Hello AV
Hello Amps Volts,
Please...I am "no longer" a Guru...I am now a Pleiadian!!...
It will be a Controlled Pulsed System, in order not to blow out the Generator in smoke...
But the PM Stators on that Motor are so strong...I almost needed a Pulley to extract Armature from Motor Frame...
However, if you look at Diagram that is at Scale related to Stators area versus Armature Diameter, (I must do it at scale to calculate the Throw Out Forces well) will notice Magnets are pretty spaced apart...(I particularly would have designed much closer to each others [Bigger Magnets]...the increase and difference would then be galore)...But saying... I do have lots of room to add Coil-Stators there... wound around magnets...It will make up for the lost space...and it will enhance the strength on Stator side.
But it will run Generator Head easy without the Stators Coils... and at Full Load...for sure.
I got a few 500 Watts Incandescent Spot Lights...So, I will be loading them one by one and observing behavior- Meters reading...and filming...the "Light Show"...
Plus other heavy loads as well...Wall AC 12000 BTU...Portable AC 9000...All together to run it almost Max Surge Out Watts...I don't want the Skeptics crying that I should do this or that...to prove it, etc,etc...
So tell them all...I know exactly what am doing...
Regards A/V
Regards A/V
