Solar of course, with batteries for backup and a Grid Tie Inverter. Solar Panels (Light) and Solar Stirling Engine Generators (for heat, Dish like on your roof, made of mirror centering all the light / heat to the end of the piston of the Stirling..) - My Jeep Patriot should be a Hybrid, Electric first till 5% battery and then gas for longer trips with a solar panel on the hood to help recharge when outside during the day and the sun is shinning.
Electric motor is a generator used in reverse, which is merely coils of wiring spinning by magnets to generate electricity or magnets spinning by copper wiring like a bicycle wheel itself could be, magnets instead of the rubber passing by coils close by not touching it. Right now I have a Baldor Motor that I just need to mount and then chain it to the bicycle with the backwheel off and the motor in it's place.
Squirrel Wheel Generator
Squirrel project has pair of Mark Morris students spinning their wheels
I want a Giant wheel to spin inside like the Price is Right generating electricity like a wind turbine does, you can bike it to spin it as well when exercising. Just like you keep tapping the basketball to keep it spinning on your finger, you merely do the same as if you are the wind, maybe using piezoelectric devices of merely tapping the electricity to keep the magnetic flywheel moving or people walking around to keep it spinning. You just keep propelling it forward, like pressing the gas in the car or keep pressing it forward by pedaling.
I need a pedal and gearing in order to be the wind to keep the wheel spinning or generator moving. So we should be able to sit there watching tv pressing a pedal to keep a flywheel spinning or the turbine. I want to exercise or figure out the most efficient way to be the "wind" inside, doing as minimal work to generate electricity at the same time since I know perpetual motion isn't possible and nothing is free but willing to put the work in myself at home whenever possible (emergency backups, etc.)
https://www.youtube.com/watch?v=eAniA73C6WI (Preview)
https://www.youtube.com/watch?v=PvO8qA3rf3M
Gravity Power - like a grandfather clock, where all you have to do is lift the weight back up after it comes down.
Rain Barrells, one higher than the other to stimulate the down flow of water to place the water turbine in the middle and the individual can keep riffling the top barrel from the bottom.
I'm trying to create jobs - More of us should be seeking the production of this stuff, for an abundance of something equals the lower cost of it and it starts with sharing ideas or the knowledge
Copper Roller coaster with sphere magnet is a good idea, yet you are better off with spinning a flywheel real fast over and over versus letting a sphere go over and over down the track which as it loses speed it will limit production
A Scaled up crystal radio I'm sure will work, those operate without batteries, bigger the coil and antenna, more amps. I have a little one to understand the concept and build, seen someone on YouTube who scaled his larger than mine to light an LED instead of listening via the speaker like I'm doing with mine and I'm wondering if you scaled his up even more to light a larger bulb? using an antenna many households already have on their roof?
