the following infos you posted Llynch caught my attention
and from one of the links provided Spread Sheet Calculators which is site on Rife technologies
in light of a previous post : http://www.energeticforum.com/renewa...tml#post195288
sure most of you know this book :
The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting
check out chapter 24
talking about Asymetry
thought the following might interest you
see also Francis E. WILKINSON
High-Frequency Transformations
Francis E. WILKINSON -- High Frequency Transformations
see also : http://www.energeticforum.com/153076-post152.html
Octave: a term indicating a repeating pattern of 'frequencies' at different 'scales'.
There is a C note in each Ocatve
The note C is always C regardless of what scale/octave you are at.
Just as the note C is a C at each scale. The vowels A, O and E are the same when at the higher frequency scales of the light spectrum.
Light to Frequency Calculator
Molecular Weight to Frequency Calculator - If one knows the molecular weight of a particular chemical, one can calculate the frequency of the chemical. This spread sheet allows one to both calculate the frequency and also sub harmonics of that frequency. The formula for the fundamental frequency can be found in the CRC Handbook of Chemistry and Physics
Initial reports of the use of this calculator indicate the generated frequencies can have physiologic effects. These effects are not what might be expected. One cannot create a frequency for aspirin and expect it to relieve pain. The same holds true for substances like cocaine or heroin, no effects of intoxication will occur. The effects seem to be equivalent to homeopathic preparations of the chemical. There are significant differences between the physiologic effects and use of a Medical version of a chemical , and the homeopathic version of the chemical ! For example the Medical use of the metal Silver i.e. colloidal, and a Homeopathic preparation of Silver ( Argentum metallicum). If the frequencies have homeopathic actions then:
1. The frequencies are to be delivered directly to the subject, not through some intermediary like a pill or solution.
2. The relationship between a particular sub harmonic and homeopathic potency is unknown.
3. One may be able to apply a specific frequency and expect that known physiologic effects may result from the use of that frequency.
Review of some of the various homeopathic materia medicas should be done to understand how to utilize a frequency. It is simple to locate the molecular weight of just about any chemical in the Homeopathic repertoire by a web search. Just use the name of the chemical along with the words “ molecular weight”. So far, frequencies that seem to work best are in the ranges below 1000 Hz with utilization times of between 5 and 10 minutes. Many questions remain as to the effects of higher frequencies, extremely low frequencies, and extremely long exposure times. Feedback on your experiences with the calculator would be very helpful in understanding how best to utilize it.
