  • Numerically , it makes sense and also biologically .... our circadian cycle controls our mood thus our Chakras .... will repost it after
    57,6 is one earth hour
    that is your Internal Clock .... the Clocks are material objects .... they only give you an Average ..... Principle of Rhythm
    Shin the Dragon Storm ..... liking it very much
    Note the Quartz in the clock ...... quartz is 13 in NUM
    Originally posted by Michael C View Post
    Ohh... this revealed a lot of information, although I'm not sure what it means.
    The obvious:
    Then Saturn, Chronos, 13. But our chronometers only goes to 12.
    Then I remembered a fact about Ley lines, they carry both polarities but shift dominant polarity every 57 minutes circa, according to some sources. So 57 minutes or there about would be the "correct" length of 1 hour, if 1 hour had anything to do with nature. 1440 (HM6) is the number of minutes in one full calendar day, and divided by 25 we get 57,6 minutes per hour. The hourly cycles in one day is 25. We could pull down the length of seconds too but it is not necessary, 57,6 is one earth hour (right now) and keeping it so makes us correctly timed.
    I'm not sure where this will lead, I just recieved these thoughts.
    “Signs and symbols rule the world, not words nor laws.” -Confucius.
    • CHAPTER XI
      RHYTHM
      "Everything flows out and in; everything has its tides; all things rise and fall; the pendulum-swing manifests in everything; the measure of the swing to the right, is the measure of the swing to the left; rhythm compensates." Gnostic.Org: The Kybalion
      The beat goes in the brain: Visual system can be entrained to future events
      (Medical Xpress)—Like a melody that keeps playing in your head even after the music stops, researchers at the University of Illinois's Beckman Institute have shown that the beat goes on when it comes to the human visual system.
      "In nature, rhythmicity is everywhere, so it makes sense that our brain has evolved to be sensitive to rhythms in the world and to be able to latch on to them to improve neural processing," Lleras said. "It's very nice to be able to show that not only does the brain work in this oscillatory fashion but that we can harness that property that is inherent to the brain and use it to control the brain's response."
      Tuning the brain: How piano tuning may cause changes to brain structure
      (Medical Xpress)—Working as a piano tuner may lead to changes in the structure of the memory and navigation areas of the brain, suggests new research funded by the Wellcome Trust. In a study published today in the 'Journal of Neuroscience', scientists show that these structural differences correlate with the number of years of experience a piano tuner has.
      Piano tuning involves listening to the sound of two notes played simultaneously (a two-note chord) and 'navigating' between sequences of chords in which one note is already tuned and the other has to be adjusted. Interaction between the sounds produced by the two notes produces a wobbling sound (known as a 'beat'). Tuners detect the frequency of this fluctuation (the 'beat rate') and adjust it so that the two notes are in tune. Since different combinations of notes in a chord produce different frequencies, tuners use these beat rates as a form of acoustic 'signpost' in the virtual 'pitch space' of a piano to help them tune subsequent notes in a systematic manner.
      Sundeep Teki from UCL, joint first author of the study, explains: "Piano tuning is a unique profession and this motivated us to investigate physical changes in the brain of tuners that may develop over several years of repeated acoustic practice. We already know that musical training can correlate with structural changes, but our group of professionals offered a rare opportunity to examine the ability of brain to adapt over time to a very specialised form of listening."
      The researchers found highly specific changes in both the grey matter (the nerve cells where information processing takes place) and the white matter (the connections between cells) within a particular part of the brain: the hippocampus. These changes significantly correlated with the number of years that tuners have been performing the task. The changes were not related to age or to musical expertise. In fact, musical expertise and perfect pitch are not necessary for the basic skill practised by tuners.
      Researchers devise a new way to plot circadian clock
      (Phys.org)—Everyone has an internal clock, that mysterious process which controls sleeping and hunger patterns, but now researchers are finding out that because the internal clock also controls metabolism, it would be helpful to be able to easily chart out a person's personal rhythm because it appears many drugs work better or worse at certain stages of their cycle. Until now, charting out a person's clock has involved taking blood samples every twenty minutes or so over a twenty four hour period and measuring melatonin levels. Now new research by a team in Japan has found what appears to be an easier way. They measure, as they describe in their paper published in the Proceedings of the National Academy of Sciences, certain metabolites using just two blood samples over a 12 hour period to prduce an accurate clock.
      Circadian rhythm - Wikipedia, the free encyclopedia
      A circadian rhythm is any biological process that displays an endogenous, entrainable oscillation of about 24 hours. These rhythms are driven by a circadian clock, and rhythms have been widely observed in plants, animals, fungi and cyanobacteria. The term circadian comes from the Latin circa, meaning "around" (or "approximately"), and diem or dies, meaning "day". The formal study of biological temporal rhythms, such as daily, tidal, weekly, seasonal, and annual rhythms, is called chronobiology. Although circadian rhythms are endogenous ("built-in", self-sustained), they are adjusted (entrained) to the local environment by external cues called zeitgebers, commonly the most important of which is daylight.
      see also astrotheology
      The clock watcher: Circadian rhythms research is shedding light on the causes of disease and aging
      ... also why you should eat vegetables and fruits of the Season
      All is analogy
      Plants use circadian rhythms to prepare for battle with insects
      In a study of the molecular underpinnings of plants' pest resistance, Rice University biologists have shown that plants both anticipate daytime raids by hungry insects and make sophisticated preparations to fend them off.
      • The Prophet said that women
        totally dominate men of intellect and possessors of hearts,
        But ignorant men dominate women,
        for they are shackled by the ferocity of animals.
        --Rumi
        truly now i understand ..... on so many levels .... if you only knew .... how beautiful Women are ..... and how sad it is to see them in the state they are in today .... for they also reflect you and the state of your Right Brain
        sometimes ATS posts some interesting comments .... .... which seem to reflect a trend ( awave if you prefer ) , i noticed evolving for the past few years ' say a couple ) ... from my perspective ....
        in a dual world ..... the poles tend to separate overtime ( see walter russell work ) ...
        Yeah, sure, I'd like a girlfriend. Just like i'd like a Lamborghini., page 1
        from experience .... I've seen many take the short cut ... and usually end up regretting it .... for both sides
        ps: it is very likely that the female of the above story is not quite satisfied with her vagina ( see designer Vagina ) ..... applicable also to Male Poles ..... pun intended ..... Pole Designer exist too
        New study finds clients want real love from sex workers
        makes sense
        • Note the Quartz in the clock ...... quartz is 13 in NUM
          Ah, beautiful, the "excess" minutes between 57,6 and 60 spread out all over the face of the clock... I wondered how on earth to get a 25th hour into our present 12 times 2 cycle. An odd hour left. But it is actually represented today.
          I wonder if the earth pulse had another interval back when the day got it's 24 hours from the beginning?
          • Originally posted by Michael C View Post
            http://www.scribd.com/deleted/81212655
            1.Do not think dishonestly.
            2. The Way is in training.
            3. Become acquainted with every art.
            4. Know the Ways of all professions.
            5. Distinguish between gain and loss in worldly matters.
            6. Develop intuitive judgement and understanding for everything.
            7.Perceive those things which cannot be seen.
            8. Pay attention even to trifles.
            9. Do nothing which is of no use.
            trifles can be synchronicities when put together
              Indeed , it needs some more tuning ..... Michael C
              and It starts with empathy for oneself and one's "imperfection"
              here is what Empathy does for a person ...... Dr Vogel demonstrates it very well
              MonsieurM,
              I know you appreciate Marcel Vogel's work.
              Ran across this newly uploaded video that contains dowsing rod demonstrations by Dr. Vogel. It was shot in 1986.
              https://www.youtube.com/watch?v=ghBwSlRI4Hg
              Marcel Joseph Vogel (1917--1991) was a research scientist working at the IBM San Jose Advanced Systems Development Division Los Gatos Lab (actually located in San Jose) for some 27 years. He is sometimes referred to as Dr. Vogel.
              IndianaBoys
              • let's play a bit more :
                The following are the arts to be studied, together with the Kama Sutra:
                The art of understanding writing in cypher, and the writing of words in a peculiar way
                The art of speaking by changing the forms of words. It is of various kinds. Some speak by changing the beginning and end of words, others by adding unnecessary letters between every syllable of a word, and so on
                Knowledge of language and of the vernacular dialects
                Shall we Dance
                Anita Ward - Ring my bell Lyrics (Requested) - YouTube
                Tibetan singing bowls - YouTube
                TOGETHER = TOG ETHER
                tog - Wiktionary
                TOG
                Noun
                tog (plural togs)
                A cloak.
                Clothes.
                A unit of thermal resistance, being ten times the temperature difference (in °C) between the two surfaces of a material when the flow of heat is equal to one watt per square metre
                Noun
                tog n (singular definite toget, plural indefinite tog or toge)
                train
                expedition
                Scottish Gaelic
                [edit]
                Verb
                tog (verbal noun togail)
                build, erect
                lift, haul, pick up, hoist
                rear, bring up, raise (a child)
                rouse, stir
                [edit]
                Derived terms
                dian-thograch - ambitious
                togarrach
                tog dealbh - photograph (verb)
                tog fianais - demonstrate
                ETHER :
                (ancient philosophy and alchemy, uncountable) A classical physical element, considered as prevalent in the heavens and inaccessible to humans. In some versions of alchemy, this was the fifth element in addition to air, earth, fire and water.
                (archaic, physics, uncountable) A substance (aether) once thought to fill all space that allowed electromagnetic waves to pass through it and interact with matter, without exerting any resistance to matter or energy (disproved by Einstein in his Theory of Relativity).
                (poetic or literary) The sky or heavens; the upper air.
                So Pull yourself "TOG ETHER "
                Morcheeba - Be Yourself (lyrics) - YouTube
                  you would be surprised how very few people are themselves ..... 24/7 ..... most would give excuses such as we live in a society and we have to act in such and such manner .... examples are aplenty .... being yourself .... two words that will open a new world for you to explore ..... simply put YOU
                  drop the greek masks .... and you will see
                  and stop beating around the Bush
                  • Dancing the night away - The Motors
                    So you want to believe
                    Everything that you read
                    And you think that you're makin' the grade
                    And just when you're getting it made
                    You're still in love with her
                    She'll ask you to kiss her
                    Hopin' you'll miss her
                    By takin' your mind off the road
                    Just when you're ready to go
                    You turn your back on her
                    You're fixin' your mind on the road ahead
                    At last you're gonna be free
                    You love her you kiss her
                    Be glad that you miss her
                    So you turn on the smiles
                    'Cause you think it's the big time
                    The cost just is more than the star
                    And nobody knows who you are
                    Don't even know your name
                    At last they accept you
                    They kiss and caress you
                    And ask you to reach for the sky
                    And just when you're ready to die
                    They turn their back on you
                    So they put you in Hell
                    In Survival Hotel
                    Where they wish you would die from the cold
                    They know you belong to a travelin' show
                    Great film clip with Marcel Vogel, thank you!
                      CNN Hero Narayanan Krishnan - YouTube
                      wow ............ an amazing man ..... not 1/100th the man he is
                      • you know lately , i Have been thinking about past lives ...... and wonder what was the road taken by Me / Monkey .....
                        • Truly amazing, and yet, the right thing to do is the simple thing to do. A great man.
                          A humouresque reply from me, in a strange language but with a message that makes sense in the discussion we're having. He sings: "I can't stand it anymore, I want my mom and dad".
                          Markoolio - Jag orkar inte mer - YouTube
                            .......... mine looks to be digital rather than analog
                            Now i Understand what happened to Fulcanelli ...... the past of him and the future him merged with his present ..... in Platonic Talk ..... He merged with his Oversoul
                            ..... i think .... pure speculation for now
                            • the past of him and the future him merged with his present
                              It makes perfect sense that it could be possible to someone. It's a very educating thought.
                                Quetzalcoatl - Wikipedia, the free encyclopedia
                                If you can tune to yourself ( empathy ) ..... you can tune to your past self and your future self ..... thank you MichaelC
                                really ........ how about some bad memories .... how do they make you feel .... how about good memories .... it is called tuning in
                                how about the future ... how does a grim future makes you feel .... how about winning the future lottery .... and what would do with it .... got you to think about it
                                play 369 .... let's see if it doesn't mess the system .... TOG ETHER
                                have fun and surf your wave
