According to Perpetual Motion Defination,from wikipedia,
Perpetual motion describes hypothetical machines that operate or produce useful work indefinitely and, more generally, hypothetical machines that produce more work or energy than they consume, whether they might operate indefinitely or not.
Reality is we cannot go against those three laws of thermodynamics and three newton’s laws?These laws are verified to be true!So the perpectual devices based on modern Perpectual Defination can not be made(impossible). But real gravity engines are possible to make which do not violate laws of thermodynamics and Newton’s laws of motion.
Yes,some well known accepted laws of physics are proved wrong recently as I expected because those laws were made on assumptions which were not verified properly as true.But newton’s laws and laws of thermodynamics have enough evidences/proofs to proove it right.
My Gravity engine Is not Perpectual and based on the regular laws of physics you read in books,use or see everyday.
Why my engine works and why it is not Perpectual?
If it does not work,it will prove the regular laws of physics absolutely wrong!
All the laws of physics used in my engine are already validated to be true!and all those theories are used in other devices
There are three types of theories which can be proposed by a scientist:
1)theories based on assumptions(assumptions made with doubtable reasons):May be wrong or right:need to be experimentally verified
2) theories based on well known and well established laws:Always right
3)Hybrid of 1st and 2nd type
My engine is based on 2nd type!
To prove my engine works I have to prove that my engine works on regular laws of physics!
Since my engine is based on regular concepts of physics,there is no doubt that it works!
To check the validity of my engine,you may check the Example showing how Gravity energy is used as fuel in my engine
Now I am going to start making a prototype!I am talking to my college professors for starting this project!And the response is positive!Real Non-Perpectual gravity magnetic engines
Please see the Rough *Sketch on
Explaining clearly the working principle of my Non-Perpetual gravity engine for a single cycle,with an example. | Flickr - Photo Sharing!
for reference.
Hi guys,here is my analogous example of a very heavy weight red ball hanging,to explain a single cycle of my gravity engine working principle.
The splashing water on right side indicates how gravity is used to overcome water resistance,and convert gravitational energy in to splashing of water which is analogous to converted net electrical output of my engine.
The more the weight of ball,the more the resistance overcomed.
Energy is only supplied here to lift the ball up and recovered when ball comes down.It is comprising of half cycle motor and half cycle generator located at red pivot,controlled by a commutator.
Here also two downward processes occur simultaneously:1) recovery of supplied energy to lift the red ball through half cycle Generator mode of Motor Cum Generator at red shown Pivot.
2) The conversion of Gravitational energy in to electrical usable energy due to Overcommable weight obstacle resistance by the gravitational energy acting for more time by slowing the downward process. (Assume that you use water turbine to convert energy consumed in splashing of water into electricity for eliminating confussion).
Note that water resistance is present only on right at downward motion of ball and not on left.
The commutator changes it’s circuit coils orientation so that during upward process you lift ball and during downward process you recover supplied energy .
The idea behind the overcommable resistance is to extend time spent by gravity to act on a heavy object/ball by a few nanoseconds due to the slowing down of the heavy ball speed due to resistance offered.The more the time gravity acts at a particular height(H=H1),the more the gravity energy gained to overcome resistance (splashing the water resistance in analogous example given) as well to rotate the half cycle generator rotor.
That was just an Very similar analogy,actual engine will be actually completely different but will work on same principle.The resistance element will be like elastic like overcommable solid,but not fluid in my original design.
I have discussed only Analogous example(Basic concept) on Flickr only due to initial Patent law compatibility.I would have revealed the whole engine design itself instead of analogy BUT ;;;*
(A)"A patent document is published in Official gazette for public Opposition and further legal processing ONLY if the idea is novel AND it is never and not at all published anywhere else."—This is what patent law says.*
(B)Not only this,any body can copy the invention and patent it before you if you disclose it without publication in patent office. "*
"Analogy is a cognitive process of transferring information or meaning from a particular subject (the analogue or source) to another particular subject (the target)"*
What is strange is “Why nobody else pointed out about such a mechanical resistance before which can be overcomed by gravitational force.”
If you still have confussion open any “mechanics of material “textbooks and study how materials and weight offer resistance.This resistance occurs due to weight of the fluid.This type of resistance can also occur due to solid body weight.
So,what my engine does is tap the energy required to go against the resistance by the gravity.
Balance energy equation for my concept:
Energy supplied to lift Red ball through commutator controlled motor mode at pivot + gravitational energy required to push the resistance away + frictional losses + other entropy losses = supplied energy recovered though generator mode by commutator control at pivot(red coloured in sketch) + electricity converted from overcoming of resistance+ frictional losses + Back EMF losses + other entropy losses.
It’s also right if said theoratically that “energy supplying and recovery process “is just like a or analogous to a catalyst,which is used to let the resistance overcomming process through gravity take place without actually any net change of electrical energy form/format from one form to another form of energy.The energy used to overcome resistance is then converted to electrical energy by a suitable energy conversion system.
Limitation of the example/Analogy discussed here:
The analogy only explains a single complete cycle of the engine in comparison to Continuous repeating cycle of the actual engine.
Water is not used in actual engine due to efficiency problems of water turbine energy conversion processes.Water splashing is turbulent and blades opposite reaction of blades to the water striking offers lot of losses.So some other much much more efficient Solid elastic type resistance system is used in actual engine.
for reference.
