Now Murlin, I appreciate the smiley face, but it was not 3 amps while charging. The 20W bulb was a 12V bulb....no charging on that one. I'm using the 6.3 V RS bulb which is either a 150 or 300 ma bulb with the charging. Time will still tell on the final results, but it is looking good. JB said we would get it eventually....where is he!!!!
Hi guys, so as not to detract from the work going on in this thread i've started a new thread over at hereticalbuilders, and uploaded an initial video.
Can you post a schematic of how you have changed your circuit? I have a copy of a circuit you posted a while back that shows two bridges and six transistors. I am not sure if this is the same one you changed to try to simulate Bit's circuit or are you talking about another one. Also I am confused about which transistors you are actually turning on. And one last question if you don't mind, what size batteries are you using, because 3 amps or so is way more than I think I could safely pull from my 12volt 7ah batteries.
Thanks for any help you can give, Carroll
@Carroll,
I'm using 21194s as the NPNs. I'm not the best schematic drawer, but here is is. Optos are H11D1s as per JB. The diodes are 4001s, but I used what the program had in it's libraries. So substitute as I've indicated if you wish to duplicate. It isn't written in stone yet, as Bits and I discover daily, so use your own imagination and intuition.
I'm using 17ah batteries. It is still too much for the batteries according to the C20 rate, but it stays pretty steady with the 20W bulbs. With the 6V bulbs (small aperage) it gains a little. We all must do our testing...mine is just one version. I have others that work as well, but the theme is always the same.
It is the Bedini circuit minus the two bottom transistors. I am using a different processor than Bits and running it from a separate power supply, for now, so it is definitely different. I think the currents are flowing both ways on the bottom and the top transistors come into play when we switch them, but I don't know all the details on them. Bits has been instrumental in my latest progress, got me thinking about how this thing "really" works, so hat's off to him .
Leroy
P.S. The amperage is dependent on the load, so you can always go down on the load to compensate for what you "think" your batteries can handle.
Ps, who is the member who's name doesnt come up? every now and then it says something like 8 members viewing, but there's only 7 member's names..
Inquorate,
I think you may be more theoretical than the rest of us, but you show great stuff and have some good ideas. I'm an idiot, just trying to duplicate what JB has told us we can make work. Keep up the posts...I'll try to post less! I don't really believe that anyone cares what I have to say either! So, this is an outlet for my absurdities.
Leroy
I didn't mean it like that leroy, i enjoy your ramblings
What i meant is that the method of tricking the aether to give up free charge in the 4 battery tesla switch, vs the 3 battery bedini coil hybrid, seems to be quite different.
I believe the 3 battery uses the ion's inertial properties and the extended magnetic field 'action time' of the collapsing coil.
But i have not yet worked out how the 4 battery switch is working, unless it's like a square fish tank being shoved side to side; the wave hitting the glass of the tank and the next 'push' both coinciding, until (if the timing is right) the wave builds higher and higher.
This builds a floating voltage, or free charge that bounces back and forth on top of the batteries.
So, in essence the two systems unlock the aether, zpe field, in quite different ways. 2 different beasts.
So when i asked if i should continue to post my progress, it was because i don't want to be confusing people by racing a donkey in a horse race, as it were.
Or maybe this post will help define the 2 different methods. I'll just keep posting my progress here anyway.
Love and light all
@ Inquorate Great video. I think you are on to something with the pulse you are getting to the batteries. I agree with Leroy, KEEP POSTING! I don't always comment about what someone posts because some times it takes me awhile to figure out where they are coming from in their approach to the problem. Later I find they are truly making progress so I back up and study their idea some more. I have learned a lot from this thread and the different approaches that have been taken.
@ Leroy Thanks for the information Leroy. Unfortunately I can't seem to get the pdf file to work for me. I keep getting an error that says it didn't download correctly or it is corrupted. I tried 3 times to view. It says by the file it was looked at 24 times so I think maybe the problem is on my end or maybe something has happened to the file. Maybe someone else can try it and see if it still works.
Congratulations to both you guys and Bits too as all of you seem real close to a better understanding of what works and what doesn't.
Good luck, Carroll
Good luck, Carroll
No, I think it is broken. I could not download it or view either.
Thanks Leroy it is working now. I got it. I have to get some work done around the house and then I want to give it a try. I have a board set up with optos and MJL21194's that I can hook up to the batteries in any way I want using jumpers. The optos are being driven by the picaxe chip so I can program it to do most anything I need it to in the way of timing and duty cycle.
Thanks again, Carroll
Has anyone ever heard their transistor play a tune? Mine are singing to me. I know that sounds weird, but they are, playing a tune with the pulsing going through them and it is the transistors, not the digital board.
