Transduction
  • Transduction
    Recommended Guidelines:
    The topic is transduction.
    Within the scope of this thread, transduction is defined as the the conversion of one form of energy to another form of energy.
    Looking at idea, theories, experiments, practices, nature, or whatever.
    Brainstorming encouraged.
    Radical ideas are not discouraged.
    Offered input is welcomed.
    There are no bad questions with respect to this topic.
    Group norms within this thread are treat each other with respect.
    Object: Question: Is possible to convert electrostatic compression waves into transverse electromagnetic waves?
    Recommendation: Understand the difference: See video
    Object: Question: What are all the possible ways of doing that?
    Recommendation: Look at one method in nature: See video
    VIDBID
    Where is the charge stored in a capacitor?
    What stores the charge? Is the charge actually stored in the dielectric? What if you remove the dielectric and touch the two plates of a capacitor together? What will happen? Will there be a discharge or will nothing happen? See video.
    See Tuks DrippingPedia : Energetic Form Posts
    See Home-made Supercaps
    VIDBID
      Bifilar coils are important.
      Vladimir Utkin discusses two different types of bifilar coils on page 8 of his Free Energy: Nikola Tesla Secrets for Everybody.
      Originally posted by Vladimir Utkin
      The bifilar pancake coil may be the best method.
      The voltage between adjacent turns in an ordinary coil is very low, and so their ability to generate additional energy is not good. Consequently, you need to raise the voltage between adjacent turns in an inductor.
      Method: Divide the inductor into seperate parts, and position the turns of the first part in between the turns of the second part, and then connect the end of the first coil to the beginning of the second coil. When you do that, the voltage between the adjacent turns will be the same as the voltage between the ends of the whole coil!
      Next step: Rearrange the position of the magnetic and electric fields in the way needed in applying amplifying energy (as described above). The method for doing this is - the flat pancake coil where the magnetic and electric field are arranged in exactly the way needed for amplifying energy.
      Tesla patented the bifilar pancake coil in 1894 with Patent #512,340
      Interesting video on the comparison of a Tesla bifilar and a pancake coil.
      Link:
      HTML Code:
      http://youtu.be/mvb39SwTXBE
      Brainstorming:
      stacked Tesla pancake coils
      cochlea
      Notice how the stacked Tesla Pancake coils resemble the cochlea of the inner ear?
      Could the round window of the inner ear be analogous to an earth ground?
      Whereas the earth ground is being the sink for longitudinal magneto-dielectric waves or electrostatic compression waves to exit the system, the round window of the inner ear provides a place for the fluid of the inner ear to be displaced.
      But how do we get the longitudinal magneto-dielectric waves entering the pancakes and exiting to earth ground to bring about displacement electricity?
      VIDBID
        Tesla
        Update 38 - Quest for free energy - Tesla's Disruptive Discharge Coil & Radiant Energy Production - YouTube
        Interesting Video
        VIDBID
          New Dynatron Video
          New Dynatron Video
          New Transformer
          Качаем 100 кг железо ) - YouTube
          VIDBID
            Well, all of this can get confusing in a hurry. Capacitance is a whole realm within itself and I have been lost within that realm for a while now! The dissectible capacitor would have you believe that the charge is stored on the surface or within the dielectric but things are not that simple.
            Look at the electrophorous for example. Charge separation by induction. Removing one of the charges leaving a net charge. Raising of voltage by raising the plate which lowers the capacitance.
            Clearly the charge is caused by electrons or lack thereof on the metal plate. My best guess is that both things happen in a capacitor with a solid dielectric. Electrons (or lack) pile up on the surfaces of the plate and dielectric.
            Ultracaps?... a whole new cavern in the realm to be sure!
            Do we even know what is really happening in energy transfer? What are we causing a displacement of energy in? What really is the media. The aether? What is that really?
            Certainly we are not actually flinging electrons off of a transmission antenna? I know that doesn't work because flying electrons don't "live long" in open air, and besides; I have transmitted ham radio using nothing more than a 60 watt light bulb for an antenna. No electrons flying out of there.
            Don't transverse waves and longitudinal waves both result in a compression/rarefaction phenomena which would both be detectable by the same well known means? If not then why do you think there is a difference? Is the magnetic component in TEM waves necessary for conventional detection?
            I know...no answers and more questions...sorry...it's the nature of our existence here.
              Radiant Collector Replications
              Basic Schematic:
              The input to the radiant exciter circuit is about 200mA; however, the radiant collector is not directly connected to the batteries. Output from the radiant collector circuit can be seen to be considerably more than the input to the exciter circuit.
              More Detailed
              Replication #1
              HTML Code:
              http://youtu.be/2JxunfyhtFI
              Replication #2
              HTML Code:
              http://youtu.be/vnHTtpPvsTQ
              Replication #3
              Diodes for Replication #3
              Originally posted by kajunkreations View Post
              15kv 4 amp 100ns.
              HTML Code:
              http://youtu.be/nhbtOvNLnko
              These diodes cost about $30US each.
              VIDBID
                Charging by Induction
                As far as I know, only electrostatic compression waves(Dr Peter Lindemann) and sound waves utilize compression and rarefaction.
                Interesting video on the electrophorus
                The Electrophorus: Part 1 - YouTube
                HTML Code:
                http://youtu.be/UtPtMltV4DY
                I believe this video explains charging by induction pretty well.
                Charging By Induction - YouTube
                HTML Code:
                http://youtu.be/o0hXYfvnND0
                VIDBID
                  JJ Thompson
                  Update 30 - Found missing info from Tesla Radiant Energy Patent - YouTube
                  HTML Code:
                  http://youtu.be/geYfUHh6nD8
                  Basically, what Tesla left out of his patent, according to the video.
                  See thread: http://www.energeticforum.com/renewa...gy-patent.html
                  HTML Code:
                  http://www.energeticforum.com/renewable-energy/4673-think-i-found-some-missing-info-teslas-radiant-energy-patent.html
                  J. J. Thomson - Wikipedia, the free encyclopedia
                  J.J. Thomson
                  On the Discharge of Electricity Produced by the Roentgen Rays
                  Proceedings of the Royal Society 1896, 59, 274
                  Royal Society Publishing
                  On the Discharge of Electricity Produced by the Rontgen Rays, and the Effects Produced by These Rays on Dielectrics through Which They Pass
                  VIDBID
