Thanks Freind
Thanks UFO, will digest what you said and get back to you, sorry but it will be with lot's more questions.
Originally posted by Ufopolitics
Hello Cornboy and thanks!, it is all my pleasure.
1-I have been able to see a WarP9 Armature...as so, you will in the video below...go to 10:00
Oct 21, 2012 - EVTV Green WarP 9 Motor Disassembly - YouTube
Now that armature is wounded with the single heavy gauge wire, which is the typical "new Symmetric method" brush motor styles for EV's, including Utility and small EV like Golf Carts...On video you could see the excessive heat that rotor has been exposed to...it is a heavy and serious short 100 percent of its running time...
It is NOT good for an Asymmetrical Conversion due to lack of room to wind finer wire and several turns per Groups. This cores opening between poles do not go all the way close to shaft and sometimes they just have a drum like inner space...
Also take a look at your space to add the second Commutator...no room either, shaft is not long enough...therefore outer housing also needs to be elongated...
So, honestly...trying to adapt this motor to Asymmetric...you would be better off making everything from scratch (at least all from shaft, CAD/Cut armature steel laminates pressing them on shaft then insulating them...for rotor/armature, as also the outer frame housing...and just getting the commutators and brushes housings with their boards...
Still, That is a lot of work my friend...that is why I recommend some specific motors to do this modifications...since I have gone already through all this trouble/time and $pending lot's of it...
2-It depends on the demand/request that you want from the EV. application..also room to mount it... weight to drag...want it street legal?...country roads?...racing...etc,etc
Propulsion of an EV...I have considered to build an specific machine...about the size of the Gas Engine Block (including the heads), then adding same required accessories like the power steering pump, vacuum pump (for brakes and AC operations of control gates) Air Conditioning Compressor...etc...(We will not need a water pump...no water, and no Alternator...we have a huge one...
...Add those to front end through front plate bracket mount and belt pulleys drive, and connect rear of motor shaft to Tranny Bell Housing at back...so it will be mounted and connected just like the Old Gas Engine.
Now related to Asymmetric Design...I posted recently The Magnificence of Three...and that design will "Rock and Roll" your EV...based on 36 poles or more...multiples of 3,6,9...like 72 poles or more within those combinations.
And again a cheaper deal would be the Imperial Motor I am working on...but that would move only small vehicles...like small 4 passengers utility cars...
If you look at the WarP9 spec's... it uses over 200 to 300 Volt System...and around the same amount in Amps...that requires a whole bunch of stack batteries...adding lot of weight to Vehicle...drag galore. We do not need that much power weight room from "Source" to propel our Asymmetric powered vehicles...
3- Yes, definitively...to have the required heavy power/torque we need the old steel...when working with Hot Side, my friend.
Statement Response: In order to be able to control the speed of your EV Motor precisely ...definitively you will need a bit of Electronic Circuitry work...but come on...all the Diagrams and parts are there!!...all you need is to put them together like a LEGO for a three years old...
But do not worry...we got great Electronic Engineers around here like Sir John Stone...so dont worry be![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
![Thumbs Up Smiley](http://www.energeticforum.com/core/images/smilies/thumbsup.gif)
![Big Grin](http://www.energeticforum.com/core/images/smilies/biggrin.png)
![V Peace sign Smiley](http://www.energeticforum.com/core/images/smilies/v-peace.gif)
