  • one more fractal resonance for you:
    “Signs and symbols rule the world, not words nor laws.” -Confucius.
    • a repost from the 1st page of : http://www.energeticforum.com/renewa...magnetism.html
      Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature (fractal nature), for in it there is a spirituality (all is spirit, and so is electromagnetics ) and conjunction of elements, and an earth which is golden (golden mean see: http://www.energeticforum.com/149201-post91.html ) in its tincture.
      the hen's egg (Victor Schauberger's egg, inventor of : The Schauberger Flying Saucer "The Repulsin" type A)
      Schaubergers Cosmic Egg
      • for some explanation :
        The following pic can be seen as the representation of the Principle of Mentalism :
        ALL the waves (material and immaterial) are seen here
        what you see represented by Walter Russell is the Gradient ( Octave ) of Material to immaterial (and vice versa ) :
        which results in the shape of an Egg ( field of a magnet )
        The North Pole's field will always be a little bigger/ expanded than the South Pole
        an egg :
        --------------------------------- and using the Principle of Correspondence :
        read the following
        I think you might like this this info ...remember Anisotropy
        Lenses can bend light and sound in almost any direction
        (PhysOrg.com) -- When an optical fiber is bent by 90° or more, the light begins to leak away, posing a problem for fiber optics communications. But by using special lenses that can bend light by not only 90°, but also 180° (i.e., a U-turn) or 360° (i.e., a full loop), scientists may limit light leakage in optical fibers and overcome this problem, not to mention provide a useful material for many other applications. Recently, a team of scientists has theoretically investigated materials for achieving this kind of advanced light control, which could work equally well for sound waves.
        The scientists, Sebastien Guenneau and coauthors from Institut Fresnel, CNRS, University of Aix-Marseille in Marseille, France, have published their study on the focusing and bending of light and sound waves in a recent issue of the New Journal of Physics.
        As Guenneau explained, both light and sound control techniques use gradient index (GRIN) lenses, which can effectively be used to curve space for light and sound trajectories. By creating a change, or gradient, in the refractive index of a lens, the scientists could create anisotropies – that is, make the lens' refractive index directionally dependent.
        doesn't remind you of: ( Principle of Correspondence )
        images taken from : Sacred Geometry
        • a Thought occured to me a while back but i had to let it grow for a while before posting it :
          some of you maybe familiar with Tesla's Turbine
          Tesla turbine - Wikipedia, the free encyclopedia
          The Tesla turbine is a bladeless centripetal flow turbine patented by Nikola Tesla in 1913. It is referred to as a bladeless turbine because it uses the boundary layer effect and not a fluid impinging upon the blades as in a conventional turbine. The Tesla turbine is also known as the boundary layer turbine, cohesion-type turbine, and Prandtl layer turbine (after Ludwig Prandtl). Bioengineering researchers have referred to it as a multiple disk centrifugal pump.[1][2] One of Tesla’s desires for implementation of this turbine was for geothermal power, which was described in "Our Future Motive Power".[3]
          Student-made Tesla Turbine - YouTube
          ...... we know that the dillution of salt in water generates UV
          and the first created battery was a stack of disks :
          This image is based off fractals and the yin-yang symbol, and also reminds me of an electromagnetic field and very much like this chakra field diagram (, )--(and somewhat like this version of chakra energy flow —see Wikipedia: chakra for general info). When I showed this image to a friend of mine, he said it reminded him of the Cantor set. I didn't know what this was at the time but, after a bit of researching on the Web, I emailed a math professor who told me this image is "a depiction of a 'Cantor-like' process". Another interesting thing about this image is that it can be drawn by simply making smaller and smaller figure-8s (infinity symbol), which only intersect in the center. I call this "circular infinity" (2D) or "spherical infinity" (3D). Vortices can also be seen by spiraling down along the circle lines. This version is a base-2 division but a base-3 (and higher) division version is possible and used in esoteric literature.1
          what do you think would happen if we merged these two Designs into one
          ps: Tesla knew his designs were fractal .....
          Nature may reach the same result in many ways. Like a wave in the physical world, in the infinite ocean of the medium which pervades all, so in the world of organisms, in life, an impulse started proceeds onward, at times, may be, with the speed of light, at times, again, so slowly that for ages and ages it seems to stay, passing through processes of a complexity inconceivable to men, but in all its forms, in all its stages, its energy ever and ever integrally present. A single ray of light from a distant star falling upon the eye of a tyrant in bygone times may have altered the course of his life, may have changed the destiny of nations, may have transformed the surface of the globe, so intricate, so inconceivably complex are the processes in Nature. In no way can we get such an overwhelming idea of the grandeur of Nature than when we consider, that in accordance with the law of the conservation of energy, throughout the Infinite, the forces are in a perfect balance, and hence the energy of a single thought may determine the motion of a universe. Nikola Tesla
          Our first endeavors are purely instinctive prompting of an imagination vivid and undisciplined. As we grow older reason asserts itself and we become more and more systematic and designing. But those early impulses, though not immediately productive, are of the greatest moment and may shape our very destinies. Indeed, I feel now that had I understood and cultivated instead of suppressing them, I would have added substantial value to my bequest to the world. But not until I had attained manhood did I realize that I was an inventor
          . Nikola Tesla
          The scientific man does not aim at an immediate result. He does not expect that his advanced ideas will be readily taken up. His work is like that of the planter — for the future. His duty is to lay the foundation for those who are to come, and point the way. He lives and labors and hopes Nikola Tesla .
          • or simply Quartz (piezo electric ) Disks + Salt Water ( UV emission ) :
            the Tesla Quartz / Barium Titanate Turbine Battery
            ps: nano quartz will also be produced through friction
            • quick info on saltwater (besides UV emission through dissolution )
              as electrolyte
              Fuel Cell Today - Home Page
              Cheap Fuel Cells with Salt Water Electrolyte to Commercialise in Japan
              30 Mar 2012
              Japan’s Tohoku University has developed a magnesium powered cell that uses salt water as an electrolyte. Magnesium is an abundant and cost-effective resource, brine is obviously even more so. Magnesium has been considered before but has suffered from problems of being easily burned and being dissolved by its electrolyte; Tohoku University claim to have solved such issues by using flame retardant magnesium developed under a separate research project by the National Institute of Advanced Industrial Science and Technology.
              The technology will be able to compete with conventional batteries in a number of applications, including for use in electric vehicles. Furukawa Battery Company is working with the University as a cooperative development partner in the battery manufacturing industry; it will commercialise the product within the year at a target price of half that of an equivalent lead–acid battery.
              Tohoku University also hopes that its cell will find application in the UPS and emergency power niches – “It is now possible to install an inexpensive emergency power source at each house” commented project developer Professor Ohama.
              The electrolyte and anode of metal air fuel cells (MAFC) require periodic replacement due to corrosion which occurs as the system generates hydrogen ions, and electricity. Therefore this technology differs from conventional fuel cells which can operate indefinitely as long as a source of fuel is available.
              • here is a vid to add to our aluminum links
                Originally posted by Allwest View Post
                see also Petar's post on aluminum and magnetite : http://www.energeticforum.com/184579-post2416.html
                n rays :
                ------------------- from http://www.energeticforum.com/renewa...tml#post184178
                Rene Blondlot: N-Rays
                On a New Species of Light (March 23, 1903)
                The radiations emitted by a focus tube are filtered through a sheet of aluminum foil or a screen of black paper, in order to eliminate the luminous rays which might accompany them. While studying these radiations by means of their action on a small spark, I discovered that they are plane-polarized as soon as emitted. I further proved that when these radiations traverse a plate of quartz in a direction at right angles to its axis, or a lump of sugar, their plane of action undergoes a rotation just like the plane of polarization of a pencil of light.
                I then asked myself if a rotation could also be obtained by passing the radiations of the focus through a pile of Reusch mica sheets. I observed, in fact, a rotation of from 25° to 30° in the same direction as that of polarized light. This action of a pile of micas made me at once infer that a single sheet of mica must act, and that this action must be depolarization, or, rather, the production of elliptic polarization; this is indeed what occurs. The interposition of a sheet of mica, set so that its axis makes an angle of 45° with the pane of action of the radiations emitted by the tube, destroys their rectilinear polarization, for their action on a small spark remains sensibly the same, whatever be the direction of the spark gap. If a second sheet of mica is interposed, identical with the first, so that the axes of the two sheets are perpendicular to each other, rectilinear polarization is reestablished. This result can also be obtained by the use of a Babinet’s compensator. Consequently we are dealing with elliptic polarization.
                tourmaline has boron and aluminum
                • Sun Unleashes Flare, Blows Magnetic Bubble : Discovery News
                  On April 16, an M-class flare erupted on the limb of the sun, triggering a coronal mass ejection (CME). The CME -- a magnetized bubble of superheated plasma -- wasn't thrown in the direction of Earth, but toward Mars and Venus, both of which may experience a glancing blow according to Spaceweather.com.
                  Additional analysis by NASA's Space Weather Laboratory at Goddard Space Flight Center has shown that the CME will likely wash over the Mars Science Laboratory (currently en route to the Red Planet), the STEREO-B spacecraft and the Spitzer space telescope. (The Lab produced a nifty animation showing the predicted trajectory of the CME.)
                  Sun:
                  Mars
                  Venus:
                  • here is a nice info that goes along our line of Discussion
                    The earth is not at rest
                    (Phys.org) -- The Earth is not at rest. It orbits the Sun, which in turn orbits the center of the Milky Way Galaxy, which in turn moves within the Local Group of Galaxies - a collection of about fifty four galaxies in our "neighborhood" (that is, within about ten million light-years of Earth). The Local Group itself is "falling" toward the Virgo Cluster of Galaxies, a set of over one thousand galaxies about fifty million lights years away in the direction of the constellation of Virgo, and whose gravity pulls the Milky Way. After the cosmic microwave background radiation was discovered in 1960, astronomers began searching for signs of these motions of Earth with respect to the background light. First hints came in the mid-1970s and 1980s, and signaled a serious problem: the measured motion of the Earth with respect to the cosmic background was considerably smaller than the sum of all the movements listed above. One possible solution was that our understanding of the distribution of galaxies was incorrect.
                    ----------------------------------- a repost from http://www.energeticforum.com/psychi...tml#post145400
                    - Ben Rich, the “Father of the Stealth Fighter-Bomber” and former head of Lockheed Skunk Works
                    When Rich was asked how UFO propulsion worked, he said, “Let me ask you. How does ESP work?” The questioner responded with, “All points in time and space are connected?” Rich then said, “That’s how it works!”
                    Extraterrestrial UFO Are Real : Ben Rich Lockheed Skunk Works Director Admitted In His Deathbed Confession |Latest UFO News| UFO 2011 Sightings|Alien Pictures|2011 Solar Flares|Disclosure Project|Web Bot
                    Isn't he describing this:
                    Just wanted to post this info because its representation is nothing more than a Fractal representation:
                    Multiverse = Many Worlds, Say Physicists - Technology Review
                    Enjoy
                    • New process improves catalytic rate of enzymes by 3,000 percent
                      Light of specific wavelengths can be used to boost an enzyme's function by as much as 30 fold, potentially establishing a path to less expensive biofuels, detergents and a host of other products.
                      In a paper published in The Journal of Physical Chemistry Letters, a team led by Pratul Agarwal of the Department of Energy's Oak Ridge National Laboratory described a process that aims to improve upon nature – and it happens in the blink of an eye.
                      "When light enters the eye and hits the pigment known as rhodopsin, it causes a complex chemical reaction to occur, including a conformational change," Agarwal said. "This change is detected by the associated protein and through a rather involved chain of reactions is converted into an electrical signal for the brain."
                      With this as a model, Agarwal's team theorized that it should be possible to improve the catalytic efficiency of enzyme reactions by attaching chemical elements on the surface of an enzyme and manipulating them with the use of tuned light.
                      see also: Francis E. WILKINSON -- High Frequency Transformations
                      http://www.energeticforum.com/renewa...tml#post188793
                      read what Tesla wrote (previously posted ; you maybe surprised )
                      • Positive feelings may help protect cardiovascular health
                        Over the last few decades numerous studies have shown negative states, such as depression, anger, anxiety, and hostility, to be detrimental to cardiovascular health. Less is known about how positive psychological characteristics are related to heart health. In the first and largest systematic review on this topic to date, Harvard School of Public Health (HSPH) researchers found that positive psychological well-being appears to reduce the risk of heart attacks, strokes and other cardiovascular events.
                        Principle of Correspondence applied to an Economy / Society
                        Changing brains for the better; article documents benefits of multiple practices
                        (Medical Xpress) -- Practices like physical exercise, certain forms of psychological counseling and meditation can all change brains for the better, and these changes can be measured with the tools of modern neuroscience, according to a review article now online at Nature Neuroscience.
                        • “Question: What great change or the beginning of what change, if any, is to take place in the earth in the year 2,000 to 2,001 A.D.? Answer: When there is a shifting of the poles; or a new cycle begins.”(826-8 given August 11, 1936) Edgar Cayce
                          A scarcity of college men leads women to choose briefcase over baby
                          American women today are more likely to earn college degrees than men with women receiving 57 percent of all bachelor's and 60 percent of all master's degrees. But are there consequences to having more women than men in college?
                          Research from the University of Texas at San Antonio (UTSA) and University of Minnesota has found the ratio of men to women dramatically alters women's choices about career and family. When men are scarce, women delay having children and instead pursue high-paying careers.
                          "Most women don't realize it, but an important factor in a woman's career choice is how easy or difficult it is to find a husband," said Kristina Durante, assistant professor of marketing at the UTSA College of Business. "When a woman's dating prospects look bleak – as is the case when there are few available men – she is much more likely to delay starting a family and instead seek a career."
                          In one study, the researchers examined the ratio of single men to single women in each U.S. state and Washington D.C. They found that as bachelors became scarce, the percentage of women in high-paying careers increased, women delayed having children, and had fewer kids when they finally decided to start a family.
                          In another study on college campuses, the researchers led women to believe that there were either more men or less men on campus by having participants read one of two news article about the student population. When women read that there were fewer men than women on campus, they became more motivated to pursue ambitious careers rather than start a family.
                          • a beautiful thought considering our discussion and the celestial intelligences ( from before it's news )
                            Dr. Neil DeGrasse - A fascinatingly disturbing thought - YouTube
                            Dr. Neil DeGrasse - Segment of Cosmic Quandaries you should watch it .... beautiful
                            As within so without
                            ps: look at the background color
                            while we are on the color ... so did you guys pay attention to the colors people are wearing ... just out of curiosity
                            • Let explore another way of visualizing Amps ... think of it as an Analogy of sort ......
                              Anisotropy is defined as :
                              Anisotropy ( /ˌζnaɪˈsɒtrəpi/) is the property of being directionally dependent, as opposed to isotropy, which implies identical properties in all directions. It can be defined as a difference, when measured along different axes, in a material's physical or mechanical properties (absorbance, refractive index, conductivity, tensile strength, etc.) An example of anisotropy is the light coming through a polarizer. An example of an anisotropic material is wood, which is easier to split along its grain than against it.
                              conventional current is defined to flow in the same direction as positive charges. So in metals where the charge carriers (electrons) are negative, conventional current flows in the opposite direction as the electrons. In conductors where the charge carriers are positive, conventional current flows in the same direction as the charge carriers.
                              or if you prefer "Left Chiral" vs "Right Chiral"
                              ponder on that
                              • one more piece of info to roll a bit the boat
                                By all accounts Earth should be a "snowball planet" like the frigid world Hoth in the 1980 Star Wars film "The Empire Strikes Back."
                                Why? Because common theories of stellar evolution predict that the sun was only 70 percent of its current brightness when it first lit its fusion engine 4.5 billion years ago. The sun has been steadily growing brighter since then and will continue so into the future, eventually evaporating away Earth's oceans.
                                ANALYSIS: Stellar 'Speed Bumps' Could Shape Baby Star Systems
                                Once Earth amassed an ocean 4.3 billion years ago it should have quickly frozen over and reflected so much sunlight back into space that it squelched Earth's ability to thaw out for billions of years.
                                The dilemma, called the "faint young sun paradox," has been know about since the 1950s and was popularized by Carl Sagan. Geochemists and solar physicists have wrestled for answers all these years.
                                Lowering Earth's reflectivity by reducing cloud cover doesn't work. Models also show that a greenhouse effect from dense carbon dioxide and methane can't warm the Earth enough either. In some simulations, methane and carbon dioxide combine to make a photochemical smog that would have chilled Earth even further.
                                Now, David Minton of Purdue University has come up with a novel solution that, by his own admission, straddles science fact and fiction. Minton proposes that Earth was closer to the sun when it formed and then migrated outward to its current orbit. To keep Earth tepid under a cooler sun, our planet would have needed to have been roughly 6 million miles (9.7 million kilometers) closer to the sun than it is today.
                                this is one theory ...... or :
                                PLANET-SWAP shock: Stars grabbed dirtballs from other clusters β€’ The Register
                                Space boffins have suggested that billions of stars in our galaxy have captured roaming rogue planets as they tootle through the cosmos
                                The rogue planets, which can be ejected from their own star's system by interaction with a fellow planet during the early stages of a system's formation, float freely out in space. If they pass a different star later on, which is moving in the same direction and at the same speed, they can hitch a ride and end up trillions of miles away.
                                All this planet-swapping took place long ago in young star clusters. Boffins simulated these clusters and found if the number of rogue planets equaled the number of stars, there was a three to six per cent chance the stars would grab a planet over time.
                                some call her Gaea / Aeon ( def in the next post )
                                A Feminine corpuscle becomes detached from, or rather leaves, a Masculine corpuscle, and starts on a new career. It actively seeks a union with a Masculine corpuscle, being purged thereto by the natural impulse to create new forms of Matter or Energy. One writer goes so far as to use the term "it at once seeks, of its own volition, a union," etc. This detachment and uniting form the basis of the greater part of the activities of the chemical world. When the Feminine corpuscle unites with a Masculine corpuscle, a certain process is begun. The Feminine particles vibrate rapidly under the influence of the Masculine energy, and circle rapidly around the latter. The result is the birth of a new atom. This new atom is really composed of a union of the Masculine and Feminine electrons, or corpuscles, but when the union is formed the atom is a separate thing, having certain properties, but no longer manifesting the property of free electricity.
                                Serious blow to dark matter theories? New study finds mysterious lack of dark matter in Sun's neighborhood
                                (Phys.org) -- The most accurate study so far of the motions of stars in the Milky Way has found no evidence for dark matter in a large volume around the Sun. According to widely accepted theories, the solar neighbourhood was expected to be filled with dark matter, a mysterious invisible substance that can only be detected indirectly by the gravitational force it exerts. But a new study by a team of astronomers in Chile has found that these theories just do not fit the observational facts. This may mean that attempts to directly detect dark matter particles on Earth are unlikely to be successful.
