MagMotor vid on YouTube
  • MagMotor vid on YouTube
    I haven't seen this here. Kinda looks like a possible hoax cause he
    claims to have a monopole magnet. Which I think all he has is a
    diametrically magnetized magnet giving the illusion of a monopole magnet.
    Motor seems to work. But I'm thinking he may be utilizing a battery in the
    form of a homopolar motor to make this work hidden in the wood block.
    If in fact it ISN'T a hoax, it should be easy to replicate.
    Easy to make free energy, perpetual motion machine using monopole magnet. - YouTube
    Brad
    I think he works with Batteries, on his Page he is stating, that he is a Magican, an Illusionist.
    Even that monopole Magnets not really exist, and for sure not shaped in the Form he use,
    I guess he use a normal Magnet, scraped the Isolation at one half from the Wires and it runs like a simple DC motor.
      Well,
      If he's an illusionist and challenge us, then I don't mind. lol
      I think it's a simple motor. Battery is slotted through in the back of the wood. Even if that magnet is a monopole, he only use one pole. So does it matter? lol The measured voltage is 2.52V steady so it's highly a battery. He says voltage drop as it slow down, but it doesn't. Then he lifted that probe up simulated a zero voltage. He sanded the nails so the terminal is now go through the neo magnet to the other nail back to the battery. It's neat though.
        Where does it say he's an illusionist?
          ::Pointing fingers =====> Joit ::
          But if he doesn't say it's a trick, then I reserve a possibility for him.
            If a monopolar magnet was discovered it would change science as we know it.... that would be OK but dont you think it would be all over the newspapers?
            I like the demo though ... it illustrates cool possiblities.
              FAKE!!!
              Come on guys do a little research before posting this stuff.
              I found the pics showing how it is faked and if you can read the rather fuzzy text it says how. Without buying access to that site I couldn't get a better image. This is from the guy who made the video. He's an inventor - that is inventor of magic tricks and illusions.... LOL
                Monopole courtesy Marko Rodin
                Marko Rodin shows you how to make a Monopole.
                Marko Rodin Permanent Monopole Magent (biased Poles) - YouTube
                Marko Rodin | Facebook
                Vidbid
                VIDBID
                  His Homepage
                  Freelancer Magican.
                    I actually dont think, the Rodin Coils creates a Monopole, but the opposite Pole is sucked into the Coil. Its anywhere deep inside or even maybe outside where usual the other Pole appears. The winding itself should create usual a opposite Pole when they get powered.
                    Even when some claim, they have found now the magnetic monopole,
                    Magnetic Monopoles Detected In A Real Magnet For The First Time
                    i dont think it is really possible. Anywhere the opposite Pole will allways appear.
                      Originally posted by Joit View Post
                      His Homepage
                      Freelancer Magican.
                      How did you find this guy? I looked all over. Thanks.
                        The Link was at the end from the Video
                          Oh. oooops. My bad. Need to pay closer attn.
                          Thanks again.
                          • #14
                            A friend of mine described over the phone what sounds like
                            a magnet magnetised N-S-S-N through its thickness, which looks
                            to me as good as a monopole magnet. (He got it on Ebay).
                            • #15
                              Vidbid
                              Maybe its just me but im looking for the trick all the time and what i see here is the first drill that shows north on the shank end clearly has a reduced shank which actually looks like its been modified and the second one showing a north at the tip end also looks to be modified at the tip. Surely if this were as real as it looks the demo would simply show that the north pole existed at either end of the same drill. Also if the north pole was focused in the coil as explained then the south must be outside the coil if this was the case then surely should not the drill display a north pole at both ends at the same time ??
                              Garry
