Finer versus Coarse wire...
Hello Netica,
You have been lost!...(some people were thinking you were running to the Patent Office..?!...
Remember We need for you to please find out the range of frequencies-duty cycle where the Amps effect (No Increase on Mechanical Load) occurred ...
Related to your question now...
Finer wire allows less Amps (lower electron flow Population)...However, you could get a heavier volume of it, when using multi-filar strands, it will increase its Capacitance and magnetic field...and yes it will work like that also...The problem on this Machines is that we have Two Currents traveling within same wire...Radiant (Cold) and Hot...Now Radiant travels great in finer wire...Hot does not...Radiant could get to become very sparky if we allow it to develop further than Hot...So it is always good to keep a "balance"...
Finer wire works best as Secondaries within Rotor and/or Stator Coils...basically on Non Ferrous Cores...then those fine wires will only contain Radiant Flow within without interfering with Machine Operation of Primaries.
Originally posted by Netica
Hello Netica,
