Use for the Tesla Switch
  • @vtech,
    can you please post the latest schematic you used in replicating bit's inverter_cap pulser? the one you posted above. coz the links on previous pages no longer work. thanks.
    Shingot
    • Originally posted by shingot View Post
      @vtech,
      Shingot
      Here is the link;
      http://www.energeticforum.com/attach...b_inverter.jpg
      • Successful Tesla Switch Deviation
        Potential Switch Oscillator - Heretical Builders
        just FYI. More people should try this.
        • Thanks bits, im excited to try this out..hehe
          • Jeff, thanks for the link back to your circuit. I have been digging around for it hoping it would resurface eventually. More on topic though, I'm glad to see your advanced ts design that incorporated your battery switcher with other means of charging. It makes me dream of things in my future. Mostly is that I want a hands on model to prove to a few people that this is possible.
            • Bit's, can you provide the values on. ie R1, C1..etc - if its not too much to ask. all i know there is the transistors MJL21194 and 93 and other components with values stated already. TIA.
              I already printed the schematic but some components have no values.
              Shingot
              • C1 - 0.33uF, C2 - 0.1uF, R1 - 120k, R9 - 10k, R2,R3 - 10k, R4 - 22k.
                Vtech
                General D.Eisenhower
                http://www.nvtronics.org
                  Shingot
                  Here is the full parts listing;
                  1n4001-Q1 1n4001
                  1n4001-Q5 1n4001
                  C1 0.33uf
                  C2 0.1uf
                  C4 27,000uf 35V
                  C5 27,000uf 35V
                  Cap-Q1 1.0uf
                  Cap-Q5 1.0uf
                  D1 STPS8H100D
                  D2 1N5408
                  D3 STPS8H100D
                  D4 Bridge
                  D5 1N5408
                  D6 STPS8H100D
                  D9 STPS8H100D
                  DB9
                  J1
                  J2
                  J3
                  LED1 Red
                  LED2 Red
                  LED4 Red
                  Q1 MJL21194
                  Q2 MJL21194
                  Q5 MJL21194
                  Q6 MJL21194
                  Q7 MJL21193
                  Q8 MJL21194
                  R1 120K 1/4 watt
                  R2 10k 1/2 Watt
                  R3 10k 1/4 Watt
                  R4 22k 1/4 Watt
                  R5 330R 1/4 Watt
                  R6 330R 1/4 Watt
                  R8 100 Ohm 1/4 Watt
                  R9 10K pot
                  SW1 Reset E28
                  T1 273-1365A
                  U1 PICAXE-18X
                  U3 LM7805
                  U-Q1 H11d1
                  U-Q5 H11d1
                  U-Q7 H11d1
                  And a sample code (adjustment needed for your individual setups)
                  Main:
                  ;Inverter Section
                  do
                  high 5
                  pause 5
                  low 5
                  pause 40
                  high 4
                  pause 5
                  low 4
                  inc b1
                  readadc 0,b2
                  if b2 > 140 then Pulse
                  loop while b1 < 30
                  b1 = 0
                  goto main
                  ;Pulse section
                  Pulse:
                  high 6
                  pause 30
                  low 6
                  return
                  goto main
                  Good Luck
                  Bit's
                  • Thanks Bit's
                    Thanks Bit's for the parts list. I have always been interested in this circuit. With
                    this info, now I know it could be replicated.
                    FRC
                    • Coming to a Conference Soon, The Multi-Function Tesla Switch (MFTS).
                      Ok gang, here is the first glimpse of the new MFTS that you will be able to view at the upcoming conference in July. In the video, I am showing the functionality used in conjunction with the Batt Swapper. What a neat device.
                      Actual load on the panel was 700ma.
                      Enjoy.
                      Bit's
                      YouTube - MOV01609.MPG
                      • Great again Bits!!
                        Another great video!! You just keep on putting out more and more interesting things. After all the months of working on the TS I can't wait to get to Idaho and find out what the secret is to getting a TS to work like that! Thanks for sharing.
                        Carroll
                        • Sorry for asking this as I haven't kept up here but I don't think I would ever make it through 113 pages to find the answer. Are the latest setups using solid state switching of batteries in Jeff's Machine of Time circuit or are there relays on the outputs of the H11D1's ? Hopefully my question at least makes sense. Seeing the specs on the H11D1's I assume they are using relays or other solid state switching to actually pulse power to batteries. Would that be correct?
                          • Originally posted by ewizard View Post
                            Hi ewizard, yes there are opto's and solid state switching, LCD readout, terminal monitoring, battery charging, loading (day and night) and more. Stay tuned. John K. will be illustrating a bit more.
                            Bit's
                            • Originally posted by Bit's-n-Bytes View Post
                              1n4001-Q1 1n4001
                              1n4001-Q5 1n4001
                              C1 0.33uf
                              C2 0.1uf
                              C4 27,000uf 35V
                              C5 27,000uf 35V
                              Cap-Q1 1.0uf
                              Cap-Q5 1.0uf
                              D1 STPS8H100D
                              D2 1N5408
                              D3 STPS8H100D
                              D4 Bridge
                              D5 1N5408
                              D6 STPS8H100D
                              D9 STPS8H100D
                              DB9
                              J1
                              J2
                              J3
                              LED1 Red
                              LED2 Red
                              LED4 Red
                              Q1 MJL21194
                              Q2 MJL21194
                              Q5 MJL21194
                              Q6 MJL21194
                              Q7 MJL21193
                              Q8 MJL21194
                              R1 120K 1/4 watt
                              R2 10k 1/2 Watt
                              R3 10k 1/4 Watt
                              R4 22k 1/4 Watt
                              R5 330R 1/4 Watt
                              R6 330R 1/4 Watt
                              R8 100 Ohm 1/4 Watt
                              R9 10K pot
                              SW1 Reset E28
                              T1 273-1365A
                              U1 PICAXE-18X
                              U3 LM7805
                              U-Q1 H11d1
                              U-Q5 H11d1
                              U-Q7 H11d1
                              Main:
                              ;Inverter Section
                              do
                              high 5
                              pause 5
                              low 5
                              pause 40
                              high 4
                              pause 5
                              low 4
                              inc b1
                              readadc 0,b2
                              loop while b1 < 30
                              b1 = 0
                              goto main
                              ;Pulse section
                              Pulse:
                              high 6
                              pause 30
                              low 6
                              return
                              goto main
                              Good Luck
                              Bit's
                              hey jeff we have done with the ciruit fabrication on the board but i need to know how to burn the code on the pic , and the code says you will need some modification so what modification should i do in the code..pls reply
                              • Originally posted by blackchisel97 View Post
                                Hi guys, After couple busy nights I finally managed to replicate Bit's IVA according to last revision . I had a little problem with too small transformer getting warm but just found bigger one and swapped few hours ago. I have 10 000uF caps which I'll replace with bigger values as soon as they arrive. Anyways, this is real beauty, works really nice. I'll make a short tube when I get some rest. Been working all night. Big to Bit's, NVisser and everyone for contributing and making this progress possible.
                                [IMG][/IMG]
                                Vtech
                                hey nice to see your iva but if you have used a latest version then what about the schottky diodes i coudnt see them and the bridge . and what is the input voltage you have given on the socket . can you just tell me hou you burnt the code on the picaxe and which code you used.
                                im also trying to implent this, so pls let me know these details.
