I may be missing something in my Red LED Christmas light set up if 292 frequency is the part that helps with healing. I also play the healing 528 Solefeggio frequency while using the red light board. Anyway, I don't have a lot of knowledge in using a freqency generator so, what's my next step for my panel in order to get the full benefits?
Red Led Light Therapy
Originally posted by rhozzi View PostI may be missing something in my Red LED Christmas light set up if 292 frequency is the part that helps with healing. I also play the healing 528 Solefeggio frequency while using the red light board. Anyway, I don't have a lot of knowledge in using a freqency generator so, what's my next step for my panel in order to get the full benefits?
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
I have a book from the library on the healing power of light and it list different colors (not just red and blue) that have healing influence on the body...such as yellow, orange, green, violet and indigo. Has anyone tried the different colors and had results? Has anyone had long lasting results with the red or blue. I thought of buying the blue light panel but found a site that list side effects for some people using blue light therpy and decided not to try that one. Perhaps a less intence form of blue light would work better, with no negative side effects? Just thinking outloud because blue is very calming.
color therapy
Rozzi,
Dinshah probably has the best material on all the multi color light therapy.
However, from what I've seen, red and infrared alone has accomplished every benefit of all the colored light therapy. The exception is in altering the mood, which multi colors do have benefits there that the red/infrared don't.Sincerely,
RPX & MWO http://vril.io
My only concern for any suggestions that encourage adapting panels for pulse activity is the safety aspect. While experienced electronic engineers and hobbyist will be aware of working with direct AC high voltage circuits, novice experimenters may not be aware of possible dangers. For any panels or LED clusters working from low voltage adapters which offer supply line isolation can be modified easily. For none isolated AC configurations; then extreme caution must be observed…seek professional advice first before attempting to modify an electrical product.
I can recommend a semiconductor device I have used on several occasions for switching LED’s and other low voltage circuits. BSP452 is ideal as it can be switched directly from logic output devices including 555 timers and micro controllers. This device can be inserted directly in series with the light strings positive source voltage (check data sheets first before use)
Originally posted by rhozzi View PostJust curious...Has anyone done the red light therapy with any positive results? I used the red light panel for almost 2 months from 15-40 minutes per day and so far with no notable results.
I'm still working on portable unit with all seven frequencies. Please visit Energy Science Forum - Electronic Healing Technologies - Red Light Therapy for details.
red light therapy
Is the red light steady or pulsed?
And can you share the exact benefit you're trying to gain?Sincerely,
I used the deep red light panel that can be found at ledwholesale. I thought I read that a deeper red would be beneficial, even without the pulsing. I stopped using my christmas light panel with the 2 blinking red lights I had put together once I received the professionally made panel. (It does not pulse that I know of).
I want to see clearly again (disease-macular degeneration) and get rid of a sore on my temple that has not gone away in 3-4 years. I keep it under control with bag balm and some times use tumeric (tumeric can kill tumors).
Originally posted by rhozzi View PostI used the deep red light panel that can be found at ledwholesale. I thought I read that a deeper red would be beneficial, even without the pulsing. I stopped using my christmas light panel with the 2 blinking red lights I had put together once I received the professionally made panel. (It does not pulse that I know of).
Our associate's mother was in her 80's and had severely advanced macular degeneration. She stopped going out, stopped going to Church, etc... she couldn't even make out people's faces anymore.
3 times a day, she would shine the red led's in her eyes for 10 minutes at a time pulsed at 292 times per second. In about 6 weeks, it had reversed enough where she could start making out faces and about 6 weeks after that, it had improved so much, she could could tell the difference in coins (pocket change) and was going back to church and going back out elsewhere. It had turned her life around.
The red LED's are much brighter these days. That was about 12 years ago or so. I wouldn't recommend doing that directly in the eye. What I do myself just for a good boost to the eyes is I close my eye lids and shine the led's right on them.
Anyway, that is the only experience I know of someone near me that received benefits for macular degeneration and red leds.Sincerely,
Thank you so much for those encouraging words. I haven't yet found a way that I can pulse my red light panel to 292. I don't know very much about electronics as some do that are on this forum. I've tried to find some kind of device I can plug into the wall and attach my panel to make it pulse. Hasn't happened yet. But, thank you again.
steady light
Rhozzi,
You can try it with steady light.
Please understand I'm not giving medical advice - I'm just sharing
my experience.Sincerely,
Originally posted by rhozzi View PostThank you so much for those encouraging words. I haven't yet found a way that I can pulse my red light panel to 292. I don't know very much about electronics as some do that are on this forum. I've tried to find some kind of device I can plug into the wall and attach my panel to make it pulse. Hasn't happened yet. But, thank you again.
I should have my device ready within a week or so. It will work with one/couple 30W or less LED panels as well as stylus pointer for small areas (point treatment). Circuit isn't complicated, even for a beginner and was intended to be that way, rather than using Arduino or other programmable microprocessors.
There is no need to complicate and confuse. I mainly post on Energy Science Forum> Electronic Healing Technologies due to the work load.
If you wish to have something build and need a hand I'll be happy to assist.
Below is one of my setups with 711 LED panel and (unfinished) control unit on the right. It will have all 7 frequencies available.
Vtech
