Need help from sensitive persons in this forum!
  • #16
    Very interesting work.
    I just wanted to convey my experience with the photos and see if anyone else may have had any similar experiences like myself.
    It is strange as to why i am not so clear on feeling this today, but last week when i first viewed the photos of these devices, my immediate feeling with the very first pyramid (top most photo), was as if the air is clean, and in a way clear or fresh. I felt it very clearly. I am uncertain if i was picking up on other work happening around people working on that first pyramid, but that is what i experienced.
    What i did feel, and continue to perceive with the 3rd pyramid (counting from the top and moving down as one counts), is a sort of active, or dynamic energy that is more like presence of energy, rather than a movement of energy.
    • #17
      Athena, thank you for the link to that amulet shop, got some new ideas
      Our shop is now cleaned and repainted and we can start working again. As for selling these, we will be ready any time now.
      alsy,
      thank you for your observations, it helps a lot
      Here are some new stuff:
      These pyramids are used to clear the energy of the environment, energy can also become stuffed like air and such a pyramid works kinda like opening a window and letting fresh air in, only it works on energy. That pyramid that is in the third picture of my first post is used ļike an altar, it helps to focus when you meditate and eases your connection to your higher self and of course it boosts your energy
      Good day to you!
      • #18
        @Jetijs
        Amazing I hope you've got everything under control after the incident. What do you use to wind Rodin's coil on? It is transparent core but I wonder if this is something I could find around or it was custom made. I tried Mobius only but have a feeling of much stronger effect using Rodin's variations.
        Vtech
        General D.Eisenhower
        http://www.nvtronics.org
        • #19
          Hi Vtech
          It is really easy. We use two component silicon that dentists use to make molds of your teeth. We put a wooden toroid in it and let it cure. After that we carefully cut the toroid out and what is left is a nice silicon mold. We then use that mold to cast epoxy resin toroid rings. And those rings are then used to wind the Rodin coils. To make the winding process easier, we file grooves at right spaces around the perimeter of the toroid so that the windings doesn't slip off. After such a coil is put into the epoxy resin, it becomes invisible. You may add some color dye to the resin that is used to make toroid cores, this makes a beautiful effect
          If you want, I can make an easy tutorial with pictures how all this is done. We do not have anything to hide
          • #20
            Thanks jetijs I understand the process of casting. Used in past to recreate a missing pieces of ornaments in the furniture restoration process. Different materials but similar technique, faster than carving
            Vtech
            • #21
              Thank you.
              I just received my pendant today. Its amazing. Thank you.
              Heat
              • #22
                Just received mine
                Hello Jetijs,
                Just received your pendant It is beautiful. Will test and share the results. If there is anything in particular you'd like to know about, just let me know.
                Thanks again
                Vtech
                • #23
                  Hi Jetijs,
                  My pendant arrived today and it is gorgeous! Thank you so very much! I look forward to noticing and reporting any and all results from wearing this beautiful pendant!
                  With Much Love & Gratitude,
                  Pamela
                  My PATHS Website
                  My Art Website
                  My Paintings As Prints
                  My Facebook
                  • #24
                    Hi all
                    Great to hear that you received everything. I just want you to observe the effects of the pendant, see if you feel any different than usual. It should have a calming effect among other things. Just remember to work with it a bit, thank it for what it is doing for you, treat it like a pet, this works really well. It is your personal little guardian
                    Thank you!
                    • #25
                      Hi Jetijs, I received the one for my wife also - WOW! what a beautiful piece of art. I really like that you have included a Flower of Life symbol on the back as I have been very much into the Flower of Life having studied Drunvalo and Dan Winter. I've seen both of them in person and have books from Drunvalo about Sacred Geometry. I've even got an orgonite type of pyramid with the Flower of Life symbols on it. So this is a very meaningful pendant to us. Thanks so much! PM on the way with a question.
                      • #26
                        First results
                        Hi Jetijs ~
                        I have been in San Diego this week on a business trip. My organite pendant arrived while I was away. My husband, Raymond, knew I was waiting for it and let me know that it had arrived.
                        Since I wasn't home, I asked him to open the package and wear the pendant until I returned. I asked him to pay careful attention to any feelings that may come up or any changes he may experience.
                        After one full day of wearing the pendant he said, "Pamela, I feel so much calmer. I feel like nothing bothers me and I have just an overall sense of calmness."
                        In no way did I put these thoughts in his head before hand. I simply asked him to let me know if he felt differently in any way.
                        One suggestion he had was it may be easier to wear if it were smaller. He wore it around his neck and under his shirt. But because of its size, it did stick out quite a bit. I don't know if it is possible to make them smaller though. He said he would probably be more likely to keep it in his pocket.
                        Anyway, I am home now so I am wearing the pendant. I just put in on about an hour ago and will report back again.
                        Thank you so much Jetijs. It is truly beautiful
                        Namaste,
                        Pamela
                        Discover the Single Greatest Health Science Breakthrough of the Century
                        • #27
                          Jetijs
                          I've been using the pendant the last couple of days. And so far, what I've noticed is:
                          1. when I first got it, I felt an immediate since of it clearing my energy.
                          2. I felt calmer throughout my day
                          3. It seemed as though people were responding more pleasantly to my energy
                          4. A stranger commented on how happy and content I seem
                          5. I had a really long day yesterday. My energy was up, and I felt positive most of the day.
                          6. I held it in my hand as I slept last night, and slept really deeply and calmly.
                          I will continue to report more as I notice things. : )
                          By the way I suffer from depression, and anxiety often, so its nice to feel the calming effects of the pendant, and for someone to comment on how happy I seem.
                          P.S.
                          I was also curious if a smaller one would have the same effect, because I think it would be easier to wear. So far I have carried in my pocket, but will try to find a necklace to wear it on.
                          Thank you so much!
                          Heat.
                          • #28
                            Hi all
                            Thank you for your observations so far
                            It is very difficult to make them smaller, at least the current setup. The next level pendants will be a bit smaller, because they wont have any additional metals in them other than the coil wire. This means that they won't have their own energy, they will be intended more for persons whose vibrations have reached high enough and that are beginning to work with themselves. That pendant will be more of a tool for your spiritual progress. I will post pictures of the next level pendants soon. Also it would be advisable to carry them around the neck and over the shirt, because they work better in light because light as you know is also a form of energy. But they will also work great in pocket or even in a purse
                            Thanks again!
                            Jetijs
                            • #29
                              Hi Jetijs,
                              I received my pendant yesterday. First impressions: curiously attractive and pleasant to pickup.
                              Thank you for sending it. I will continue to keep you updated.
                              • #30
                                Thanks chasson321
                                Here is a quote from an email I sent to a person interested in pendants. It is about the issue that sometimes after a while some people that wear them stop noticing any improvements.
                                The thing with the pendants is that there are several issues. One of them
                                is that you need to do something also in order to get the best out of the
                                pendant. It works by itself also, but you need to treat it as a living
                                being because it emits the same kind of energy that you are using. Thank
                                it for what it is doing for you, this boosts it up a bit. If you are not
                                doing it constantly, you may experience that it does not feel like it did
                                at the beginning anymore. Also every pendant has its own frequency mostly
                                depending on the crystal inside. You also have a certain frequency. The
                                pendant usually tries to synchronize with your frequencies and get your
                                frequencies up till it matches the pendants frequency. This usually takes
                                a month or so and if you have the same frequency as the pendant, you might
                                not feel anything. Then you perhaps will need a pendant with higher
                                frequency, we have those, but I have no picture of them. These are without
                                any metals in the base, they are almost transparent with the coil and the
                                crystal inside. These are more intended for those we have reached a
                                certain frequency already and are starting to work on their own energy
                                flows in meditations, it is a helpful tool for that, but on their own they
                                have less energy, because of the lack of metals. But to increase the
                                frequency you need to remove the metals
                                Hope this helps.
