Oh ya I did a 5us off time. I just pulse a pin that wasn't being used. I forgot that.
Matt
Thx Matt.
I've read this page RADIANT ELECTRICITY about 20 times recently and always get more ideas from reading it. A relay produces the same sparking that Tesla is talking about, no?
Matt, you generated the blue lightning with the point contact that you were using on your wheel....I'm thinking we must come up with something to utilize this energy...and redirect it back into our systems.
I've come up with a circuit...playing with it some more to redirect energy back to the front end of a SSG (or other system) and will continue to work on it...the shuttling of energy.
Been quiet out there in EF land.
Leroy
Your talking about the simple motor in my video.
The blue spark shows up in point contacts when you are not discharging the coil into a charge battery. It a regular spark. I don't think its anything like what talked about in the article.
been away for a long while.. trying to catch up on all the messages. wondering if someone might post a summary of knowledge for the tesla switch to date. link to the "official" schematic etc. that would be greatly appreciated.
slloyd
Hey Sonny,
Welcome back to the party LOL!
If only it was that easy. The past few months has seen a lot of people drop off, or go into a different direction. AFAIK, there is no "official schematic", but there have been several spin-offs posted that are based on the "original" schematics that were on JB's pages.
Personally, I've been working closely with a couple of the guys on this thread on TS based circuits that also incorporate several other Bedini based circuits and concepts. Basically, I'm trying to make the best use of a solar panel to charge batteries - including "low light" conditions where the PV panel is outputting very little.
Hello Bits,
I want to replicate the Inverter 2 cap pulser as is. I got hold of the schematic you posted in the thread but cant seem to find the component values post . I clearly remember seeing the post but simply cant find them ... shouldnt be astonishing considering the size of this thread though
The idea is to use the pulsinator in the back end of the window motor circuit to pulse the CEMF into a second battery . Now there is a gang of four university students looking for an interesting project for their final year engineering project and i think the pulsinator could be a great project for them . Can you please help out with component specifications and any other tips ???
Hello Bits,
Bhargav
Bhargav, thanks. I will get you the component list here shortly.
Hey Jeff,
Thanks for the part specs . Ok , i did a bit of shopping today . Couldnt find the below parts :
C3 35,000uf 35V - Is there a hard set rule for uf/V rating . How much can i deviate
C6 35,000uf 50V - How much can i deviate on the uf/V rating
D1 STPS8H100D --- bought MUR8100e(datasheet attached... is this OK?? )
T1 273-1365A --- datasheet attached :says 12VAC output , 450ma transformer with 120Vac input . But the schematic says 56 Vac output . Is something amiss or the circuit setup in schematic right??
I got the 4A rated bridge . I guess this is enough ...
I did find rest of the components
Do let me know your thoughts when you find time ...
Hey Jeff,
C3 35,000uf 35V - Is there a hard set rule for uf/V rating . How much can i deviate You can deviate alot, in fact I am getting better results using a 350uf 350V cap at the moment, just watch the output volts do not exceed the caps rating.
C6 35,000uf 50V - How much can i deviate on the uf/V ratingNot really needed unless you are feeding AC
D1 STPS8H100D --- bought MUR8100e(datasheet attached... is this OK?? )I can only recommend what I have tested
T1 273-1365A --- datasheet attached :says 12VAC output , 450ma transformer with 120Vac input . But the schematic says 56 Vac output . Is something amiss or the circuit setup in schematic right??Nothing amiss, check how I have turned it around in the circuit, primary becomes secondary
I got the 4A rated bridge . I guess this is enough ...That should work
I did find rest of the components Happy building!
Hey Jeff,
Bhargav
I will also post an updated schematic to include "sensing".
Hi all, What kind of waveform are we looking for in a solar setup with SS, I get best results from a trifiler Simple SS drawing power from befor a diode and delivering spikes from the bridge bakck in after the diode but i'm worried if it could harm the panels I have three waveforms.
This is the setup described above SCR on negative line.
