Originally posted by Matthew Jones
I have been looking again at the Benitez patent, and it seems that John Bedini is a bit behind the eight ball with this one in regards to who started what. I am not sure that a micro analysis of TS procedure is going to result in a practical outcome. Switching a few hundred milliamps is a lot different than switching several hundred amps.
Benitez uses his "charging circuit as an alternator, that is, constantly topping up his NiFe batteries. A problem for these batteries is that they can give up their potential very quickly. This is why I think that Benitez came up with the original idea. He mentions portability of power plants.
Benitez does not show what he does with the high frequency pulses that he salvages from the load. It looks like he drives these straight into the batteries! My reading is 10kv. I know that the hydroxyl solution of the NiFe works differently to that of the sulphuric acid solution but they still both produce hydrogen. He must have some way of converting this potential back to a usable voltage: unless he maybe has created a very high impedance. As he is using Tesla's high frequency theory, the solution for his is to ground his power unit and draw the excess current from an earth potential.
This would be more difficult to achieve using an "isolated" power supply such as an EV. So, the solution is to manipulate the pulsing technique to draw the excess energy required in through the "Ether" and charge caps to unload across the batteries.
Where we are ahead of Benitez is that we have at our disposal the means to automatically monitor the switching battery potentials and switch battery packs and be able to adjust the flow of charge across the batteries. Should make life a lot easier.
I am reconstructing my Battery Switch to run with relays in the first instance, and, I am having a special rotary switch made to replace these relays. I have resurrected the charging notes I made some time ago, which surprisingly enough, are very similar to those of Benitez, A few major differences that I will elaborate on if they work out. Mainly technique.
Rob
