  • Humongous Roman mosaic found under farmer's field in Turkey (+video) , page 1
    Humongous Roman mosaic found under farmer's field in Turkey (+video) - CSMonitor.com
    So far, the researchers have revealed about 40 percent of the mosaic. The floor is in 'pristine' condition, and would have fronted an open-air marble swimming pool flanked by porticos.
    The mosaic, which once decorated the floor of a bath complex, abuts a 25-foot (7-meter)-long pool, which would have been open to the air, said Michael Hoff, a University of Nebraska, Lincoln art historian and director of the mosaic excavation. The find likely dates to the third or fourth century, Hoff said. The mosaic itself is an astonishing 1,600 square feet (149 square meters) — the size of a modest family home.
    "To be honest, I was completely bowled over that the mosaic is that big," Hoff told LiveScience.
    find the Swastika - Wikipedia, the free encyclopedia
    “Signs and symbols rule the world, not words nor laws.” -Confucius.
    • you know by now that I am a Great Admirer of Tesla's Work
      in particular the Tesla Turbine : see : http://www.energeticforum.com/psychi...tml#post191941
      so want to show you something :
      Dynamics of Disk Spacing, Geometry, Horsepower & Torque by Ken Rieli, disc geometry improvements, Phoenix Turbine Builders Club, Tesla turbines
      Comments
      First of all we'll look at some of Nikola Tesla's historic experiments to get an idea of the relationship between disk spacing, horsepower, torque, and efficiency. Tesla started out building a 6-inch turbine followed by a 12-inch, 9.75-inch, 18-inch and finally a 60-inch. With the smaller turbines he used a disk spacing of .03 inches (0.8mm), with disc thickness the same (.03").
      Once he moved to 18-inch diameter disks, he increased both the disk thickness and spacing between them to .0625 inches (1.6mm). While working with the Allis Chalmers company of Milwaukee, Wisconsin, his largest design -- a 60-inch diameter turbine -- was built using a disk thickness and spacing of 0.125 inches (3.2mm). (some of the last measure don't follow the 369 principle .... maybe wrong or needs readjustement )
      Tesla's 10-inch turbine produced 110 horsepower, his 18-inch produced 200-300 hp, and the 60-inch produced 675 hp. Tesla also mentioned in his aircraft designs that for maximum efficiency the exhaust port should be reduced, but for maximum horsepower the exhaust size should be increased. In addition, Tesla stated that the greatest efficiency is achieved when the disks rotate at the speed of the fluid, but maximum torque is realized when the disks rotate at just over 50% of the fluid speed.
      Other factors that affect efficiency and power are the same as those affecting aircraft, cars or any aerodynamically sensitive object: surface finish and geometry.
      To put it plainly, it is virtually impossible to calculate the obtainable torque and horsepower due to aerodynamic complexities; however, if you follow the basic design and construction methods already established, you will achieve results that are relatively close to Tesla's experiments.
      and also from:
      Tesla turbine - Wikipedia, the free encyclopedia
      Pump
      If a similar set of disks and a housing with an involute shape (versus circular for the turbine) are used, the device can be used as a pump. In this configuration a motor is attached to the shaft. The fluid enters near the center, is given energy by the disks, then exits at the periphery. The Tesla turbine does not use friction in the conventional sense; precisely, it avoids it, and uses adhesion (the Coandă effect) and viscosity instead. It utilizes the boundary layer effect on the disc blades.
      Smooth rotor disks were originally proposed, but these gave poor starting torque. Tesla subsequently discovered that smooth rotor disks with small washers bridging the disks in ~12–24 places around the perimeter of a 10″ disk ( actually 9.75" ) and a second ring of 6–12 washers at a sub-diameter made for a significant improvement in starting torque, without compromising efficiency.
      I have been kind of "obsessed" with the idea of mixing a Stirling Engine with a Tesla Turbine
      Stirling engine - Wikipedia, the free encyclopedia
      Homeconstructor - Tesla turbine
      • Sex with early mystery species of humans seen in DNA, UW researcher says | Nation & World | The Seattle Times
        There's only one way the foreign DNA could have made it into modern human populations. "We're talking about sex," said Joshua Akey of the University of Washington, whose lab identified the foreign DNA in three groups of modern Africans.
        got it from: Coast To Coast AM 09.27.2012 Mysterious Pyramid, Puzzling DNA, & Angelic Light - YouTube
        also : Sun today — solar flares online
        • Linking Patterns
          from : Reading the Green Language of Light - Vincent Bridges
          In Islam, the mithrab is the prayer doorway to Mecca and the inner mysteries of Mohammed's revelation. In many Sufi sects, the mithrab has the geometric pattern of the Tree of Life, without Malkuth, inscribed in its niche. This is usually coupled with the Light Verse from the Qu'ran - Sura 24, verse 35. To the Sufis, this verse exemplifies the very idea of illumination. Idries Shah called the verse "the essence of Sufism," and goes on to suggests that it "conceals the nature of the cognition of the extra dimensions of the human consciousness which comes beyond the intellect."
          Arabic Quran Surah 24. Light
          24:35 Allah is the Light of the heavens and the earth. The Parable of His Light is as if there were a Niche and within it a Lamp: the Lamp enclosed in Glass: the glass as it were a brilliant star: Lit from a blessed Tree, an Olive, neither of the east nor of the west, whose oil is well-nigh luminous, though fire scarce touched it: Light upon Light! Allah doth guide whom He will to His Light: Allah doth set forth Parables for men: and Allah doth know all things.
          from: Fulcanelli - The Mystery Of The Cathedrals book
          All is Analogy
          • continuing : Reading the Green Language of Light - Vincent Bridges
            In the niche of the credence at Lallemant are the letters RERE on one line, followed by the letters, RER on the next. This is repeated twice more for a total of six lines, hence doubling or crossing: two times three equals six. It looks like this:
            RERE
            RER
            RERE
            RER
            RERE
            RER
            Pythagorian Numerology :
            RERE = 28 = HM 1
            RER = 23 = HM 5
            RERE + RER = HM 1 + HM 5 = HM 6
            Sun Angel Creations - Law of Attraction Secrets - NumberQuest Numerology - NQ-Multi Numerology Calculator - Calculate Pythagorean, Chaldean, Kabbalah and Gematria Numerology Numbers! :: 123 Free Numerology Reports! :: Unlimited Free Numerology Name,
            • Linking Patterns
              24 : 35 = 6 8 = 14 = HM 5
              following are Surah matching these numbers
              At Tβriq Surah 86. The Morning Star, The Nightcomer
              Al Qalam Surah 68. The Pen, (the Letter) N
              Ibrahξm Surah 14. Abraham
              Fussilat Surah 41. (Signs) Spelled Out
              Al Mβ'idah Surah 5. The Table Spread
              Heliopolis egypt
              Coordinates: 30°07′46.3″N 31°17′20″E
              30+7+46+3 = 86
              31+17+20 = 68
              86+68= 154 = HM 1
              ps: same principle as the Iching I Ching Online - the Online Book of Changes with Transformed Hexagram
              a Fractal Construct
              • forgot to post the following
                the right conduit to allow for a Mash up of a Tesla Turbine with a Stirling Engine would be :
                Tesla valve - Wikipedia, the free encyclopedia
                A Tesla Valve is a valve allowing for a fluid to flow very preferentially (or entirely) in one direction, but without the moving parts usually found in valves. The principle is that currents flow along different paths in different directions, and that these differences have a disproportionate effect on the resistance of the valve. Named after Nikola Tesla, it was invented in 1916 (U.S. patent 1,329,559; patented 1920). In practice, the idea has seen little development or use since its invention. A similar mechanism is used for mixing on a small scale through the use of a Coanda effect mixer.
                • New Theory On Why Men Love Breasts | Health
                  Men are programmed to like breasts, but it isn’t for the reasons scientists once thought.
                  Why do straight men devote so much headspace to those big, bulbous bags of fat drooping from women’s chests? Scientists have never satisfactorily explained men’s curious breast fixation, but now, a neuroscientist has struck upon an explanation that he says “just makes a lot of sense.”
                  Larry Young, a professor of psychiatry at Emory University who studies the neurological basis of complex social behaviors, thinks human evolution has harnessed an ancient neural circuit that originally evolved to strengthen the mother-infant bond during breast-feeding, and now uses this brain circuitry to strengthen the bond between couples as well. The result? Men, like babies, love breasts.
                  When a woman’s nipples are stimulated during breast-feeding, the neurochemical oxytocin, otherwise known as the “love drug,” ( see also : http://www.energeticforum.com/psychi...tml#post206207 ) floods her brain, helping to focus her attention and affection on her baby. But research over the past few years has shown that in humans, this circuitry isn’t reserved for exclusive use by infants.Recent studies have found that nipple stimulation enhances sexual arousal in the great majority of women, and it activates the same brain areas as vaginal and clitoral stimulation. When a sexual partner touches, massages or nibbles a woman’s breasts, Young said, this triggers the release of oxytocin in the woman’s brain, just like what happens when a baby nurses. But in this context, the oxytocin focuses the woman’s attention on her sexual partner, strengthening her desire to bond with this person.
                  In other words, men can make themselves more desirable by stimulating a woman’s breasts during foreplay and sex. Evolution has, in a sense, made men want to do this.
                  Attraction to breasts “is a brain organization effect that occurs in straight males when they go through puberty,” Young told Life’s Little Mysteries. “Evolution has selected for this brain organization in men that makes them attracted to the breasts in a sexual context, because the outcome is that it activates the female bonding circuit, making women feel more bonded with him. It’s a behavior that males have evolved in order to stimulate the female’s maternal bonding circuitry.”
                  http://www.energeticforum.com/psychi...tml#post196232
                  Music and spirituality may be legacies of motherese: expert
                  (PhysOrg.com) -- Ancient humans may have developed a capacity for music and a sense of spirituality linked to music because of the foetal/infant-maternal bond, according to international authority on the origins of music, Professor Richard Parncutt.
                  from: http://www.energeticforum.com/psychi...tml#post209637
                  Linking Patterns
                  Study suggests women with severe forms of endometriosis are more attractive
                  ps: I wonder if the presence of Boron in the female body also plays a role in this imbalalnce
                  Boron
                  Boron, Estrogen, Lunaception, and Menstruation
                  Solar Outbursts and Sacred Ancient Visions | Science and Technology
                  http://www.energeticforum.com/psychi...tml#post206215
                  boundless love « Oculus divinorum v.4
                  Original Title: Venus-Neptune contacts and the divinity of love
                  Not All Fractal Antennas are Identical
                  ps: I think Mary Magdelene also fits the profil ( boobies included ..... )
                  Mary Magdalene - Wikipedia, the free encyclopedia
                  Jiraiya - Narutopedia, the Naruto Encyclopedia Wiki
                  one more thing :
                  Why Do Men Have Nipples? | LifesLittleMysteries.com
                  Brace yourselves for a low blow, tough guy. Nipples remind us that gender is anything but clear-cut, especially in utero. Whatever your sex, everyone starts off as a woman in the womb .
                  For the first several weeks a developing embryo follows a "female blueprint," from reproductive organs to nipples. Only after about 60 days does the hormone testosterone kick in (for those of us with a Y chromosome), changing the genetic activity of cells in the genitals and brain. But by then those mammary papillae aren't going anywhere.
                  So the real question is: why do male nipples come equipped with nerves and blood vessels? In many male mammals nipple formation is stunted by hormones, but not in humans. Did prehistoric men nurse their young? The lack of evidence suggests not. More likely, full-grown nipples—being harmless—don't get weeded out by natural selection.
                  If Women have male DNA in their brain ... don't you think Men are likely to have Female DNA in their Brains
                  Men on the mind: Study finds male DNA in women's brains
                  • How to Become a Virtuoso: Start With Non-Conformity | Alternative
                    Are you willing to spend 14,500 hours at something, anything, to master it? Apparently, that is what it takes to become a virtuoso. While there are exceptions to this rule, it seems that it takes an exceptionally large amount of focus and dedication to become a virtuoso or a genius. Is it possible, however, that the process of mastery could be accelerated? Can we use unconventional tools to surpass mundane levels of skill? Are there secrets to going above the bar without frying our minds or suffering emotional or psychological burn out?
                    Franz Listz was playing the piano at the age of five. Yo-Yo Ma started playing the violin and viola at a very young age before he switched to the cello. The world-renown tenor, Luciano Pavarotti, started singing at a local church at the age of nine. Einstein apparently did not start reading until the age of nine, and spoke much later than most children, but when he did, he spoke in full sentences. Apparently it takes time for the mind to process creative ideas, and it can do so more easily without the interference of speech . Is it possible that each of these examples of virtuosity developed mental prowess with slightly different, but fascinatingly connected, experiences?
                    read on more on the article :
                    Inherit Good Genes
                    Change Your Genetic IQ with Meditation
                    Don’t Be Normal and Overcome a Great Challenge : Morcheeba - Be Yourself (lyrics) - YouTube
                    Once You Overcome Hell, Embrace Heaven
                    etc....
                    in other words : Just go with your Flow
                    Pablo Cruise | Zero to Sixty in Five - YouTube
                    • from: http://www.energeticforum.com/psychi...tml#post178376
                      found the book mentioned previously: THE THEORY OF CELESTIAL INFLUENCE:Man, The Universe, and the Cosmic Mystery by: RODNEY COLLIN[/B]
                      http://www.bibliotecapleyades.net/ar...linfluence.pdf
                      some really great quotes in it
                      The whole world of six dimensions is filled with His bounty: wheresoever
                      thou lookest, it is making Him known.
                      JALLALEDIN RUMI: THE MATHNAWI, BOOK III (VERSE 3108)
                      Look how the floor of heaven Is thick inlaid
                      with patines of bright gold:
                      There's not the smallest orb which thou behold'st But in
                      his motion like an angel sings, Still quiring to the young*
                      eyes Cherubins;
                      Such harmony is in immortal souls.
                      SHAKESPEARE: THE MERCHANT OF VENICE (ACT. V, SCENE l)
                      All the progress obtained by our cerebral effort consists in the ascertaining
                      of material facts by ridiculously imperfect instruments, which make up in a
                      certain degree however for the inefficiency of our organs. Every twenty years
                      some unhappy enquirer, who generally dies in the attempt, discovers that the
                      atmosphere contains a gas hitherto unknown, that an imponderable,
                      inexplicable, unqualifiable force can be obtained by rubbing a piece of wax
                      on cloth; that among the innumerable unknown stars, there is one that has not
                      yet been noticed in the immediate vicinity of another which has ... Well, what
                      about it?
                      Our diseases are due to microbes? Very well. But where do those microbes
                      come from? And what about their diseases? And the suns, whence do they
                      come?
                      We know nothing, we understand nothing, we can do nothing, we guess
                      nothing. We are shut up, imprisoned in ourselves ...
                      GUY DE MAUPASSANT: NOTEBOOK, APRIL 7, l888
                      but the introduction sums it very well:
                      INTRODUCTION
                      IN EVERY AGE MEN HAVE TRIED TO ASSEMBLE ALL THE KNOWLEDGE
                      and experience of their day into a single whole which would explain their
                      relation to the universe and their possibilities in it. In the ordinary way they
                      could never succeed. For the unity of things is not realisable by the ordinary
                      mind
                      , in an ordinary state of consciousness. The ordinary mind, refracted by
                      the countless and contradictory promptings of different sides of human
                      nature, must reflect the world as manifold and confused as is man himself. A
                      unity, a pattern, an all-embracing meaning - if it exists - could only be
                      discerned or experienced by a different kind of mind
                      in a different state of
                      consciousness
                      . It would only be realisable by a mind which had itself become
                      unified.
                      • are you familiar with :
                        About the Masnavi
                        The "Masnavi" is Rumi's greatest poetic work, composed during the last years of his life. He began it when he was between the ages of 54-57 [about 1258-1261]1 and continued composing its verses until he died in 1273 (with the last story remaining incomplete). It is a compendium of sufi stories, ethical teachings, and mystical teachings. It is deeply permeated with Qur'anic meanings and references. Rumi himself called the Masnavi "the roots of the roots of the roots ( Fractal ) of the (Islamic) Religion... and the explainer of the Qur'an
                        The Masnavi is divided into six books, and Rumi wrote prefaces for each book. The earliest complete manuscript (the "Konya manuscript") was completed in December, 1278 (five years after Rumi's death). In a recent printed edition of this manuscript (by Dr. Tτfξq Sobhβnξ), the total number of lines is 25,575 (Book I, 4019 lines; II, 3721; III,4811; IV, 3855; V, 4240; VI, 4929) R. A. Nicholson was the first to translate the entire Masnavi into English (1926-34). Unfortunately, he did not have access to this earliest manuscript until he had translated through Book III, line 2835. From line 2836, onwards, however, his printed edition is based on the Konya manuscript. As a result,the first two and a half books of his translation are based on less earlier manuscripts which contain numerous "improvements." (In Nicholson's printed edition, the total number of lines is 25,632 (Book I, 4003 lines; II, 3810; III, 4810; IV, 3855; V, 4238; VI, 4916.)
                        • here is a nice synch for you
                          • https://www.forbiddenhistory.info/?q=node/130
                            Radioactive Remains from 8-12,000 Years Ago
                            Substantiating the Pakistan/India texts that apparently describe atomic attacks is an amazing find found in the prehistoric Indian cities of Mohenjo-daro and Harappa. [Pakistan's Indus Valley] On the street level were discovered skeletons, appearing to be fleeing, but death came too quick. They were found to be highly radioactive, on a level comparable to Hiroshima and Nagasaki. Yet there are absolutely no indications of volcanic activity, and it appears that both cities were destroyed at virtually the same time.
                            Mohenjo-daro - Wikipedia, the free encyclopedia Coordinates: 27°19′45″N 68°08′20″E
                            Harappa - Wikipedia, the free encyclopedia Coordinates: 30°38′N 72°52′E
                            play guitar ;D
                            Mysterious and Strange Archaeology Discoveries That Science Cannot Explain | Socyberty
                              p183
                              Thus in the cosmic cycle of functions, no matter on what scale they may be taken,
                              three parallel lines of development may be seen, beginning in different places
                              - the
                              first, based on the development of solid or physical matter, which begins at point 9
                              ; the
                              second, based on the development of air or atmosphere, which begins at point 3;
                              and
                              the third, based on the transmutation of light or perceptions, which begins at point 6.
                              What the cycle of respiration and the cycle of the transmutation of light imply on the
                              scale of the Solar System is difficult to say; but that some such cycles exist -parallel to
                              the astronomically recognized cycle of solid or physical bodies -is clear enough.
                              Man lives and develops by the parallel assimilation of food, air and perceptions. The
                              Solar System consists of a parallel development of solid spheres, atmospheric spheres,
                              and spheres of light. And in fact this parallel development of three different levels of
                              matter, originating at different points, is a fundamental feature of the universe and one
                              which enables the inevitable falling away of any single line of development to be
                              magnificently overcome.
                              from the Table of Content : 21 Chapters
                              III THE SOLAR SYSTEM
                              VI THE HARMONY OF THE PLANETS
                              IX THE WORLD OF NATURE
                              XII THE SIX PROCESSES IN MAN (i)
                              XIII THE SIX PROCESSES IN MAN (ii)
                              XV THE SHAPE OF CIVILIZATION
                              XVIII THE CYCLES OF CRIME, HEALING AND
                              CONQUEST
                              XXI MAN IN ETERNITY
                              ps: Thank you Eep² ..... for your discovery of the circles
                              • Harvest Moon Meets Uranus in the Sky Saturday: How to Watch Online | Space.com
                                The Harvest Moon will float just above the planet Uranus in the sky this weekend, and skywatchers can get a great look at the celestial show without even going outside.
                                Major Astrology Events in August 2012, Astronomy Events, Celestial Events - Truthstar
                                Mars parallels Pluto on September 29, 2012; Venus squares Dragon’s Head on September 29, 2012; Sun squares Pluto on September 29, 2012.
                                Mercury parallels Saturn on September 30, 2012
                                Solar flares today
                                Today, 4 solar flares were observed:
                                Active region Begin, UT Max, UT End, UT
                                Flare of class C1.0 1575 00:07:00 00:10:00 00:12:00
                                Flare of class C1.0 1577 00:42:00 00:45:00 00:48:00
                                Flare of class M1.3 1583 04:27:00 04:33:00 04:42:00
                                Flare of class C2.9 1577 06:34:00 06:45:00 07:10:00
                                Solar flares yesterday
                                Yesterday, 11 solar flares were observed:
                                Flare of class C1.2 1575 06:17:00 07:53:00 07:59:00
                                Flare of class C1.2 1577 07:50:00 07:53:00 07:56:00
                                Flare of class C1.2 1577 08:52:00 08:57:00 09:05:00
                                Flare of class C1.2 1580 10:24:00 10:30:00 10:36:00
                                Flare of class C1.1 1577 13:23:00 13:39:00 13:49:00
                                Flare of class C1.6 1577 15:37:00 15:47:00 16:01:00
                                Flare of class C1.4 1575 17:09:00 17:19:00 17:23:00
                                Flare of class C1.2 1575 17:34:00 17:38:00 17:43:00
                                Flare of class C1.4 1575 17:46:00 18:09:00 18:21:00
                                Flare of class C1.2 1575 18:37:00 18:47:00 18:57:00
                                Flare of class C1.3 1577 20:55:00 20:58:00 21:04:00
