Esoteric and spiritual teachers have known for ages that our body is programmable by language, words and thought. This has now been scientifically proven and explained.
Human DNA acts like a biological version of the Internet -- and it is superior to the artificial one in many ways.
The latest Russian scientific research directly or indirectly explains phenomena such as clairvoyance, intuition, spontaneous / remote acts of healing, self-healing, affirmation techniques, unusual light/auras around people (namely spiritual masters), the mind's influence on weather patterns and much more.
In addition, there is evidence for a whole new type of medicine in which DNA can be influenced and reprogrammed by words and frequencies -- WITHOUT cutting out and replacing single genes.
Researchers have demonstrated a write-once-read-many-times information-storage device, made of DNA embedded with silver nanoparticles, that uses ultraviolet light to encode data.
The device, described in a paper accepted to the AIP's Applied Physics Letters, consists of a thin film of salmon DNA that has been embedded with silver nanoparticles and then sandwiched between two electrodes. Shining UV light on the system enables a light-triggered synthesis process that causes the silver atoms to cluster into nano-sized particles, and readies the system for data encoding. In some cases, using DNA may be less expensive to process into memory devices than using traditional, inorganic materials like silicon, the researchers say.
At first, when no voltage or low voltage is applied through the electrodes to the UV-irradiated DNA, only a low current is able to pass through the composite; this corresponds to the "off" state of the device. But the UV irradiation makes the composite unable to hold charge under a high electric field, so when the applied voltage exceeds a certain threshold, an increased amount of charge is able to pass through. This higher state of conductivity corresponds to the "on" state of the device.
The team found that this change from low conductivity ("off") to high conductivity ("on") was irreversible: once the system had been turned on, it stayed on, no matter what voltage the team applied to the system. And once information is written, the device appears to retain that information indefinitely: the researchers report that the material's conductivity did not change significantly during nearly 30 hours of tracking. The authors hope the technique will be useful in the design of optical storage devices and suggest that it may have plasmonic applications as well.
"Everything is Dual; everything has poles; everything has its pair of opposites; like and unlike are the same; opposites are identical in nature, but different in degree; extremes meet; all truths are but half-truths (and all lies are but half lies ); all paradoxes may be reconciled." - The Kybalion
“Signs and symbols rule the world, not words nor laws.” -Confucius.
I don't know about you guys but this key has something special...just take 5 min to study it...let your eyes follow the flow and you'll see where you end up....
there is a useful discussion taking place in this thread.
llynch has kindly taken it upon himself; for which I am Grateful , to reduce the numbers in the Table of Elements and seek out useful Patterns...PLease Check it out...you'll learn quite a bit
The Crown has 12 small red orbs ; the sun has 15 rays , the Lions have 9 red Claws ,if you don't count the 2 hidden yellow and blue (red yellow blue and white are magical and Alchemical colors ) there are 12 of them
also from Comte St Germain's Book :
Approaching I noticed on one of them sacred script, the other being engraved with a line of Greek letters; between the two plates was an iron circle. Two lions, one red and the other black, rested on clouds and appeared to guard a golden crown above them. Also near the circle were to be seen a bow and two arrows. I read several characters written on the flanks of one of the lions. I had barely observed these different emblems when they vanished together with the wall which contained them.
one more thing...where the pentagram meets the Blue tile, it resembles the all seeing eye
We must remember that the periods of exodus from Atlantis were far apart. The type of civilization carried to the region of the Pyrenees and America just before and after the first destruction was not the same as that carried to Central America and Morocco before the second upheaval, and to Egypt and Yucatan before the final destruction.
In the Pyrenees there are ruins of the early Atlantean settlements; and in Moroccoearly settlements, also as yet uncovered.
for clarification: People (including royalty ) living in Morocco may not be aware of this hidden in Plain sight Truth ...Nor are they Atlanteans (at least for most of them )
Dragon history is extensive and wide-spread, as almost every mythology has unique styles of dragon. The Sumerian word for dragon is "ushum". Chinese dragons date back to around 5,000 BCE. The Chinese believed that they were the "decendants of the dragons," too. Like comets, they could rise to the heavens or go to the bottom of the seas. Like Mesopotamian and Egyptian rulers, Chinese emperors were said to be sons of the dragons and wore special robes. The sign of the celestial dragon could only be worn by the emperor, and it was the sign of the ultimate power.
The venom of the snake was used as an Elixir to help prevent disease through boosting the immune system with high levels of protein. And secondly mixing the neurotoxic venom with the blood of the snake or mammalian host such as a horse brings on altered states of consciousness much akin to certain drugs used by shaman across the world from ancient times. Visions of ‘otherworlds’ seen in such trances are often depicted as tombs, wombs or caves, within which sometimes benevolent, sometimes terrible, serpents are encountered.
In any discussion of serpent wisdom we cannot fail to also mention the ancient Hindu Kundalini practice. Kundalini means simply "coiled serpent" and in the Indian system the ida and pingala energy (through serpent channels) are raised up and down the spine to raise the consciousness of the adept. The dual serpentine caduceus is known to all health practitioners the world over.
[/QUOTE]
Dimensional Shift
This master adept, called the wisest in Europe, reserved his greatest gift, the two books he wrote, for his wisest companions. One of them was a magical rite for alchemical Immortality. The Magnum Opus, the Great Work of alchemy, is the utter transformation of oneself into a being of light, an energy body. Saint Germain's great secret was the Art of Rejuvenation and Spiritual Rebirth. Immortality is the occult alternative to Christian salvation. Post-modern views include ideas of holographic pattern or field survival from advanced physics. There is a clear message to realize the immortality that rests within us.
High ritual magic can be traced to Hellenistic Egypt, from there to Arab Spain and Jewish practitioners of Kabbala, then to late medieval magicians. Magic was a fundamental element in the rituals of the Greek mysteries. There are three basic ‘paths’ in Ritual Magic: the ‘left’ and ‘right.’ These refer to the goal of the magician’s spiritual work.
A “Left hand path” magician usually seeks physical and/or spiritual immortality and magnification of the Higher Self; a right hand path magician seeks union with divine energy and dissolution of the ego/personality. The Middle Way annihilates each thought against its opposite, opening the most direct path to transcendence or primordial awareness of the eternal. Is it a choice to pursue individual glory or immortality rather than union or absorption, or are they in fact different facets of the same paradoxical state?
Kicking off his new Saturday night berth, John B. Wells (email) welcomed futurist Paul Guercio and physicist George Hart of the Merlin Project for a discussion about their Timetrak technology, which reveals future trends and changes, as well as information about the election, the economy, war, and climate.
they used an interesting example about US history and every 72 years event
