Post your photo and I reveal the aura, short of ..
Thanks . I never notice there is orgone draw bucket before. I guess wrapping the pipe with cloth would also enhance its capability isn't it? Seeing the description remind me of my radiant electronic sleeping aid. They both work by grounding deadly orgone. At least that is what I can think of when my family sleep easier.
The reason I said my previous experiment is unconclusive is because I expect the glow in the water to increase, but I found it to be reduced instead. I guess having radiant oscillator running in our room can reduce DOR if the setup is right, especially with grounding. However, I still wondering why there are more people reporting upnpleasant feeling, neucea or headache around their device, a sign for too many DOR.
According to BKVR the energy will stay for minutes after the item is being removed. But the aura need time to accumulate. How many hours or minutes the object must remain and how many seconds or minutes the aura remain detectable after the object is removed is still unknown.
I think we can only count camera to be as sensitive as the least sensitive person. Where we see white aura but not the color, we can assume the color is the result of object bleeding color. However it is not consistent though lol.
It would be useful if it actually improve camera sensitivity just like a hack on old sony handycam that allow it to see trough thin cloth. Old handycam that have large CCD sensor also have very good sensitivity that can capture infrared range very well too. However, for the sake of compactness, resolution and price the sensor size being reduced each new model...
Kirlian imaging only work like a scanner though.
BTW here is the difference between my aura filter and PIP:
original image
PIP result:
my aura filter result:
Yes Sucahyo, a test. But i thought a conclusive one... The 'aura' of the cut fruit would jump across the gap to the other side of itself. Try it, holding your fingers near each other at arms length from your face with a white or cream wall as a backdrop... You'll see the 'energy' between your fingers bringing the gap. Have another person hold out the tip of their finger, and make the 'bridge' intersect their finger; make them close their eyes. They should feel when you see the line go thru their finger.
Not sure if I am using the same technique as you but I did a quick test where I got a similar aura around people when using a filter. I also got a similar aura around your objects pic with the banana so I cut the banana out, eliminating all background that may contain an aura and ran the filter on it and this is what I got.
Original Banana cut out with new clean background.
