skin growths on my back, they just shrank away over a couple weeks, and the psoriasis i've had for years has been just about licked and has gone down to near unnoticed levels, some lessening can be seen every day. Using direct application to the skin helped there too. Havn't tried the bath method yet, that's next.
    I've also noticed that an allergy i had to something that grows in the mangrove's has apparently gone away too... Whenever the wind blew from a certain direction from the mangrove swamps, i used to sneeze and water for an hour or two, but not now.
    MMS appears to be a winner, at least for me
    • #62
      Very good news I still wonder what could case your stomach to react so violently and color of discharge Did you ever had ulcers?
      Vtech
      General D.Eisenhower
      http://www.nvtronics.org
      • #63
        Originally posted by BobBrown View Post
        Hello all !
        I'm up to 6 drops after 2 days, seems harder to schedual things around my timetable then I thought. Not meny side effects, mainly stomach queezyness and flatulance. And the taste ? !#@!$!@%!@%)!$*^)^@) MM MM Good
        Fist thing I do notice, my mouth is cleaner. I swiril and gargle before swallowing, and there is a definatle positive effect on cleanlyness there.
        Oh ya, i don't have a 10 % solution of vinigar, so I'm using a 5 % solution, and letting it rest for 6 minutes instead of 3 minutes, to compensate.
        Andrew T
        PATHS ~ Mind Energetics
        For out health ! For our future !!
        Andrew, I would use 3 min. activation time, regardless of acid strength.IMO
        Vtech
        • #64
          @Black: Nope, always had a strong stomach. There have been similar anecdotes from people, Jim says that is the result of a major killing off of pathogens or some kind; although why it would manifest itself in the stomach and not the G.I. tract (which it also did that day lol), i dunno either. My dose that day was 12 drops and i had that much previously without the bad reaction.
          BTW: I heard in the Belgium PC talk that if someone does have a history of ulcers, DO NOT use the citric acid for the actifier. Use the lemon juice or apple cider vinegar. The citric acid could weaken stomach walls over time if yer sensitive to it.
          The thing about vitiman C is that natural C is not as bad in reaction to the MMS as the manufactured C that is added to many drinks... He says if your juice does have some natural vitamin C (like lemon or lime juice) then just use 1 more drop of MMS.
          • #65
            Swirl, gargle and spit
            last edit....
            • #66
              Mms2
              last edit....
              • #67
                Originally posted by jibbguy View Post
                @Black: Nope, always had a strong stomach. There have been similar anecdotes from people, Jim says that is the result of a major killing off of pathogens or some kind; although why it would manifest itself in the stomach and not the G.I. tract (which it also did that day lol), i dunno either. My dose that day was 12 drops and i had that much previously without the bad reaction. Logical, but would love to hear JH opinion on this.
                BTW: I heard in the Belgium PC talk that if someone does have a history of ulcers, DO NOT use the citric acid for the actifier. Use the lemon juice or apple cider vinegar. The citric acid could weaken stomach walls over time if yer sensitive to it. Makes perfect sense
                The thing about vitamin C is that natural C is not as bad in reaction to the MMS as the manufactured C that is added to many drinks... He says if your juice does have some natural vitamin C (like lemon or lime juice) then just use 1 more drop of MMS.
                I agree with that. I always look for pure juices without added vitamins, like apple or prune. Label may look confusing, since there is always vitamin C present, but it's natural. They usually advertise any additives.
                Thank you for your comment
                Vtech
                • #68
                  Originally posted by chasson321 View Post
                  Bob, when I first started to use MMS I would also swirl and gargle before swallowing. However, I figured that it is probably better to spit out the mouth wash than to have all the killed pathogens pass through the entire digestive system. Your garbage men won't have to work as hard taking out the other trash.
                  Rinse out your mouth and spit, then you can make some fesh and swallow that. Just a suggestion.
                  I agree with your statement. I would treat mouth separately and use a "fresh" dose internally
                  • #69
                    Bad Reactions
                    last edit....
                    • #70
                      An MMS alternative
                      Not necessary to get ill.
                      Try this instead.
                      It is Ph balanced.
                      The Official Supplement Store of Dr. William Wong, ND, PhD
                      Stabilized Oxygen
                      You will get the same benefit.
                      Love and Blessings,
                      DeAnn
                      Dr. DeAnn Upton, A.M.P.
                      My PATHS Affiliate Website
                      • #71
                        MMS Alternative
                        last edit....
                        • #72
                          I just had a pleasure to get in touch with Jim Humble. I was able to clarify that MMS2 is no better than MMS1 and they both work a bit different. MMS1 should be used as a primary and combined with MMS2 as needed.
                          Also found out that one Canadian (BC) supplier of MMS1 cannot sell to Canadian customers anymore, due to the recent "decision" made by Health Canada, that MMS is a drug!
                          Vtech
                          • #73
                            Sodium chlorate?
                            lsat edit....
                            • #74
                              There is a Newsletter #7 @ Jim's site. Very good reading!
                              Vtech
                              • #75
                                That's great info, and as soon as MMS' effectiveness becomes well-known, there is no question in my mind that it will become illegal to sell in the U.S. also. It's too effective, it would cost Big Pharma billions in profits.
                                These ..um.. "people" at the FDA are so corrupt and evil at heart, they will stop at nothing. Soon it will be illegal to sell ANY herbal or alternative medicine (as this recent bogus "Medical State of Emergency" in the U.S. has shown). they are indeed becoming very bold.
                                What about this product for "shock cleaning" swimming pools that is supposed to be sodium chlorite, does anyone know anything about that? I bet it would be cheap, and a 5-gal container would last for 20 years; or be enough to cure hundreds of thousands of people. NOW would be the time to buy some.
