Originally posted by MonsieurM View Postfrom: The Dwellings of the Philosophers Fulcanelli
http://www.bibliotecapleyades.net/ar...ilosophers.pdf
This important point, where the elements and the principles of the highest knowledge are
concentrated, could not be search nor encountered in life, as life is within is, as it radiates
around us, as it is familiar to us and as it suffices to know how to observe it in order to
grasp its different manifestations. It is in death that we can recognize it, in this invisible
domain of pure spirituality, where the soul, liberated from its bonds, takes refuge at the
end of its earthy stay; it is in nothingness, this mysterious nothing which contains
everything, the absence where all presence reigns, that it is proper to search for the
causes, the multiple effects which life is showing us.
Mystery of the Cathedrals
I will stress this point, although I am sure that few will thank me for it: we are truly concerned with a nocturnal star, whose light shines without great brightness at the pole of the hermetic sky. It is, therefore, important, without allowing oneself to be led astray by appearances, to enquire about this terrestrial sky mentioned by Vinceslas Lavinius of Moravia and dwelt on at length by Jacobus Tollius:
'You will have understood what this Sky is, from the following little commentary of mine and by which the alchemical sky will have been disclosed. For:
'This sky is immense and clothes the fields in purple light,
'In which one has recognised one's stars and one's sun.'“Signs and symbols rule the world, not words nor laws.” -Confucius.
Follow up
For evolution to take place, there is required at every step a shift away from less-organization towards more-organization. The mechanistic view asserts that this enhancement of organization, this negative entropy, could be progressively established from the mechanical consolidation of 'favourable' variations. Recent work in applying mathematical theory to biology suggests that there is a very big hole indeed in this particular bucket.
Even if an increase in order arises fortuitously, this accidental shift must survive if it is to be built upon by the next similar accident. But its survival is by no means assured. Indeed it appears to be vulnerable to collapse in proportion to its achievement.
Even in the case of primitive life forms and certainly in higher life forms, the number of possible combinations present at every stage is erroneous -- so enormous as to require that entropy must always increase at the expense of chance arisings in the contrary direction.¹
Statistically, evolution could not happen. As it demonstrably did happen, it must have done so not merely against probability but actually against the possibilities present in a closed system. The conclusion seems unavoidable: the evolutionary process was not a closed system.
By extension, evolution and its present end-product, man, must have been contrived by forces outside the system (the biosphere) in which it occurred. Such an operation, involving the conscious manipulation of energy levels, may be taken as an operation in alchemy.
This was posted here:http://www.energeticforum.com/renewa...tml#post169702
...turn down the volume
Scientists probe Earth's core, make mystifying discovery • The Register
Scientists carrying out extreme boffinry into the makeup of the Earth's liquid core have announced that they are very puzzled to find it is not made of what they had thought it was.Thus it turns out that actually silicon may be even more important than we at the Reg have always thought. The new discoveries have important implications for our understanding of how the Earth formed, and thus in turn how other planets - perhaps ones orbiting other stars - might form.
USU geophysicist links quartz deposits to mountains and faults
Geophysical measurements collected in the western United States reveal correlations between high concentrations of quartz and high temperatures deep in the Earth’s crust. USU geophysicist Tony Lowry says quartz is key to rock cycles resulting in large-scale deformation of continents. Image courtesy Tony Lowry, Utah State University.
John W. Keely
...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously."All matter is crystalic in nature" -- W.Russell.Last edited by MonsieurM; 12-05-2011, 11:53 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
Water, Alpha Quartz and Dna are coaxial helices and also Chiral
Jay Weidner: Hyperdimensional Alchemy
SacredMysteriesTV's Channel - YouTubeLast edited by MonsieurM; 12-06-2011, 12:59 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by MonsieurM View PostPurple is when Red meets Blue in the primary color chart:
and find purple here:
; Female joins Male , Hot and Cold meet...Walk the Middle Path
From : The Dwellings of the Philosophers Fulcanelli http://www.bibliotecapleyades.net/ar...ilosophers.pdf
Facing this subject, which or the initiate translates perfect realization, we are looking at
the completed Work. The brilliant flowers, whose vivid and glistening colors were the
joy of our artisan, have become wilted, and burned out one after the other one; the fruits
grew and, from green, which they were at the beginning, they now appear adorned with a
brilliant purple envelope, a sure clue to their maturity and excellence.
Above all, we must remember, as a priority in the science which interests us, the high
purifying virtue that fire possesses. In the highest sense of the word, a pure physical
manifestation of purity itself, it signifies in this manner its spiritual origin and uncovers
its divine affiliation. As a rather singular observation, the Greek word [*421-1] (pur)
which designates fire has exactly the same pronunciation as the French word pure; and
the hermetic philosophers, by joining the nominative to the genitive case, created the
term [*421-2] (pur-puros), the fire of fire, or phonetically, le pur du pur (the pure of the
pure) and regarded the Latin purpura and the French pourpre (purple) as the seal of the
perfection of the philosophers’ stone’s own color
Queen - The Invisible Man - YouTube enjoy Queen - A kind of magic (High Definition) HD - YouTube
"The lips of wisdom are closed, except to the ears of Understanding." - The Kybalion.
Last edited by MonsieurM; 12-06-2011, 02:56 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Principle of Correspondence:
Flow of Time...I highly recommend you watch his presentation
the good news...you will find free energy...
do not anchor yourself to this time....follow the flow“Signs and symbols rule the world, not words nor laws.” -Confucius.
What took Alchemists years / lifetime to achieve.... will take one year or less to achieve...Walk your Path...Find your Truth
The Pendulum's Swing is shortening
a fractal construct has an 'efficient function', it has a fractal ergonomy to them, they function on multiple levels and in multiple dimensions:
Principle of Mentalism
Last edited by MonsieurM; 12-06-2011, 03:46 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
I put it in post #337...should have put it with the pics...my bad
just a side note ... bunkers and such won't do you any good...quartz , water and your DNA are in and around you ... ...knowledge will do you good
Principle of Mentalism: The Universe is all wave and so are bunkers and mountains
a great rap singers :
Nate Dogg - Music and me - YouTube
Nate Dogg - concrete streets - YouTubeLast edited by MonsieurM; 12-06-2011, 11:21 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
this song will now make more sense to you
Bob Marley - Wake up and live in Santa Barbara 1979 - YouTube
good thinking Haan, if you want to avoid having to copy on dvd...I have one of my pc hooked to my TV (most recent LCD have a pc monitor plug ) a wireless keyboard and you are good to go“Signs and symbols rule the world, not words nor laws.” -Confucius.
Robert Cox: Alchemy and History Lecture 1 - YouTube
A spontaneous overview of the roots of alchemy as embedded in the relationship between matter and consciousness. From the point of view of the Vedic seers to the Hermetic sages, the philosophic significance of the great dictum from the Emerald Table, "That which is Below corresponds to that which is Above, and that which is Above corresponds to that which is Below, in the accomplishment of the miracle of one thing," is unpacked and comprehensively elaborated.“Signs and symbols rule the world, not words nor laws.” -Confucius.
just learned the following while doing some research:
Zinc is found in all human tissues but it is found at high concentrations in the brain
