Sefe, Inc. Power the Entire World
SEFE has created a portfolio of issued and pending patents, making it first mover and industry leader, right out of the gate. They are:
USPTO Patent Number 7,855,476 – Atmospheric Electrical Generator
A mechanism to tap an electrical source which uses an aircraft (preferably a lighter than air balloon) tethered by a conductive line. The conductive line is extended/withdrawn by a winch motor to adjust the altitude of the aircraft. The conductive line is isolated from the ground and an electrical conductor is connected to the conductive line and to an electrical load. In this manner, static electricity generated in the atmosphere is gathered for use. This patent was issued by the USPTO on December 21, 2010.
USPTO Patent Number 8,102,078 Dynamic Electrical Converter System
A dynamic electrical converter system configured to receive a variable voltage input which is then converted to a proper electrical configuration for a load. The converter assembly utilized multiple converters, each of which is configured to accept a unique range of voltages and from these voltages creating the desired electrical output configuration. A monitor checks the incoming voltage and by controlling switches going to each of the converters, selectively closes the circuit to the appropriate converter; thereby, routing the incoming voltage to the converter capable of addressing the incoming voltage. This patent was issued by the USPTO on January 24, 2012.
USPTO Patent Number 8,102,082 Atmospheric Static Electricity Collector
An antenna for the collection of atmospheric static electricity in which an electrically conductive hub is suspended from a balloon or blimp via a tether. The hub is either solid or uses a spoke/arm arrangement. A number of rods extend from the hub enhance the collection of atmospheric static electricity. The collected atmospheric electricity is conducted from the rods to an electrical connection where the electricity is conducted to earth via a conductive line. This patent was filed with the USPTO on January 24, 2012.
USPTO Patent Number 8,102,083 Atmospheric Electrical Generator with Change of State
A mechanism to tap an electrical source which uses an aircraft (10) (preferably a lighter than air balloon) tethered by a conductive line (12). The conductive line (12) is extended/withdrawn by a winch motor (13, 14) to adjust the altitude of the aircraft (10). The conductive line (12) is isolated from the ground (17) and an electrical conductor (6) is connected to the conductive line and to an electrical load (5). In this manner, static electricity generated in the atmosphere is gathered for use. This patent was filed issued by the USPTO on January 24, 2012.
