If it is correct that the excess energy effects are due to the combination of a coil and an electrolytic cap, it should also be possible to get an excess energy effect by pulsing a transformer trough a diode in reverse direction, with the other end of the TF primary loaded with an electrolytic cap or a battery:
If you take a relay for the switch, you should be able to pulse-charge the LV Cap C2 using very little current from the source and gain energy which is tapped from the changing electric field being converted to a magnetic field in the coil during the brief moment the electrolytic cap needs for a current to get flowing.
If this indeed works with a relay, you may be able to get a solid state version working. Also see:
http://www.energeticforum.com/renewa...tml#post123752
