Can I change my module?
  • Can I change my module?
    Question: I started with one module on Wednesday, and I've realised I should have started with a different one. I was wondering if it would be at all possible to swap the one I have (Business Productivity and Creativity) for the one I should really have started with (Self Esteem - Confidence Builder)? Or do I have to wait a month before I can swap?
    Answer: During the first month you can change your modules as much as you need to, to get them fined tuned to what is best for you.
    After the first month you many change any of your modules a maximum of one time per month.
    Simply email info@paths-vx.com the following information:
    first and last name
    what module(s) you want to end
    what module(s) you want to start
    Energetic Forum Administrator
    http://www.energeticforum.com
    first and last name
    Does this mean during the first month on each module you may change it as much as is needed, and not during the first month on PATHS?
    Terry
      Hi Terry ~
      After the first month, you can change out any or all of your modules once per month, every month
      Namaste,
      Pamela
      Discover the Single Greatest Health Science Breakthrough of the Century
        Originally posted by Pamela Vicik-Smith View Post
        Hi Terry ~
        So if I add another module can I change that module as many times as I want during the first month on it?
        Terry
          I guess you can. Was there one in particular you were thinking about?
          The problem with changing one module out several times in a month, is that you aren't giving any of them enough time to work.
          Namaste,
          Pamela
            Hi Pammie,
            No I'm not wanting to keep changing a particular module. Just wanted to be clear that I could do so, if I wished to do that.
            Terry
              Terry,
              PATHS needs to have some limit to the number of swap requests they can keep up with (in addition to the point of it not being best to swap without the module getting a chance to work).
              However, they are aces to work with and aim to please.
              If you are EVER having trouble with any module, no matter if you already did a swap that month, let them know.
              They will help as much as they can
              XO Jessica
              Keep your mind on the aether www.PathsToSucceed.com
                Bumping this up! And a reminder... You may change all of your Modules up to once a month. Also, to keep response time down, it helps to send all requests at the same time.
                Happiness & Health,
                PATHS, S.A. Staff
                PATHS
                  If I have four modules, does this mean that during the course of one month, I can only make one change (regardless of how many modules I decide to swap out), or can I swap module A one week, then module B the next, etc?
                    You can change ALL of your Modules up to once per month. It does not matter when during the month you do this, however, it helps to make changes together as this keeps the number of emails down, which equals a quicker response time.
                    Happiness & Health,
                    PATHS, S.A. Staff
                    PATHS
                      Bumping this up!
                      Happiness & Health,
                      PATHS, S.A. Staff
                      PATHS
                        Bumping again!
                        Happiness & Health,
                        PATHS, S.A. Staff
                        PATHS
                          Bumpity Bump!
                          Happiness & Health,
                          PATHS, S.A. Staff
                          PATHS
