I try to post this saturday but failed.
That is interesting.
I once use magnet as fuel booster. When I start experimenting with cemenite as fuel booster, I found that the power increase more if I take out the magnet. I use three ceramic and one neo. The boosting power of one cemenite felt stronger than all 4 magnet.
I think you should remember that magnet produce influence not just from its polarity but from its material too. And Neo is toxic.
Also Neo field is strong. It is possible that when you are exposed by north field, you are actually also being exposed to the south field too. They do not cancel each other, so you may actually receive both kind.
Thank you for the link and explanation .
I think penta around diseased organ may not means the penta shape is the cause, it can also be the effect.
Do you know how Dr. Jhon observe water shape?
Interesting. I also observe many tiny bubble, but on water on room temperature. I wonder if that is a good or a bad sign.
BTW, I found that sometimes the water kept liquid after two days, when I tap it or touch the surface I see it froze later.
About north and south. I believe that while south can boost plant growth, excessive use will be bad. Some energizing power is good, too much can produce bad effect. There was actually research with plant, and boosting power should never be excessive or will produce opposite result.
Exposing plants to south should only be done in limited time. See this:
Robert A.Nelson: Hemp Husbandry ~ Electro-Culture (Ch 5)
I would only use energizing energy at work and use only calm energy at home. Less arguing in the house is a good thing .
