load voltage very important to charging
I was using a 3.57 volt light to charge. If I don't go through the correct starting sequence when I turn on my commutator the light will blow.
Well I blew my last 3.57 and took a bulb out of a flashlight. probably 5 or 6 volt one.
My batteries wouldn't charge then.
I was surprised that even though I was getting 16 17 volts out of the positive side of the batteries,when I checked the test point before the diode on the positive and out of either neg 2 or 4, the highest voltage I could dial in was 12 .6 volts.
So its kind of tricky getting the potential to go in the direction you want it to.
I will go back to the Shack and get another assortment of bulbs at a lower voltage and see if I can get back to charging mode. I wish I knew how to figure that out without trial an error, but I guess there are always many ways to get from A to B.
On the subject of measuring voltage in the batteries with a volt meter.
I am not sure if this will give us the most accurate picture of what is going on in our batteries.
I think the SG test must be performed on each cell.
It's going to be a PITA but I am pretty sure I have been getting some false readings and might not be charging as much as I thought.
What makes me think that is that that bulb really pulled down the volts real quick in my batteries.
On the flip side though it could just be confirming that I was getting a charge previously.
6 of one, half a dozen of the other.....
regards,
Murlin
regards,
Murlin
