One Brief Review about plastic/non ferrous core Machines
Hello to All,
I see how many of you are replicating the "Non Ferrous" Machines very successfully...and I am very happy to see all this great work!
At this stage of my work, I wanted for all of you to realize/verify/see, we do not need heavy steel cores to get a strong and Fast Motor running...This will deliver very light weight, yet fast and high torque machines...
But there is a draw back when it comes to their Hot Generating side...
This Non Ferrous Machines are very "Lousy" Hot electricity Generators, which is great for "Motoring Attributes"...since there would NOT BE more Hot Generator Counter Effect...
But, there will be very little on all their HOT generating side...so, please, do not expect high amounts of power at your output terminal Gates...it will not happen.
And the reason is very simple...we need a Hot Strong Magnetic Field, that only thrives/grow excellent inside steel lamination, in order to Magnify the Storage Capacity within that hot magnetic field, then the charges to be delivered at output terminals will remain at higher levels, while also being induced/magnified/maintained by the fact of traveling within the Hot stators fields.
But again, everything in life is a matter of "Balance"...A balance in the "Equation" to be even more successful, so, there could be "Half and Half" Machines...where we maintain an equilibrium of fields...by simply alternating lamination between steel-plastic...or other non ferrous material like aluminum...then we will have both worlds within same embodiment...
I wanted to explain all this...so you guys will not be expecting a great Hot Generator Output from all your beautiful machines...
Regards and
Hello to All,
Regards and
