Wiring Nessie...
Hello my dear friend Kogs,
Sounds great, you are getting to the final stage...
That was great test, the point here is that you observe the Voltage out, even using the brushes in parallel at output, it is understood that if you would have them in series, voltages would add even more than that.
Input=36V
Output=50-78 Volts
When you put a mechanical load the amps jumped above 10 amps, that is normal, since you are slowing down by force keeping same feed, and also the amperage would increase for output as well.
Yes, I did suggested that...BUT, You could run single wires off the motor (just like we did with Imperial) and switch the connections at dashboard to get output in series...or separately excited (feed input) each one. Meaning, You DO NOT need to make the series connection INTERNALLY inside Motor.
In your 1000W you have the same arrangement as in Imperial, meaning four brush/four stators.
You could have different ways to run Nessie with this set up...
1- Using typical Two set of Brushes for Input and Two set for Generator (series connected) that could be sent to a Cap Bank recovery Tank...then back to batteries.
2-Accelerating or Turbo Boosting Nessie by feeding ALL Four Gates based on FOUR SWITCHES as GEARS, ADDING ONE BY ONE at a time...First Gear, Second, Third and Fourth...No Output/Generator
2a- This type of electronic switching/gears will give you different "Modes" to run Nessie, Independently from the Controller Acceleration Feeding from Batteries:
First Gear: On 1st gear you need high torque/high speed to brake inertia forces, and like in a standard vehicle, it is NOT intended to use it for too long...In your case First Gear would be ALL Four Gates at once.
Second Gear: 2nd gear would be Three Gates, while the not fed Gate would be retro-feeding back to source. I would call this Gear the "PASSING GEAR"
Third Gear: Two Gates (what is our typical connection of 2+2) meaning two on Input, Two on Output. And this Gear would be a "STANDARD CRUISING GEAR"
Fourth Gear: would run just ONE GATE...while you are getting Three Gates to feed Cap Bank/Batteries. This Mode would be like an "ECONO DRIVE" and more likely could be used down hills or flat land after reaching a fair speed with previous three gears...
It is just like driving a standard, manually shifting gear vehicle...![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
Only thing you will need to get...are Four nice and heavy duty High Amperage rated switches, like 50 Amps/48V...BUT Double Throw switches, having basically a Two Position from a middle input to Two connections, Up and Down...so when connecting one the other disconnects...So, when not feeding/Input from Controller, it would connect to Cap Bank.
Switches could also be with a Neutral Position at center (Three Stages) where NO CONTACT to ANY will just disconnect Gate completely from Input or Output
ONE MAIN THING KOGS, PLEASE!!
Do not forget to Install from the MAIN POSITIVE CABLE TO BATTERIES A KILL SWITCH...AND make sure you would have VERY EASY access from your driver seat...Remember, when FET's go bad...they normally do it by shorting out Source to Drain...meaning "RUNAWAY DRIVING"...You have N-Channels...so killing must be done by cutting off POSITIVE from Batteries...NOT Negative!
Do not want to hear that Nessie crashed, because of just one faulty FET!!
SECOND: Make sure that you test ON BENCH FIRST all this connections (if you want to do them, of course) BASICALLY the FIRST GEAR , in order to test your controller stress to "take it" since it will do, reverse very high spikes.
Great friend, looking forward to see those videos.
Kind regards
![Thumbs Up Smiley](http://www.energeticforum.com/core/images/smilies/thumbsup.gif)
Now as regards to the testing you have suggested
The motor connections to the 4 brushes is as from the factory 2x 2 parallel with this setup the amps draw is only 0.2 amps and under load is less than 6 amps.
I made a new 6 Mosfet controller the same as I used in my coil pulsing circuit to light the 5 CLF bulbs it was drawing 0.2A @ nominal 36v no load speed was around 1800RPM? (the meter I could not adjust exactly)under load using the 2 sticks of wood was 5A the motor was very hard to slow down.
I have wired up just temporary connection#1 as you suggested so I made sure I understood what you are saying the amps draw was 1 amp and the output was fluctuating between 50v 78v I did not measure the revs
When I put a load by jamming the shaft with 2 sticks of wood the amps jumped off the 10 amp scale the Mosfets were cool still and the motor was cool
Input=36V
Output=50-78 Volts
You have suggested that I have the generator brushes wired so the 2 generator windings are in series.
I will now clean up my workshop so I can have room for my video producer can get some more practice when she takes some videos of my testing.
Please UFO if you have any comments with regarding the testing please let me know ASAP outlining what testing you would like me to do as I intend to do the serial mod to the motor and then test it I would like to do all the testing in one video perhaps starting before the serial Generator mod if you desire for me to do so.
There is at Cavendish a local town probably 150k away on the 30th of March a "SHOW US YOUR WHEELS & TOYS DAY" its like a Trash and Treasure Swap meet If I have it finished by then I may take Nessie there and show her off.
I thank you for all your time spent to showing what you have discovered and have disclosed to us.
I am anxious to see what you have in store for us in the future I know my self that I would like to build one of the latest designs you have put up for all to see but unfortunately I am quickly running out of $$ I need some paying work to continue these projects.
Kindest Regards to you my friend
![](http://i1193.photobucket.com/albums/aa350/Kogs1/Kogs%20UFO%20Photos/th_gears_animated_avatar_99x89_57418.gif)
Kogs progressing Slowly
![Rolling On Floor Laughing](http://www.energeticforum.com/core/images/smilies/rofl.gif)
Kind regards
