Symmetric versus Asymmetric Electromagnetic Systems
  • Is the question really symmetry vs asymmetry or understanding the changing fields.
    • I guess the field could be considered asymmetrical as more current passes through the first part of the coil vs the end, allowing the field to be larger.
      • Asymmetry...
        Hello Dave45,
        I have written about the best way to understand Asymmetry many times before in this Forum...but I will keep doing it as far as everyone understands where was "the Hidden Trick"
        When Einstein refers to Asymmetry, He does it referring at TWO different fields of Science...First one is in the Mathematical Equations... related to "Non Equalities" showing on both sides...He disregard it just because E=mc2...will not be a Symmetrical Equality then...
        The Second Asymmetry (As He refers to) is in the Physical field of Electromagnetic Induction from Faraday...and refers to the situation where Conductor is moving...Magnet at rest...or the other way around...Magnet moving Conductor at rest...would they be same?
        However neither of both "cases" will fit into what was behind the Scenes to be hidden...and that were the Father of Magnetism , James Clerk Maxwell's Electromagnetic Asymmetries from the Ether (Aether in other descriptions)...Where Lorentz and Einstein "simply disregard them all"
        BUT, IN ELECTRODYNAMIC MACHINES AND TRANSFORMERS...ASYMMETRY BECOMES A COMPLETELY DIFFERENT CONCEPT/APPROACH
        And here, it refers to the "Virtual Volume/Geometry of their Magnetic Fields Projections into the 3D Space"
        So, NO, it does NOT refers to the way you feed polarities to the same coil...NOT to the Electric Field...like You Posted in above Diagram/Post...so, please, forget about the Electric Field when it concerns Symmetry or Asymmetry related to Electrodynamic Machines...or Transformers.
        The famous Tesla Coil, where a Primary seats at bottom (Pancake Type Winding)...with heavier gauge wire and less turns...than secondary, which is an elongated, very long tower like shaped Coil, with very fine awg...and thousands of turns...is a perfect example of an Asymmetrical Transformer. Here, Both Coils projects completely different Virtual Magnetic Field Patterns into the 3D Space...and , AGAIN, it IS NOT DIRECTLY RELATED to the Coils Physical Shape ...but to the projected virtual magnetic fields...So, You could have two identical shaped coils as primary-secondary in a given Transformer...but, depending on the way they are positioned related to each others... will DEFINE IF, Transformer is Symmetrical or Asymmetrical...
        When We relate to Asymmetrical Motors and Generators...is basically very similar as above examples...except it relates to Dynamic (moving) Coils through Space/Time...
        • We all have our avenues of research and I do enjoy reading your opinions.
          I am more into creating a wave guide, a sink but will keep up to date on your research.
          all the best
          dave
            all the best
            dave
            Exactly Dave...We all have our avenues of research...
            "creating a wave guide"...that sounds interesting...
            • UFO,
              Would you say your design parallels some of the developments of P. Tewari's Space Energy Generator featured below? He also stresses the ability to overcome Lenz Law through what appears to be asymmetrical principals...but perhaps it looks different to you. Thanks!
              Genesis of Free Power Generation
              • Asymmetry is Asymmetry My Friend...
                Originally posted by jmag0904 View Post
                UFO,
                Hello Jmag0904,
                Sorry for small delay to answer, I have been busy...making some money...so we can keep going on...
                I was reviewing that work, excellent!
                I also saw the following link
                Very interesting...
                I will give you a "general" answer...
                There are MANY WAYS to brake the Symmetry, and there is where the whole secret lies....my friend. Many great Scientists have done it before in the past...whether in Solid State Circuits...or Electrodynamics...or Electronics, or simply in old Vacuum Tubes...and the main issue here is so simple...Symmetry is Symmetry...meaning, you add One and Take/Subtract One...then, what do you have?...Zero...a nicely round and very symmetrical zero [0].
                It is all about "Interactions"..."Exchanges"..."Equations"...
                If You take a look around Yourself...Our Lives...Our NATURAL Environment...You will find out most of everything around Us...is Asymmetrical...nothing "exchanges" into a perfect "Zero" equation...a very "clean Zero"...it does not exist...it is completely "man made"...
                I have shown through My Motors Design...there has been a "way" to make a Motor Spin with great performance...and still, render a Positive Value as a "GAIN" and NOT a Loss...that brakes Symmetry very simple, do not need to make OU...or Excess Output over Input...even being below...it IS NOT Negative...but Positive return to Us...
                And..."My Machines"(that actually they are a "property" of DR Nikola Tesla's Design, done in the 1800's...)...are just a tiny grain of Sand in a Huge Dessert...My Friend...
                Kind regards and thanks for bringing up this Thread!
                • Getting started
                  Hello all,
                  How do I get started experimenting with radiant energy? I have a really hard time understanding all of this, but I have some cool ideas on how to use it. Can anyone offer some assistance?
                  Meeker77
                  • Getting started
                    Hello UFOpolitics,
                    I am having a very difficult time understanding how to do any of this, but I have some really cool ideas on what it could be used for. How can I get started making these radiant energy devices? I want to experiment with tesla turbines being powered by air compressors that are powered with radiant energy....
                    Thank you,
                    Meeker77
