Flow up
Encyclopedia of the Brethren of Purity - Wikipedia, the free encyclopedia
Gods of Ancient Egypt: S Hu
addendum:
... Black Heat - M & M's - YouTube
Mpulsive solar flare measuring M2.3 erupts
and
Sonic booms in nerves and lipid membranes
"He who knows himself best knows his Creator best" -- Rasa'il Ikhwan as Safa, I, 76. ( The Brethren Of Purity )
The Encyclopedia of the Brethren of Purity (Arabic: رسائل اخوان الصفا) also variously known as the "Epistles of the Brethren of Sincerity", "Epistles of the Brethren of Purity" and "Epistles of the Brethren of Purity and Loyal Friends" was a large encyclopedia[1] in 52 treatises (rasā'il) written by the mysterious[2] Brethren of Purity of Basra, Iraq sometime in the second half of the 10th century CE (or possibly later, in the 11th century). It had a great influence on later intellectual leading lights of the Muslim world, such as Ibn Arabi,[3][4] and was transmitted as far abroad within the Muslim world as Al-Andalus.[5][6] The Encyclopedia contributed to the popularization and legitimization of Platonism in the Arabic world.[7]
read on ....
read on ....
...to shun no science, scorn any book, or to cling fanatically to no single creed. For [their] own creed encompasses all the others and comprehends all the sciences generally. This creed is the consideration of all existing things, both sensible and intelligible, from beginning to end, whether hidden or overt, manifest or obscure . . . in so far as they all derive from a single principle, a single cause, a single world, and a single Soul." - (from the Ikhwan al-Safa, or Encyclopedia of the Brethren of Purity; Rasa'il IV, pg 52)
World Pyramids - The Great Pyramid, Only Facts
Ten Constant Facts
1.Height: 146.5 meters (480.6 ft) tall in original but in our days is 138.8 meters (455.4ft) because of erosion and absence of the pyramidion and outer facing blocks (casing stones).
2.Each base side was 230.4 meters (755.8 ft) long, now it’s 227 meters (744.7ft) because of absence of outer casing stones and erosion.
3.The total mass is 5.9 million tons.
4.The volume with an internal hillock is close to 2.5 million cubic meters.
5.The closest number of all blocks was estimated in 2.3 million separated blocks of different size, volume and mass.
6. Amazingly high precision. Based on measurements taken on the north eastern casing stones, the mean opening of the joints is only 0.5 millimeters wide (1/50th of an inch). Four sides of the base have an average error of only 58 millimeters in length. The base is horizontal and flat to within ±15 mm error that is unbelievable precision for so colossal construction even in our modern architect.
7.The pyramid (sides of square base) is extremely closely aligned to the North pole with only 12 seconds of arc error.
8.The ratio of the perimeter to height of 921.6/146.5 meters equates to 2π to an accuracy of better than 0.05%! It makes the Great pyramid the greatest and ideal mathematical model realized in the Great Pyramid.
9.Pyramid has four clear visible sides oriented to the Earth cardinal points but in fact the pyramid has 8 sides! The centers of the four sides are indented with an extraordinary degree of precision forming the only 8 sided pyramid. The effect is not visible from the ground or from a distance but only from the air, and then only under the proper lighting conditions.
10. Construction material. 2.3 million limestone blocks and granite stones. The largest granite stone was found in the chamber well known as a “king chamber” weigh 25 to 80 tones which were transported more than 500 miles away. At least 5.5 million tons of limestone, 8 000 tons of granite and 500 000 tons of mortar were used for the construction of the Great Pyramid in Giza.
Ten Constant Facts
The pyramid, which measured 1.85 meters at the base and had a height of 1.40 meters, was decorated with wonderful inscriptions
The Mystery of the Missing Pyramidion of Khufu - Reality Sandwich
4. The father of it is the sun, the mother the moon. The wind bore it in the womb. Its nurse is the earth, the mother of all perfection.
Shu (Su) was the god of light and air and as such personified the wind and the earth´s atmosphere. As the god of light he represented illuminated the primordial darkness and marked the separation between day and night and between the world of the living and the world of the dead. As the god of air, he represented the space between the earth and the heavens, and gave the breath of life to all living creatures. As a god of the wind, sailors invoked him to provide the good wind to power their boats. The clouds were considered to be his bones, and he supported the ladder by which the deceased souls could reach the heavens.
Deodato - Caravan Watusi strut [1975] - YouTube
addendum:
Impulsive solar flare reaching M2.3 at its peak time erupted on September 23, 2014. The event started at 23:03, peaked at 23:16 and ended at 23:28 UTC.
Wave propagation occurs when high-pressure compression waves push against areas of lower pressure in the atmosphere. Sound waves move at the speed of sound (1130 feet per second at sea level and a temperature of 68º F).
MUM 2600 – Chapter 2 Notes
Baalbek - A Colossal Enigma
The massive and elegant Roman stonework and columns pale by comparison to the megaliths they were built upon. The temple very visibly incorporates into its foundation, stones of some 1,500 tons. They are some 68 x 14 x 14 feet
http://www.labyrinthina.com/Coral%20...0A.%20Lake.pdf
The wall around the Temple of Jupiter, some 30 miles from Damascus, the capital of Syria, in the size of blocks used, holds the all-time record, with 59 of the largest stones ever quarried. Built around 150 A.D., after the Syrians’ conversion to the gods of the Romans from the god Baal, they wanted to build a greater temple than anything to be found in Rome. For sheer massiveness, they achieved their goal.
This wall is 30 feet above the ground level. Three of the biggest solid blocks of stone every cut by man are in this wall.
The largest measures 63 feet long by 13 feet high by 10 feet thick. Each of these blocks weighs around 1000 tons
Archaeoacoustics - Wikipedia, the free encyclopedia ....
Ancient auditory illusions reflected in prehistoric art?
Sound and vision: Visual cortex processes auditory information too
Stonehenge Sound Study Suggests Iconic Rocks Were Picked For Their Acoustic Properties (VIDEO)
* see also Hornfels
New dig suggests Stonehenge was built to align with summer and winter solstice
Analemma
for more check out :
Healing With Sound. ... Stonehenge - Crystalinks
He traveled to England and demonstrated that Stonehenge does indeed radiate acoustic shadows that recreate the same pattern as interference. "My theory that musical interference patterns served as blueprints for megalithic stone circles—many of which are called Pipers' Stones—is supported by ancient legends of two magic pipers who enticed maidens to dance in a circle and turned them all into stones," Waller noted.
... Disco Power
... Disco Power
* see also Hornfels
Acoustic properties[edit]
Hornfels have the ability to resonate when struck. Michael Tellinger had described these stones in South Africa also known as "ring-stones" due to their ability to ring like a bell.[citation needed]
The Musical Stones of Skiddaw are an example of a lithophone made from Hornfels.[3]
Analemma
