External Connection Two
Hello to All,
I am actually kind of "rushing" on displaying this Connection due mainly on Prochiro (Dana) progress on the advanced replications with Imperial Pulsing...I am NOT done making the final testing on this connections...but it would be worth for Machine Alive and Prochiro to test them, since they may have the right resistance per Pair/Coil, which -I believe- at this point, is my problem as of now.
Machine Imperial have a much lower resistance than mine...and I do not know about Dana's...don't recall he has mention it...
[IMG]
[/IMG]
With this connection, when I have the Mecc Alte engaged/coupled with Motor, the higher amperage I get is around 6-7 amps @ 36V...
Unfortunately...the problem -so far- is that I only reach 2300 RPM's Max...
...not enough to turn on power on Generator Head...even though Torque is very high, just like running it at higher amperage.
I believe here lies, at least one, of the methods to run Generator Heads...the resistance -in my case- IF it would be lower...I believe I will reach the required additional 1300 RPM's...
I have tried with 48 Volts...and the highest amperage is 11 amps @ 2380 RPM's...with load on...however the 500 watts ea lamps only lite dim, energy meter do not get to show readings...
So, I believe that if pulsed at a sequential order with a dead time, where SW1/SW2 are...it could render much better results.
Diodes are there to avoid reverse currents, as to show/understand flow...but it will do same effect without them.
To ALL:
You guys could test on all your Asymmetrical Machines this simple connection, even on the Radio Shack Motor...two brushes or four...don't matter how many poles...just jump the bottom Output-Input and feed from top...amperage gets down to nickel and dimes...
...Torque does not get affected.
Regards to All
Edit 1: Commutators only get "warm"...even on Imperial
Hello to All,
[IMG]
To ALL:
Regards to All
