Does the coil wire gets colder when you pulse it with ac current (or dc current for this motor)? it should.. plus repeating the same experiment over and over again with the same gauge wire should produce different results and bigger gauge wire should be better for this / plus all material connected including batteries should behave differently after they have been exposed to this test and electrolysis should give different results from normal electricity, if there is someone who needs some info about this feel free to pm me.
I'm expecting the clincher anyday now...
Watts in and extra watts out would be good but that always leads to "measurement wars"
and arguments. But the best clincher would be a self runner where the output goes to a cap and then back into running the motor.........
I thought UFOPOLITICS would have that by now but it looks like Turion or Netica could have the watts in and out anytime and even better the looped back self runner..
Then will come the alarmists who say it will ruin the world.
I just hope we can get past them this time.
Norman
Good job to you all, I have strong beliefs that if we overcoat the copper gauge wire using another material one should get different results from these attained with normal wire... I have to work out the inner and outer radius for the wire there should be a sweet spot where you get maximum effects depending on current settings.Last edited by tachyon; 09-12-2012, 12:30 PM.The pure in heart will see the light.
Originally posted by JohnStone View PostHi Nico,
nice work! I like it.
Just a hint:
The motor casings (iron) usually perform the outside magnetic closed circuit in order to make the field inside the motor stronger. Many standard motors have added another external iron tube in order to ease the field circuit.
You might try to add a similar iron tube around your transparent tube. The performance might be better.
@UFO: Do you confirm or refuse?
rgds John
Thanks for your hint!, I assumed that, but being my first project I want to "see inside" while running to check if something goes wrong, in fact the first time I fed with 34v the wire of one coil was not tight enough and broke... but this Ufo motors STILL RUNNING!! thanks to having separate coils (imagine a Symmetrical in this situation)
Thanks @All
Nico
Originally posted by Ufopolitics View PostHello Nico!!...and
Thanks for your kind words!!
And welcome my friend from the other Hemisphere of this Planet!...
I have to actually GO THERE and make it happen in ALL Universities from "El Rio Bravo hasta la Patagonia"...That is My Dream...since I am very, absolutely sure...That You guys down there...are the Ones that would really could use this Technology for great benefits...the same as African and Indian Continents...more than Any Northern Hemisphere Developed Country.
And love your excellent Model!!, it looks great and love that clear outer frame!!...Excellent and Luxury idea to see everything there!!
Any questions let me know.
Kind Regards!
...and hope you come soon! ... "Te espero con un rico asado" to talk about motors...
Nico
Originally posted by wonza View PostMasterBlaster many thanks for a great explanation and advice, hopefully it'll save me time and pain.Do you have any pictures or videos? I did a quick search but couldn't find any.
Attached FilesLast edited by MasterBlaster; 09-12-2012, 02:23 PM.
Got my four armatures stripped and put together. Have started winding them according to UFO's diagram. If I don't run out of wire, I might finish this up today.
DaveLast edited by Turion; 10-05-2012, 08:44 PM.“Advances are made by answering questions. Discoveries are made by questioning answers.”
Beautiful...
Originally posted by Turion View PostGot my four armatures stripped and put together. Have started winding them according to UFO's diagram. If I don't run out of wire, I might finish this up today.
That looks beautiful...
Now...Whatever happened to our Torque testing?
You have everything by now right?
I am not being "pushy" here...it is just that You also need those results to know if your modified UFO Machine will turn the weight of that "future" dedicated generator...
At your test when you know exactly the pounds of force applied versus the RPM's that is developing, you will know if it will turn it fast enough...as you also will need to measure weight on the completed generator armature...with wire and commutators...
Both Machines must be very accurately weight-torque balanced for your whole assembly to perform according to your expectations my dear friend...and without any stress or overheating on either side when running for long hours.
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Thanks!
Nico
I love Argentinian Asado...I was taught to make it by an Argentinian himself...the best red meat in the world.
Hello Norman
Originally posted by norman6538 View PostWatts in and extra watts out would be good but that always leads to "measurement wars"
and arguments.
That is precisely WHY...I want as many of you to make this Replications and their respective measurements....then when we all come to a mutual agreement...it would be very difficult to argue, object or deny the results, since they would be from so many different sources that will become automatically UNDENIABLE...
To please "some skeptic"..?...sorry I really don't care about skeptics...
Do you want to see a Self Runner?...with a Super Cap?...here:
Asymmetric Machine Learning Tool - YouTube
Lido Motor have this simple motor running off a Super Cap...I know a SC is like a small battery...however...if we just measure losses...will note there is almost zero...and it is still not using the generating side of Machine...
I- like I wrote before-...want to be YOU GUYS, WHO FIND OUT...and measure it...and convince yourselves that it does "make it"...not just me...and a video that "some skeptic" could say I have "faked or hoaxed out"... like they already have accused Turion of "faking the torque tests"...by someone else...who I really do not want to even mention his name here...
Do you think that would be enough for them?
Norman
UfopoliticsLast edited by Ufopolitics; 09-12-2012, 06:41 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Ok, ok,
Since you're not going to let me off the hook about the torque test, I will go down and get it set up. Will post a video in a couple hours.
Dave“Advances are made by answering questions. Discoveries are made by questioning answers.”
Lol
Try different weight values(Pull forces reflected on scales) versus RPM's within the weight of your generator armature as is now...then a bit above/calculate by guess the wire weight...write them down...I know what am talking about...the "thing is"...that later on...I do not want you crying all over this place that It does not work...
Originally posted by Ufopolitics View Post...You know I have to confirm on that steel tubing, from Hot point of view...Hot Flux likes great heavy steel casings...but not Radiant, SHE loves open environments, air...space...and we all know by now My Machines have a great part of Radiant Field inside of them...however, another way is to add another set of magnets at exterior of glass tube,and rotate them around tube to get better-stronger Static Fields.
Mariuscivic after charging a big Cap with same small motor...did that here at time 4:30 on...altering-moving "Asymmetrically" the Stators increase RPM's much more...as also note He added this Neo's at outer part of Stator Magnets...And He also have an empty-no steel case...
thanks ufo for teaching. I have to ponder on it. Crazy find - movint magents to the end!!!!!!!
@ALL: Today I got my vacuum motors. 2 original from Electrolux and one Chineese repalcement.
The original ones have 12 poles and 24 segements at commutator (center in the pic). The chineese one is built differently: 22poles and 22 segements at commutator (right hand top in pic).
It took 30 minutes for me - mechanically not experiencend guy - to make one ufo motor from two original Electrolux ones (not wound yet). I encourage to have a closer look to vacuum motors.
Now: How to wind 12 poles and 24 segements on commutator?
rgds JohnLast edited by JohnStone; 09-12-2012, 08:10 PM.Experts spend hours a day in order to question their doing while others stopped thinking feeling they were professionals.
Hello Dear John Stone
@ALL: Today I got my vacuum motors. 2 original from electrolux and one Chineese repalcement.
The original ones have 12 poles and 24 segements at commutator (middel in the pic). The chineese one is built diferently: 22poles and 22 segements at commutator 8right top in pic).
It took 30 minutes for me - mechanically not experiencend guy - to make one ufo motor from two original electrolux ones (not wount yet). I can encourage to have a closer look to vacuum motors.
rgds John
Beautiful "to be" machines there!
Your brushes are thick enough John...very minor possibility of error there...
HOWEVER, the "trick" is to make sure the center of commutator elements joined in pairs,IS aligned to the group of poles they will trigger by Brush sweep angle...as also between Upper-Lower Commutators...
Therefore mark them, color them...to identify Them, later on, at winding time.
Got my batteries charged up and letting them rest for one hour before taking voltages and running tests. Almost have my big armature wound, so will weigh it and use it as the torque weight. That was good advise...thanks. If the motor won't run this generator, I'll just build a bigger one.
