@scratchrobot
Great video, the pulses go up to 4A !!!
This is amzing because you don't disconnect the input !
Can you explain the phases through which goes your circuit ?
Is it the circuit from the patent ?
Can you detail your parts please ?
I don't understand why your pulses are higher on output if you are just pulsing normally?!
Under load your input goes up to 600mA and your output pulses up to 4A, this should be due to the floating caps pumping vacuum energy, but because you are not disconnected from the input it shouldn't do that IMO ?!
Definitely a veeeeery interesting setup man
Do you have an oscilloscope to see the pulse profile ?
@Xenomorph
Yes it is strange indeed, the caps charging from vacuum energy works on a SG under the NEGATIVE energy pulse from the collapsing magnetic field, but in this solid state charger patent, Bedini shows that the effect can be done with POSITIVE energy pulses in a capacitor.
So it seems that after the pulse the capacitor becomes a NEGATIVE resistor
Now I think that scratchrobot circuit is doing exactly that, as described in the patent
The effect will be better when he will disconnect the input after the pulse, as Bedini describes, and more important it won't increase the input pulse like it is the case on his latest video, so the gain will be even higher, the input not being affected.
I think if Bedini is right and the capacitor becomes a NEGATIVE resistor after a certain kind of POSITIVE pulse is sent to it, this is the greatest discovery in electronic since ever !
I hope he is not using a NEGATIVE resistor or a NEGATIVE oscillator as he was doing in his HI-FI sound filters in the past, because it will make the thing almost impossible to reproduce, even if now he explained how to manufacture them.
Of course no mention of NEGATIVE elements in his patent, because examiners would never accept his patent. But may be he is using one in the working device ...
So lets concentrate to study, improve and reproduce scratchrobot's circuit, because so far HE HAS THE SAME EFFECT as described in the patent and shown on Bedini's videos
@Xenomorph
