Overunity Magnetic Power Supply
  • Overunity Magnetic Power Supply
    Found this on the tube:
    Not much info on it, but it looks interesting!
    Overunity Magnetic Power Supply - YouTube
    His description:
    Unit puts out around 1-2kV power running on the earths magnetic frequency!
    I can't at this stage unfortunately. But it's about using the right amount of coil though to generate the correct frequency and having the unit open/close itself while outputting the 1-2kV of power generated. The unit has some other strange effects as well.
    Interesting video. Some particulars I see:
    - 4 toroidal magnets stacked sideways on steel axle
    - magnets spin opposite single wound copper wire coil (28 or 30 AWG?)
    - axle spins within steel housing, allowing magnetic flux to travel
    - possible commutator on side of axle?
    Unknowns:
    - copper coil air or metal core?
    - what is connected to copper coil?
    - what is making magnets rotate? is it a pulse to the copper coil causing
    magnetic field that bucks against rotor (mag toroids), causing it to turn?
    Taking a stab--
    - is it possible that a Joe Cell is connected in parallel to a capacitor which
    pulses into the copper coil, causing the mags to rotate, creating further
    induction?
    YT user dreamyear has a few videos that might give some hints as to the interaction of metal, coils and magnets in this apparatus
    dreamyear - YouTube
    Bob
      It looks like 4 magnetron magnets from a microwave oven on the axle. Also looks like a set of old car distributor points on the side being opened and closed by a cam. Interesting ....
        It's basically a "claw pole" motor very similar in design to the basic claw pole alternators. Almost all automotive alternators use this design.
          His description:
          This is a Joke ? No Measurements no load, just a claim. Please refrain from
          posting these things, is it running from a battery ? Where is the
          electrical output taken from and where is the input to the driving coil ?
          Without these things shown it is just a short video of a motor turning with no
          indication of what is supplying the input power to the coil.
          Is it a generator or a motor ? on one side the rotor has a cam and on the
          other it looks like there is a pulley. Is there something turning the pulley so
          the thing outputs mV from the coil or is the coil powering the rotor.
          Ignore the claim and look at what the device does.
          If it's a generator then what is turning the rotor ?
          If it is a motor then where does the output come from ?
          P.S. We should have a special thread to post these kinds of things in, maybe
          Titled something like, Is this real, does it do what is claimed ?
          He likely won't give more detail because it would show his claim is all hot air .
