@jetijs
I think it's important to consider the properties of any load attached to this circuit. The 6v motor you have attached to this circuit has a commutator which essentially shorts the powered windings to the next set of windings to reduce commutator arcing. As such a certain portion of the input energy is always dissipated in the windings as they are shorted outside the context of the source current. You will find that if an AC motor or low self-inductance coil is used these switching losses do not occur, I have found commutated motors are the least efficient loads we can use for this reason. A low turn brushless RC motor works very well in these types of circuits with very few losses.
P.S.-- I should mention that the brushless RC motor must be timed to the circuit impulses as the means of switching is usually performed by an external 3 phase esc (electronic speed controller). These motors have a really high power density, my outrunner heli motor is 1-1/4" in diameter and 1-1/4" long, it puts out 3/4 hp at 50,000 rpm pulling up to 40amps@14v.
AC
Today I checked the battery voltage. It has run down by another 0.1V, the circuit was running at 160Hz and the small motor as a load whole night. Something is not quite right.
AC
