Hello Shylo
Hello Shylo!
Oh come on Shylo!...I know you can understand it!
No Shylo, Bisector is the "dead Center" of the Magnetic Field Pole...it exists on North and South Poles...on permanent or electromagnets...it is where most of its force is "concentrated" and from there to either sides it starts to decrease...I normally picture like a "needle" but it is not exactly like that...however for timing alignment it works like a needle...or physical center of the coil geometry.
If You grab Two permanent magnets and turn them to face same poles...and get them closer slowly perfectly aligned...there would be a point where you start feeling like a "Solid but Flexible Ball"...and if you keep pressing magnet will eventually force your hand to go either way...depending where are your angles of pressure...have you ever done that?...if not try it...you will have a "Physical Experience" of what is a Bisector.
I lost you here...running from where to where?...could you be a bit more specific?...
Ok, if we are talking about loose Magnetic Fields , when North and South meet at their Bisectors...it occurs an immediate "Magnetic Fusion" based on Attraction...magnets lock against each others...or lock/stop any rotor or armature...or create a huge magnetic drag...even being on bearings...that is why in Asymmetric Motors we must turn them off before getting different polarity bisectors "too close".
If you are referring to locked in place magnetic fields...like in a motor...then it is a simple math formula...that depends on which is stronger, stator or rotor...then it is just deducting subtracting vectors of force...if they are equal...then resultant is zero...no magnetic field, canceled out to each others...however...it is very hard to find "perfectly balanced" magnetic fields.
If You allow magnets to lock up (obviously North-South)...right in that fused point there is no polarity...the magnetic chain got locked up, only to reinforce the strength of the two "new" extreme outer poles. We could say...they "cancel" each others resulting in zero magnetic polarity (If, and Only If both magnets are of the same strength, volume and physical properties...like both must be Neo's...or Ceramic...etc.
Yes they do "swap" magnetic polarity as they swap voltage potential...I have demonstrated that fact since my first thread here.
It is very hard to be able to actually measure that change...unless you have the right and required sophisticated equipment that is very expensive my friend...
So, our only ways are by making tests within Coils center (that is where the Poles swapping gets generated...and it does not last too long...because the previous collapsing field was what actually "pumped inwards"...so if the "pump stops...the reversed field is gone.
In my Three Pole Design...it clearly shows , according to this particular motor design , performance and attributes...that really swaps polarity when coils are off time of pulse. (you could review this Motor either on my site (ufopolitics.com) or videos of replications on YT Channel...or in site "Replications" page.
UFOPOLITICS THREE POLES
UFOPOLITICS THREE POLE REPLICATION
Please also watch: DEFINING RADIANT ENERGY FIELD (Part 1) - YouTube
I wish I could spend more time to make sure you understand everything as well as I do...and I hope this post, kinds of clears at least "a bit more"..
Thanks and Regards
Originally posted by shylo
I follow this thread ,but 99 percent of it is over my head.
In post 5773 ,you show Teslas' winding with the strong bi-sector .
Is that the point where north and south meet?
Does all the wire running from one side to the other not add to the eddy currents?
The point where south and north meet , is there no polarity?
Currently winding a new pulse motor (having a hard time with coils shorting), but does a pulsed coil create an opposite pole when the supply is cut off? IF it does , this can definitely be used to our advantage.
Sorry for interrupting , just those diagrams got the old wheels turning.
Thanks for all your work , just wish I understood it better.
artv
artv
Thanks and Regards
