The inventor says:
"Need exciting current to start"
"provide 15 seconds current from 3x1.5volts, then disconnects"
"this is the fifth replicated device of 10, all identical"
"connect a multiple leds as a load"
"device can produce 2 Amps whith actual coil, but can be scaled"
"extracts energy from the centripetal force"
"is in contact with several companies for marketing"
"he knows that these technologies are hidden and suppressed"
"he is thinking to put into the public domain"
"cutoff the device, while capacitors have some charge then go to start again"
It seems to be in the area of Zafra in Badajoz, Spain, this area has great inventors.
I like the oldy worldy flair design of that thing...like a prop from the movie Chitty Chitty Bang Bang or something.
The way the VCR head spins up and then stops when the rest of it begins to run. The seemingly bolted anywhere lights and outputs, that still result in a compact unit.
And, that it seems to run well in the presence of red wine and young kids lol. All he needed was an elephant in the room and that would complete the potential disaster picture.
No idea what to make of it, or why he would put the 3 batteries in a plastic bag, but it looks great
The inventor says:
"has 3 parts: primary motor (silver right) powered with permanent magnets and captor (sensor, black part of the medium, seems a coil)"
"secondary generator (blue left) and third the captor"
"the secondary generator has two parts: a generator up
and in the bottom one multi-pole generator, contactless, is a field generator"
"the captor has a widing"
"the captor power the primary motor, this power the generator, produces a -trans pole- to captor, and again..."
Just the same as a human captor in a battle I would think...the capturing of a person by the enemy.
Therefore the captor would be any device which captures energy, for example a radio for radio waves.
hmmm...
Collect And Process The Output Readily
Yes, this is the meaning. Is a concept.
I think the inventor is Argentine, Spanish varies somewhat.
That's how I called the inventor, he does not explain what it contains inside.
I suppose it is a collector coil,
I have a friend who has worked hard on the replica of Torian, but has not worked. His name is Lorin Randone.
Yes, "el captor" also could be understood as "the capturer." In this case, I too would see it more like a coil to "capture" voltage being generated, like a pickup coil.
Bob
