Is anyone else having problems logging into their theatre today?
  • Is anyone else having problems logging into their theatre today?
    I logged in over and over and it kept leading me to the same page that is www.paths-123.com page. Its not my error because I checked my username and password and its all correct so its the system. I emailed support just now, but thought to ask if anyone is having this problem today too. thanks all. valerie
    Hi Valerie - PATHS-123
    Hi Valerie, Welcome to PATHS!
    Code:
    http://www.paths-123.com
    is my personal PATHS affiliate site.
    If you are the same Valerie that recently started with PATHS, then PATHS-123 is the website you signed up on. After logging in, you will be able to watch your modules and the website should be PATHS-123.com even after logging in.
    But do you mean that when you log in you are redirected back to the homepage at
    Code:
    ? If so, that is a little odd.
    Please let me know and I'll find out what is happening.
      That also happens to me from time to time. It helps then to log out. Than you click on Home page on the left side and you can log in normally. That usually helps me, sometimes even that doesn't work, than I close the browser and do it all over again.
      Katja
        problem solved, thank you paths!!!
        HI,
        Paths is so quick to help. I appreciate the staff so much!!! Thank you! I tried logging in again last night and everything was fine, thanks guys!!!
        val
